Old 09-12-2012, 09:05 PM   #71
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by gmookher View Post
the overpipe and frontpipe arrive tommorrow I will let you know
You lucky fella
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-12-2012, 09:14 PM   #72
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Originally Posted by 2forme View Post
I've ridden/driven in Sony's car. You don't hear it unless you're really really getting on it. It's TOO quiet IMO.
Non-resonated is too quiet?
sho220 is offline   Reply With Quote
Old 09-12-2012, 09:18 PM   #73
2forme
Sony's is resonated. I haven't heard non-resonated.
Old 09-12-2012, 09:25 PM   #74
sho220
sho220's Avatar
You can definitely hear the non-resonated...
Old 09-12-2012, 09:29 PM   #75
2forme
Sweet!
Old 09-12-2012, 09:49 PM   #76
mach330
Drives: Ultramarine frs
I'm not seeing any sharp bends...?
In no way does the stock exhaust compare...ride in a car with Perrin's catback and you will see the light...
compare that to stock. It's Greddy axle back so midpipe is stock I believe. Doesn't stock look more smooth on the part that bends compare to Perrin? Maybe it's the angle?
So what's the consensus. I need to get this exhaust but I dunno how loud the non resonated is.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 09-12-2012, 09:57 PM   #77
tonystewart
Resonated
Old 09-12-2012, 10:28 PM   #78
loam
Drives: SWP BRZ LTD
You can also definitely hear the resonated.
loam is offline   Reply With Quote
Old 09-12-2012, 11:00 PM   #79
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
I just installed this Perrin Cat Back Resonated on my car and you can definitely tell the difference between this and stock. It has a nice low tone to it without the farty sounds of some of those other exhausts. It is first rate quality as well.
jjkerr626 is offline   Reply With Quote
The Following User Says Thank You to jjkerr626 For This Useful Post:
Chad86 (04-21-2014)
Old 09-13-2012, 12:26 AM   #80
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Tap'd from my G-Nex
The Perrin has fewer bends with smaller angles on the bends that are there...oh also it's 2.5" pipe instead of 2.25" so it flows better.
I will have sound clips of the non-resonated mid-pipe in a couple weeks if you can wait.
Sound clips of the resonated version will be made tomorrow, I just got confirmation from Kaizen that we are on for the Dyno tomorrow.
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 09-13-2012, 09:27 AM   #81
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Stock is 2.118"
Old 09-13-2012, 01:17 PM   #82
gmookher
Originally Posted by tonystewart View Post
That's sound like a fun install!
Okay so I took off the front pipe and overpipe in anticipation of UPS bringing the new Perrin overpipe, frontpipe and Oil Cooler this afternoon from Perrin (Thanks @PERRIN_Chris)
The removal and install is very easy.
simple, even a noob can do it if you got some stands and ramps:
Elevate the car securely keeping it level. safety is your 1st concern before doing this, so make sure its SECURE
I use a pro grade jack under the radiator support, have the rear wheels on ramps and have jackstands a plenty under chassis. Once you have it up in the air and level...and secure
1-remove both underbody panels, cake
2-loosen 14mm bolts at overpipe and front pipe, use a rubber mallet if getting leverage is tough in a tight spot like I did with a box wrench, drop hanger bolt too
3-loosened the motor mounts-bolts are easily located inside crossmember, also 14mm, removed passenger side bolt, for ease, I also loosened the driver side a few turns so as to remove preload. jacked up gently from oil pan(or tranny if your hamfisted) using a rubber pad just enough to wiggle OE overpipe out.
5-remove and reinstall in reverse order
hurry up UPS truck!
Took me about 30 mins to jack it up and Remove it all. Installation should be a breeze likely about 15-20 mins.
gmookher is offline   Reply With Quote
Old 09-13-2012, 01:23 PM   #83
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Their oil cooler is already on sale?! Where?
Old 09-13-2012, 01:24 PM   #84
Sportsguy83
Drives: Limited BRZ
He's testing their protptype
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 10:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 10:05 AM
Review of ISIS Street Catback exhaust sirhc Engine, Exhaust, Transmission 24 10-29-2012 05:57 AM
