Old 08-27-2013, 12:31 AM   #29
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
My single delete arrives Wednesday. Stoked! Will I be able to swap without a jack?
Old 08-27-2013, 01:42 AM   #30
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I did mine without one. Just unbolted the muffler and sprayed some wd40 on the bushings to get them to slide off. Might want someone to catch the other side when it comes loose so you don't drop it on your head. :P
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following User Says Thank You to SubiePig For This Useful Post:
BlueDubbinTDI (08-27-2013)
Old 10-16-2014, 12:36 AM   #31
Hotstuf1818
Elite Custom Lighting
Hotstuf1818's Avatar
Drives: 2014 Scion FR-S
Originally Posted by Hotlava86 View Post
i have a custom one off Berk track pipe on my car and love the heck out of it. the sound is awesome the price is awesome and the fitment of it is perfect!
enjoy sir
How did you get the burnt look on the berk? I didn't think they had that.
Hotstuf1818 is offline   Reply With Quote
Old 10-16-2014, 10:29 AM   #32
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I've got the Berk single exit delete and it's a great deal for the money, especially if you pick up a used one. The sound is much better, you drop about 22.5lbs in the rear, and I think single exit looks better. I bought mine as basically a temporary fix until I get an actual catback, since a catback is very far down my list of mods. The first day I installed it the sound was almost intolerably loud, but that is likely because it's the first car I've owned with a modded exhaust. After a couple of days it quieted down, and the sound is pretty nice now. It's actually a lot quieter than most catbacks I've heard. You also get some of those gurgles and pops at low RPMs and when decelerating, which I like a lot. There is some drone in the low to mid 2k range, but it's not too bad. I have an FT86 exhaust hole cover I'm going to install soon, but I accidentally dropped it on the concrete and need to repaint it now. haha
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-25-2014, 09:05 PM   #33
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
We like the berk dual tip and front pipe setups a lot!
Here's a sound clip here.
[ame="http://www.youtube.com/watch?v=VXrl6lUCGjU"]FR-S BERK DUAL TIP MUFFLER DELETE & CAT DELETE - YouTube[/ame]
Here was the performance figures from the Track pipe from DSPORT Magazine's exhaust shootout.
Corner3garage is offline   Reply With Quote
The Following User Says Thank You to Corner3garage For This Useful Post:
SuperTom (11-04-2018)
Old 10-21-2015, 11:49 PM   #34
Sharpest777
Drives: 2015 BRZ Premium
Berk Single Exit Muffler Delete With Before and After Video
I know this is an old thread and I am a noob. Just letting people know that these are still being installed and loved! I bought the Berk single exit delete and the FT86 SpeedFactory hole cover at the same time. The hole cover was actually more difficult to install and get it to line up properly but it wasn't too bad. Installing both took about 1 hour total.[ame="http://youtu.be/Wf_oKeHFkIA"]http://youtu.be/Wf_oKeHFkIA[/ame]
Sharpest777 is offline   Reply With Quote
Old 10-22-2015, 05:09 PM   #35
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
I have had the Berk dual exit for the past three months and I absolutely love it. The installation took about 30 minutes and was able to do it while the car was on the ground. The sound has somewhat quieted down now that there is some carbon build up in the MD. The only issue is that the MD seems to resonate at the 2-2.5 k rpm band. Other than that no issues. I am adding a tomei header system in the next month or so. I am praying that this will be pure eargasm and not too overwhelming.
Hook Em'
zkahle is offline   Reply With Quote
Old 10-23-2015, 01:38 AM   #36
Sharpest777
Reducing Cabin Drone After Muffler Delete
Did a custom spare tire delete using inexpensive foam rubber purchased at a flea market. Cut about 5 equal size squares and layered them on top of one another. Used the stock tire wing nut and washer to hold them in place and set the donut shaped insert on top. I also stuffed some of the foam into the openings in the rear sides of the trunk that lead into the area where there stock rear speakers are mounted. Placed a smaller section of foam closer to the back of the car just because it happened to fit well there. With everything in place the trunk mat is flush and can still support my guitar or amp if needed. The road noise and 2K - 2.5K cabin drone have both been reduced significantly.
2015 BRZ: Borla 11839, Modified Intake Tube, Sound Generator Mod, Drop In Filter, Perrin Lightweight Pulley, Mild Weight Reduction
Previous rides: 2013 Abarth, 2011 Hyundai Veloster, 2004 RSX-S, 2000 Celica, 1982 Camaro
Old 08-14-2016, 11:59 PM   #37
dattran86
Driver
Drives: 2013 Whiteout FRS
Hi i have a question about the nameless muffler delete, planning to do it to my car.
my is a daily, it is very loud?
dattran86 is offline   Reply With Quote
Old 07-04-2017, 01:44 AM   #38
Mchilese
Mchilese's Avatar
Drives: '14 BRZ Limited
Reviving a thread to rave for a minute.
I got a PLM muffler delete with dual tips and love it. It sounds pretty aggressive without being annoying. I sometimes leave from home pretty early in the morning, and the cold start isn't too bad.
I have access to a lift and that made it so easy. I had over 25k miles on the car so I needed to use liquid wrench and my breaker bar on the original bolts.
Spent less than $200 total and I am thrilled. I think it's a good buy at full price, but I was glad to find it at a good deal.
Just wanted to put my two cents in.
Sent from my Moto G (4) using Tapatalk
2014 BRZ
Mishimoto intake tube/TSW Nurburgring 18x8/Firestone Firehawk Indy500s/PLM muffler delete/JDL catted UEL headers
Mchilese is offline   Reply With Quote
before and after, berk technology
Muffler delete pipe = extreme temps at tailpipe?? twincamRob Engine, Exhaust, Transmission 39 07-02-2013 09:12 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 08:41 AM
Resonator delete? Sound with stock muffler? Nate219BRZ Engine, Exhaust, Transmission 23 09-05-2012 07:42 PM
Custom Muffler Delete w/ Videos! IceCreamMan Engine, Exhaust, Transmission 5 06-28-2012 08:12 PM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 11:30 AM
