86WORX
Old 10-03-2012, 02:11 PM   #197
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
The only reason I haven't gotten my RCE Yellows on yet is because I jumped in on the RS*R group buy. Also a bit unsure about whether I want to bother with the Com-Cs in case I experience the clunking issues others have had although mine look to be perfect 'out of the box'.
To be honest I'm not completely convinced that I've gone the right route with the RS*Rs since the reviews of the Yellows are so good and the price is dead on.
Also appreciate RCE throwing in OEM camber bolts with my order. Top notch vendor. I love stuff like that..
Half tempted to put them on and compare the benefits of the Yellows versus the RS*Rs. If I had my own garage I'd have put them on myself by now but as a layman I need to pay for the labour so yeah...
Anyhow this looks like it's proving to be a great bang for the buck setup for folks, as expected. I'm already recommending them to other 86 owners in Dubai.
Nice job RCE!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 10-03-2012, 02:22 PM   #198
RYU
RYU's Avatar
Drives: really slow...
^^^ Great bang for the buck indeed with the RCE yellows. HOWEVER, even though they did a great job matching springs to the OEM damper... you're still limited to the capabilities of the OEM damper. It's a good damper compared to the other OEM dampers out there but it's no comparison to what a good set of coilovers can do like JRZs, DG-5s (if they ever come out with a set), and perhaps your RS*Rs (though no experience with them). I'm very happy with my RCE Yellows but i'm also realistic and have experienced owning a proper set of coilovers. Bilstein and Koni should come up with interesting strut replacements for someone not looking into expensive coilovers.
I just hope my OEM dampers hold up for a while with the Yellows so I can save up for JRZs!
RYU is offline   Reply With Quote
Old 10-03-2012, 02:43 PM   #199
gmookher
Originally Posted by Racecomp Engineering View Post
Yeah you have a point about offset hard rubber mounts etc. Thats a tall order to fill for sure.
In a week I am installing Racecomp Lowering Camber plates on stock shocks with RCE Yellows for street testing. No one hates NVH from camber plates more than me so this is to determine their streetability.
Just a related yet off topic update.
Myles
Chief RCE slacker.
Its been a week
hows your test?
gmookher is offline   Reply With Quote
Old 10-04-2012, 02:05 AM   #200
Originally Posted by gmookher View Post
Its been a week
hows your test?
Dont knowYet . Installed GD chassis STI group-n front mounts to our prototype T2's and a range of spring rates for compliance testing with AVO front control arm bushing/caster bushings. WOW WOW WOW, but thats another post for another thread.
Give me some time to the feedback of the RCE plates to you guys. Our plan is to make a lowering version and have good stock.
Myles
Racecomp Engineering is online now   Reply With Quote
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
gmookher (10-09-2012)
Old 10-09-2012, 07:47 AM   #201
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
For anyone who experienced problems with spring popping noises while turning the wheel more than 30-40 degrees in either direction after installing the Whiteline Com-C strut tops, I can confirm that it was due to a bad batch of Com-Cs. It's very easy to quickly determine if your Com-Cs are part of the bad batch; continue reading to find out how:
Jan from Whiteline sent me replacements a couple weeks ago, and I was finally able to install them last night. The install was pushed back due to needing to wait to get my Subaru wheel locks key in the mail after losing my original key plus packaging (I had to email the manufacturer a picture of my specific lock pattern, as the lost packaging was the only way for me to know which key I needed).
The issue with the original Com-Cs was notchy bearings, as ATL BRZ mentioned in his post here.
For those who have the Com-Cs but have not yet installed them, do this quick check first before installing them: Looking at the underside of the Com-Cs (reference the image below that I stole from ultra's post, the bottom view is on the right), insert your fingertip right into the middle hole of the bearing, and twist your finger as far as you can to the left and then back to the right. It should move smoothly with absolutely no noticeable notchiness or catches. If it moves easily but you feel any notches (mine were not audible, but you can definitely feel them), hold off on the install and contact Whiteline. The link from ATL BRZ that I mentioned above has comparison videos of his defective notchy Com-Cs versus the OEM strut tops; the Com-Cs bearings should feel identically "buttery smooth" as the OEMs.
For those in the US, my contact was Jan.
Smudgeous is offline   Reply With Quote
The Following 4 Users Say Thank You to Smudgeous For This Useful Post:
F1point4 (10-09-2012), jkamelo (01-05-2021), Nardi330 (10-09-2012), whataboutbob (10-21-2012)
Old 10-09-2012, 10:51 AM   #202
gmookher
where can I buy a set of the good ones?
Old 10-09-2012, 11:21 AM   #203
Smudgeous
Smudgeous's Avatar
I wouldn't assume they're bad at any one vendor. My guess is that there was a bad batch that was produced that trickled down to multiple vendors. I personally didn't order through RCE and still got defective ones.
However, if you check before you install, you're either good to go, or need to contact Whiteline. When I did, I had replacement parts in roughly a week and a half after first calling and mentioning the problem. Annoying, yes, but I definitely feel they're worth the extra wait.
Old 10-09-2012, 11:34 AM   #204
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
That's a great question, I've begun the suspension building myself.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-09-2012, 11:53 AM   #205
cnk
Drives: '13 DGM BRZ Limited
Or, you could call up the vendor and have them verify for you by doing the test before shipping it out to you. Although, if the vendor hasn't read this thread, you're going to have to try real hard to explain that you're not some kind of sicko.
Just imagine the phone call:
you: Hey. . .do you have the Whiteline Com-C strut tops?
vendor: Yes, we do.
you: Can you stick your finger in the bottom and twist it and tell me if it's smooth or notchy?
vendor: *phone click*
cnk is offline   Reply With Quote
The Following 2 Users Say Thank You to cnk For This Useful Post:
meWant (10-09-2012), Smudgeous (10-10-2012)
Old 10-18-2012, 04:41 PM   #206
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Those with Whiteline Com-C's and OEM Struts with RCE Yellows and no noise, bearing, or deflecting rubber issues:
Did you use a conical washer (like this) inbetween the top mount and the upper spring perch?
If so, was one included in the packaging or where did you get one?
I'm tempted to get a couple of these and test fit them with OEM dampers on top of welded washer on the upper spring perch and see if this new set of Com-C's will play nice and stay quiet and not bind up. Is that a bad idea? Will I run short on threads with the upper mounting nut?
The welded washer on the OEM upper spring perches are NOT conical
Old 10-18-2012, 09:10 PM   #207
Smudgeous
Smudgeous's Avatar
Bad news on the Com-C front.
My new and smoothly-rotating Com-Cs have now also begun to make noises. If I get some free time this weekend, I'm going to just put the stock strut tops back on and see if the notchiness was caused by the car due to them not fitting properly. I'm obviously far from pleased about this latest development -.-
Old 10-19-2012, 11:10 AM   #208
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Bump
Old 10-19-2012, 11:18 AM   #209
OrbitalEllipses
Drives: Attitude
Those of you using Com-C strut tops: if you want a harder durometer strup top (though without geometry changes) you can use the GD Impreza "Group-N" strut tops.
gmookher (10-19-2012)
Old 10-20-2012, 09:38 PM   #210
yep and they work well up to at least 500 lb springs,esp on this 26_ _ lb car. I am using them now with coilovers and they keep compliance and NVH to a minimum without much flex at all.
Myles
Search this Thread:
Advanced Search
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 05:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 04:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 09:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 03:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 03:08 PM
