#43 |
Drives: FRS :D
#44 |
Drives: '06 AM V8V Coupe
@Want.FR-S it's not that simple. The Tesla is almost certainly electronically limited in torque because the tires will slip if you give it any more torque. The motor's true maximum output is when you extend the downsloping curve all the way up. Theoretically you can have infinite torque at 0 rpm, but there are obvious reasons why you can't really do that. An electric motor's torque to speed is ideally an inverse relationship, not considering friction and resistance.
Where a superconductor comes in is it gives a enormous increase in power density, because the wires now do not dissipate heat and can be made extraordinarily thin. In addition, they can handle much more current, which means that maximum torque level can be sustained for even more RPM. |
#45 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
It's nice to see a friendly conversation about auto's. Like you Madfast, I would want the auto only if it lived up to yours and my expectations. My RSX auto is garbage!!!
#46 |
Drives: Lexus IS-F
DSG > conventional automatic any day of the week, except sat night at the drags lol!
#47 | |
Kuruma Otaku
Have you compared driving your RSX to a 6 speed manual Type-S? I would bet night and day difference. Torque converter automatics are heavier, sap a lot more power from getting to the wheels, and have a bit of 'lag' when they aren't locked (which is often as they try to shift smoothly). All this is much more apparent in smaller cars and smaller displacement motors, and why I personally hate autos. This one will probably be better than yours, has an extra gear, but still shares the basic limitations. There may be some aftermarket ECU work-around later, like what Lotus did to the Evora's Camry trans. Was your 350Z auto as well?
Because titanium. |
#48 |
GL 86!
Drives: Maybe FR-S... maybe not
Yes, the mystery is unfolding now Dimman... However nothing is going to sway the fact that neither of the K20 engines in the RSX has enough torque down low for SUB-FT86 regardless of transmission type.
#49 | |
Kuruma Otaku
Because titanium. |
#50 |
4G63 & Rotary
#51 |
Praise Helix!
#52 |
Kuruma Otaku
Donuts my friend, donuts.
Because titanium. |
#53 |
Site Moderator
Drives: Stuff
I just can't believe there are people that want a sports car with an automatic. Makes me kinda sick. They might as well isolate the hell out of the car too, what's the point of letting the driver experience any part of driving the car...
I'm old(ish?) and still hate automatics, and always will, no matter how good and fancy they are.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#54 | |
Site Moderator
Drives: ichi 86 Project
#55 | |||
Drives: 4 Wheels Auto
True, superconductor (if can be done in room or high temperature) possess those benefits and reduce energy loss. But the fact is, with electric engine and their ability to generate torque at low rpm, there is really no need to have a gear box, and not even a complicate mechanical->electrical->electrical->mechanical drive-train. Of course if we can exchange all the wires with superconductors we can make the electric energy transfer with less loss. But that is not the point here. Why would you use superconductor in this energy sucking mechanical->electrical->mechanical transmission? One note though: do you know why Tesla motor cannot maintain that torque in higher rpm? Was that current limited or other factors? So even with a superconductor that can drives way over 600 amps to the motor, you should still need to limit the power band to a certain degree. Why? because you do not have infinite energy stored in the battery. If you increase the current too much, you can drain the battery with little time, and you know that right? And lastly, for my P.S.2 point in the previous post, I just realize that the power train of GM's volts is just like your idea: using an ICE to run generator to generate electricity and then power an electric motor to move the car.
#56 |
So it's like this, when the motor is at 0 rpm, and you feed the coil voltage, there is the inductance of the coil (which is quickly "overcome") and the resistance. So the maximum torque of the motor is related to whatever the maximum amperage the coils can handle. As it gets moving along the rotor is rotating in the same direction as the current (in some sense) and creates a back emf so the max current drops.
A superconductor removes the motor's power limitation, but telling a battery to supply that energy is, precisely as you say, going to drain the battery too fast. Not only that, batteries have a maximum current supply issue that cannot be overcome without adding more batteries. Batteries have crap energy density (which theoretically can increase a few times, but we won't be seeing that for a while), and afaik the issue of degradation still has not been tackled. A gasoline motor can have very high specific output and very reasonable efficiency, but being tied to a finite number of gears definitely hurts its prospects. In order to create an excess of torque for a significant speed range like the tesla has, you need quite a bit of displacement/etc., and keeping that kind of engine fuel efficient and reasonable for daily use is much more difficult. Given that the Tesla's motor weighs a ridiculously low 70 pounds or something, I think a fully electric drivetrain coupled to a high rev motor can have similar weight and give you a faster car in the end (with much much better fuel economy). The main thing standing in the way is the size of the generator; if we gear it so that the engine spins at 1/3 the speed of the generator, so we can use a smaller one, there are more losses. So this is just a pipe dream waiting on stuff in the future
| BBQ @ Forged Performance Sunday July 31st | EVAN&MONICA | Northwest | 10 | 08-23-2011 04:04 PM |
| New info on Toyota 'Gs' performance division in the works | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-09-2010 03:44 AM |
| FT-86 Article on Performance magazine | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-09-2010 12:33 PM |
