#15 | |
Drives: Scion FR-S
Personally, I release the clutch smoothly until I feel the engagement point and then gently give it gas. |
| The Following User Says Thank You to Gen For This Useful Post: | tintumz22 (09-05-2012) |
#16 |
Drives: 2013 MT Asphalt FR-S
I start with the gas to about 1500 RPM, start letting out the clutch and when the RPMs start to drop, add more gas. That is the way my dad taught me, right or wrong and at this point it is autonomic, I don't even think about it. I have to concentrate to do it any other way, like high RPM launches.
| The Following User Says Thank You to 5hairpins For This Useful Post: | tintumz22 (09-05-2012) |
#17 |
Drives: 2013 Scion FR-S (Hot Lava)
I always rev the car up to like 800-1000rpm and just slowly let the clutch in while applying more gas as the engine load increases. Think about as one foot does one the other does the exact opposite.
#18 |
Drives: 2015 Mustang GT (on order)
I pull the e-brake, rev to 5000RPM, dump the clutch, then slowly let off the e-brake over a period of around 20 seconds. Usually works.
| The Following User Says Thank You to jeebus For This Useful Post: | onthemove (09-05-2012) |
#19 | |
Option 2 is "driving it like your car cost you hard earned money". As others have mentioned, you will find all kinds of techniques for using the clutch. The above two options are the extremes. You can abuse your car all you want but it will cost you a lot more money to maintain your car. |
#20 |
Drives: 2013 Argento Silver FR-S
Sometimes it helps to have an understanding of what all of these parts are doing.
Take a moment and view these: [ame="http://www.youtube.com/watch?v=c8qsS2g_IiU&feature=related"]HOW A CLUTCH WORKS NZ Automotive Distributors - NZAD - Clutches - Flywheels - YouTube[/ame] [ame="http://www.youtube.com/watch?v=p8fAHTeDGiQ"]Auto Repair: Transmissions: "Planetary Gears, Principles of Operation, Multiple Sets 1953 US Army - YouTube[/ame] |
| The Following 2 Users Say Thank You to cgrey For This Useful Post: | steeloyangster (09-05-2012), tintumz22 (09-05-2012) |
#21 | |
Drives: 14' FRS 6MT; 16' WRX 6MT
When I was young and dumb, I used to drive my mom's AUTO Camry with both feet. A few months after she had the brakes done they needed to be changed again and my mom was real unhappy about it. Had a friend following me one day and when we got to where we were going he asked,"Why are you always braking!?" And I responded with,"What the hell do you mean?" And he said,"Your brake lights are on like 90% of the time!" Then I realized that my left foot came at a resting position on the brake pedal, causing the brakes to fail early. |
#22 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
#23 |
My technique depends. If i'm launching the car fast, which will put more wear on the components, I rev to around 2500-3000 rpm, then let out the clutch slowly as I am simultaneously decreasing pressure on the accelerator. When the clutch is fully engaged, I go ahead and stomp the accelerator. That all happens in about .5 seconds, so it's muscle memory to a very high degree.
For a slow start, it's basically the same thing, but you will start moving with more emphasis on the clutch. As others have mentioned, learning to get the car moving with only the clutch is an important skill. |
| The Following User Says Thank You to BuBlake For This Useful Post: | tintumz22 (09-06-2012) |
#24 | |
/threadjack Good advice regarding the dead pedal, resting your foot on the clutch is bad for the throw out bearing. Same as resting your hand on the stick, it can cause excessive wear on the shift forks inside the tranny. |
#25 |
Drives: Toyota
I remember when I first started driving stick, just remember to calm yourself down and not think too much and you'll get it
PS. I'm still scared of up hill ![]() any advice? |
#26 |
Drives: 2013"Road scalpel"FR-S MT
OP when your talking about punching the gas. I think you mean tapping the gas pedal, like how you might tap you finger on the table, but with you foot tapping the throttle.
Scared of up hill, your a fruit. Start out up hills like normal, but do it much faster and a little more throttle. |
#27 |
Drives: GT86
What the?
Isn't it required to be able to drive manual to get your driving license in US?!
#28 | |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
http://www.npr.org/2012/03/26/149398...-transmissions I figure that less then 25% of the population knows how to drive car with a manual transmission.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 09:39 PM |
| Starting a Group Buy | haloterence | Site Announcements / Questions / Issues | 7 | 08-29-2012 04:09 AM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 08:44 PM |
| Starting it off | e10rice | Mid-Atlantic | 93 | 03-26-2012 04:16 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 01-29-2012 02:21 PM |
