#99 |
86 Rolla
Drives: BMW X5
Great driving on the near Miss video,
Also um Im not confident in doing this myself to you reckon if I brought this guide to a tech shop they would install it for me?
-Kyubi (Unrivaled 86 Perth Australia)
My Mods to my red 86, Sprintex Supercharger Inter cooled, 5Axis Body kit, KW V3 Coilovers, Invidia N1 Exhaust. BRZ Rear diffuser and custom "UNRIVALED" plates. |
#100 | |
#101 |
86 Rolla
Drives: BMW X5
Ok but when I break my car Im sending it to you in America to fix!
jks jks :P Also may have missed where the guy said it but how does the info get stored as in recordings and how do you access it? this is my first time with a dash cam so be gental
#102 |
Drives: BRZ Limited
You just pop the micro SD card out and put it in your Windows computer. You install the software that the camera automatically puts on the micro SD card. The installed software reads the dash videos that are stored on the micro SD card. Pretty cool system actually.
| The Following User Says Thank You to developer For This Useful Post: | Kyubi (01-09-2013) |
#103 |
Drives: toyota camry
guys, i saw someone on youtube hard wire the wire from magic power pro to the existing fuse without using additional circuit and fuse. I believe this will solve the problem where the fuse box cover cannot be closed after the installation. Anyone can tell is there any problem by doing this?
[ame="http://www.youtube.com/watch?v=N8Gow5pbeEg"]How to Hardwire a Blackvue Power Magic Pro - Blackboxmycar.com - YouTube[/ame] |
#104 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Sticking wire in there, you risk a short between two circuits. This next sentence is purely an example: you could join the cigar lighter to the AC! Could be a fire hazard. I"m not 100% sure how he got the wire in there but some other articles I read involve wrapping the [blackvue power magic pro] wires around the legs of the fuse. THis works on regular fuses but on our cars there isn't much leg to wrap wire around. ![]() 20120831-LolaBlackVue400DIY-40 by VictorN07, on Flickr
#105 | |
http://www.ebay.com.au/itm/1A-1-Amp-...610386f&_uhb=1 |
#106 |
Drives: Honda Civic 07
Hey guys. So I just bought 2 of these off ebay: http://www.ebay.com/itm/280996426137...84.m1497.l2649
It supposedly works with low profile mini fuses, so I won't have to change my low profile with normal mini fuses. It should work correct? Now, it seems that I cannot find low profile mini-fuse lower than 7.5A. Can I use 7.5A with this and add it to either an empty fuse slot, or to an already used slot, together with the current fuse in that slot? |
#107 |
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Fuses are there to save the car's wiring, not the device. If you plug into a circuit of 7.5 A or more, the 7.5 A fuse is fine.
#108 |
So I picked up the Series 2 and am only planning on running it while i'm driving. I currently already have my Valentine wired to the cigarette lighter in the glove box. Does anyone know if I purchased a 2 into 1 adapter for the the cigarette lighter if I could run the camera and the radar without blowing any fuses?
Regards, |
#109 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | hayleybeaners (01-20-2013) |
#110 |
How do you change the date to current, dont see it in the settnigs
#111 | |
@b.e, thanks for the tip. Then I'l just buy 2 7.5A low profile mini-fuses and either use it in empty slots or together with other fuses (and put the bought 7.5A into the top bracket of add-a-circuit) Now, another question. Unfortunately I have slightly put the camera un-even. Is there any way to remove it, and re-attach it correctly? It looks like the camera is attached to the window real good, and I think the only way to remove it is to destroy the tape that keeps the camera in place. Any tips "if" it's possible to actually remove it without braking the bracket, or destroying the tape? |
#112 |
I mounted mine uneven as well. When I looked at the video it's evident, but barely so. A consequence of the wide-angle lens, I think. See if the video looks crooked before messing with it.
One of mine: [ame="http://www.youtube.com/watch?v=5Zga7TPfkes"]4x Fall Nebo Loop Run Scion FRS Dashcam - YouTube[/ame] |
| Tags |
| blackvue, dashcam, diy, dr400g-hd, power magic pro |
| Dash Cam Installation (BlackVue DR400G-HD) | DarrenDriven | DIY (Do-It-Yourself) Guides | 93 | 05-01-2018 10:54 PM |
| R-Magic & Rasty build 86 | toxicdrift | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 08-10-2012 01:24 AM |
| R Magic Parts List | quik1987 | Engine, Exhaust, Transmission | 9 | 07-30-2012 02:55 PM |
| R-Magic Demo Car (Exhaust video too!) | ttknf | Engine, Exhaust, Transmission | 5 | 06-06-2012 03:20 AM |
