Old 06-20-2013, 01:34 AM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by soulstice View Post
I'm getting a manual boot sent to me in the next couple of days. I'll try this out one of these weekends and post what I end up doing if I figure something clever out. Hard to say until I get under there and see what's going on.
So I finally got this all straightened out last week in time for 86Expo. The main issue was the PRND piece not being able to line up with the two screws on the MT shifter trim. At first I tried to velcro it under the center console, but heat lead to that failing. So I took a shot and was able to mount it to the shifter trim, with a little bit of work.
I do not take any liability for the actions you take with your car. This is merely me sharing my experience with the community.
I don't own a dremel, so I started by grabbing a hack saw. Lol
I then made my cuts. My goal was to allow the PRND piece to have the trim screws hold it in by pressure, not necessarily in a complete hole.
(Ignore the upper cut. My first alignment didn't work out like I thought. You will be cutting the smaller of the two holes, which is the hole for the peg, not the screw originally.)
I then made my second cut.
In the end, this was my result. It is a bit of a tight fit once installed, so be careful when you are snapping it into place as there is not much clearance under the shift boot itself.
This is my first attempt at a write up so if you have any more questions please feel free to ask here or PM me. I may take better pics and post this in the DIY eventually if there is enough interest. Thanks for reading and I hope this helps.
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
itdansharpe (06-20-2013), ramiram1984 (06-20-2013), soulstice (06-20-2013)
Old 06-20-2013, 11:53 AM   #16
ramiram1984
Drives: 2016 STi DGM
Y'all just want people to think its MT
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 06-20-2013, 11:56 AM   #17
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
This probably wouldn't be the case if you MT drivers weren't so judgmental :P
Perihelion is offline   Reply With Quote
Old 06-20-2013, 12:03 PM   #18
itdansharpe
itdansharpe's Avatar
I plan on doing this, for this exact reason!
Why? YOLO.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
The Following User Says Thank You to itdansharpe For This Useful Post:
Old 06-20-2013, 12:09 PM   #19
ramiram1984
Ya I don't get that. To each their own is what I say!
-2014 SSM BRZ MT
Old 06-20-2013, 12:10 PM   #20
ramiram1984
Any update pics on what you did with the prnd?
TRUE BLUE
-2014 SSM BRZ MT
Old 06-20-2013, 01:52 PM   #21
soulstice
Drives: SWP BRZ LTD
Thanks for the pics. I haven't had a free weekend to take things apart but hopefully I'll be able to take my own pass at this too.
1.) does the AT plastic piece #17 in the diagram need to be removed to do this mod?
2. do you need the #16 piece or is that just a MT Shifter boot, can't tell if it's just the pleather or plastic
3.) do you have a link to the DIY that you can recommend that shows how to get the center console apart?
4.) So in broad strokes you're just offsetting the PRND so that the manual boot has sufficient room to clear, correct?
soulstice is offline   Reply With Quote
Old 06-20-2013, 01:53 PM   #22
soulstice
Drives: SWP BRZ LTD
1) The opening on the MT boot is too large for the AT. (My GF sewed a snap button in front of it to tighten it up closed)
Do you have a pic of this as well?
The Following User Says Thank You to soulstice For This Useful Post:
jazztennor (07-21-2013)
Old 06-20-2013, 02:19 PM   #23
Perihelion
Perihelion's Avatar
If you guys do this, get the JPM coachworks shifter boot
Old 06-20-2013, 04:25 PM   #24
finch1750
finch1750's Avatar
So you can do it one of two ways. The leather seperates from the plastic but they are labeled as one unit in your diagram. I just swapped my whole piece. #16 and #17 are the different mt and at pieces, so in the end it will only be one of those that is used.
Ill post a link later when Im not on my phone to an article on the center console diy. And yes, in broad terms this is to get the prnd piece to fit with the manual trim. When you take it apart and compare the mt and at it will make a lot more sense.
Ill also snap a pic of the boot when i get off work.
Old 06-20-2013, 04:35 PM   #25
soulstice
Drives: SWP BRZ LTD
Crap, that means I need to find the manual plastic piece somewhere. I thought I only needed the shifter boot. Where did you get yours?
Old 06-20-2013, 04:57 PM   #26
finch1750
finch1750's Avatar
The silver plastic piece is the same. Did your boot come with a plastic ring attached to the bottom? That is what actually screws into the silver trim piece. I can take a pic tonight for you
Old 06-20-2013, 05:20 PM   #27
soulstice
Drives: SWP BRZ LTD
I'm not talking about the silver piece. I bought just the boot from another forum member who replaced their boot with an aftermarket one. At the time I didn't realize i'd need the plastic ring as well. Did you just order the whole boot assembly(shift boot + plastic ring) from a Subaru parts seller?
Old 06-20-2013, 05:33 PM   #28
Perihelion
Perihelion's Avatar
you can def get it separate. check out parts.com
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 11:56 PM
Short Shifter paulieblaze Engine, Exhaust, Transmission 33 01-20-2014 12:55 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 02:21 PM
Automatic slowdown shifter noise Roadstercycle Engine, Exhaust, Transmission 5 07-17-2012 06:32 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 09:20 PM
