#267 |
Drives: Brz
Sorry for reviving this thread but, sound wise. is it worth the extra 100 bucks to get the 3" perrin catback?
#268 |
Drives: 2013 Argento Scion FR-S
If you are going down a FI route later on then yes. Or perhaps looking for an exhaust a tad bit louder than the 2.5". I've got the 2.5" resonated and extremely happy with the quality overall.
#269 |
Drives: Scion Fr-s
Can some one please tell me the length of the resonator? I would really appreciate it. Thanks
#270 | |
Drives: 2013 Subaru BRZ MT Limited
If you need an approximate and not an exact, the Resonator is about 30" long, it's pretty big compared to others, it's also probably 4" in diameter.
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
| The Following User Says Thank You to Sony For This Useful Post: | Juanito08 (04-02-2014) |
#271 | |
Coffee Snob
Drives: '14 SWP BRZ Limited
Good estimation.
| The Following User Says Thank You to leicaboss For This Useful Post: | Juanito08 (04-02-2014) |
#272 | |
Drives: Scion Fr-s
#273 |
Drives: 2013 WRB BRZ Limited
I have a stupid question. How can I tell if I have a leak on one of the clamps? The exhaust is fairly loud between 1-3k rpm. I tightened the vclamps to within a half inch of each of those metal parts. They aren't touching like in the pictures here but I'm worried I'll break them if I tighten them anymore. It is a 2.5 resonated so I dont think it should be this loud. At 4k and above it doesn't sound loud.
| The Following User Says Thank You to oldlostcory For This Useful Post: | leoh007 (03-12-2015) |
#274 | |
Drives: Subaru BRZ
So to look for leaks I would park your car over some cardboard and let it idle for a few minutes or so. If you see and water marks on the cardboard you probably have a leak, at least at idle speeds. Even so I don't think it's an issue if its just a pin-hole leak south of the cat. |
| The Following User Says Thank You to RacerX For This Useful Post: | oldlostcory (04-17-2014) |
#275 | ||
The following quote about the clamps is from Chris Perrin himself. Quote:
| The Following User Says Thank You to Sony For This Useful Post: | oldlostcory (04-17-2014) |
#276 |
Thumper
Drives: 2013 FRS
I just crawled under the car tonight to check my driveshaft bolts. I believe I saw that my clamps had ~1/4 in gap.
Car is gone - parts for sale
#277 |
Speed Chaser Thrill Seekr
Drives: 2014 Asphalt Monogram FR-S 6MT
Did the Perrin guys post the data they promised for the 3" system? I know it's shipping as I just ordered one.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint My Build |
| The Following User Says Thank You to Xerious For This Useful Post: | Churnobyl (04-18-2014) |
#278 |
You guys were right it did need tightened down more. Although not as tight as I made the one near the muffler, yeah I broke it. Thankfully I managed to find a replacement at the local Advanced auto. Now it sounds like it should. The drone is gone and it is just a bit louder than stock. Thanks again for those that gave me tips.
#279 |
Drives: Subaru BRZ
hmmm... I think I'll crawl under mine and check them. I'm pretty sure they're tight but I don't think mine are touching. I wouldn't have thought that a small leak would cause drone. I'm not so sure about that.
#280 |
Drives: 2014 Subaru BRZ
Sorry guys, I'm not sure why I said that, actually the V band end should not be touching, there should be a gap, about even with the gaps around the V band, but most important, 70 in lbs, not ft lbs!
| Perrin Catback Exhaust vs Nameless Performance Exhaust. | vignesh | Engine, Exhaust, Transmission | 201 | 06-05-2013 10:47 PM |
| NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! | AJ@ECSMotorsports | Engine, Exhaust, Bolt-Ons | 31 | 04-06-2013 10:05 AM |
| Review of ISIS Street Catback exhaust | sirhc | Engine, Exhaust, Transmission | 24 | 10-29-2012 05:57 AM |
