Old 08-29-2012, 01:31 AM   #29
megatron
It's over prime!
megatron's Avatar
Drives: Scion FR-S
i'm glad you and your family are ok...
not sure what insurance company you have,but if they increase the $ you have to pay them,i would have to question the whole insurance scheme all together..
how in gods name would you have to pay more when you take into consideration the situation you went through?
would never happen with my insurance company.. but now i need to wonder if you are not exaggerating what could be/have been an outcome of a situation with your insurance company..
megatron is offline   Reply With Quote
The Following User Says Thank You to megatron For This Useful Post:
Texas BRZ (08-29-2012)
Old 08-29-2012, 02:02 AM   #30
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Not to be a downer, but it's not completely true. There is a chance this will affect your record.
I work at a bodyshop and you'd be surprise what counts and doesn't count. Usually vandalism and hit and runs don't count.
But since it wasn't a hit and run, that's a different story. This accident won't go on Carfax or affect your insurance as long as you don't report it so. If you call them, then it's a toss up. Some insurance companies will say your vehicle was involved and that's enough for them.
My car was parked and hit by two other cars that collided. This raised my premium and made it hard to shop around. It didn't affect my Carfax though oddly since it was repaired.. I finally found an insurance company that doesn't get affected as long as I wasn't at fault.
Stick with a big name company and you should be fine. Shouldn't affect your VIN at all since no repairs were done.
sbxjap is offline   Reply With Quote
The Following User Says Thank You to sbxjap For This Useful Post:
Old 08-29-2012, 09:58 AM   #31
Texas BRZ
Sports Car = Anti-Drug
Texas BRZ's Avatar
Drives: 2014 Honda CBR600RR
Yes, I am exaggerating thus far, since I really don't know the outcome yet, and I'm only assuming as of now. I still have to check with the agency today, but I will update with what their say is on my situation.
You're not being a downer. I knew that it would be likely that this would be on my driving record ever since the officer was inputing my Driver's License info into his system. I had a chance to let him know that I wasn't really involved, and I feel he would've left me out of it... Especially since the second officer was understanding of my dilemma. Yet at the end, I wasn't smart enough to make a positive decision... And I was being too passive and thoroughly honest with the detail of how my car was involved.
I'm with a pretty reliable and big-name insurance company, and they've been reasonable to work with from the time I even first started using them.
"Did you know that this car comes with 300 horsepower in its stock form? 200 from the engine, 50 in its chassis, and the final 50 within the driver who can make the most of it."
Texas BRZ
Texas BRZ is offline   Reply With Quote
Old 08-29-2012, 10:57 AM   #32
Zaggeron
Zaggeron's Avatar
Drives: '13 BRZ Limited '10 370ZR
Originally Posted by Sall View Post
first good to hear your daughter,you and the frs are okay.excuse my ignorance but why does this affects your insurance rates and driving record if it wasnt your fault ?
In general insurance rates are based on statistics. Statistically speaking if you've been in an accident, even if it is not your fault, the numbers say you are a higher risk and hence higher premiums.
It shouldn't affect your rates at your current insurance company, but if you decide to change providers, it may show up as an incident on your record and you'll have to check "yes" to the question of whether you have been involved in an accident in the last N years.
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT
Zaggeron is offline   Reply With Quote
The Following User Says Thank You to Zaggeron For This Useful Post:
Old 08-29-2012, 11:08 AM   #33
jstans84
Drives: Scion FR-S
Glad to hear everyone was okay! Also like basically everyone else said, unless you have some cut-rate agency you shouldn't see any negative repercussions from your insurance agency due to this. If you do simply inform them that you will be reporting it to the Better Business Bureau. That typically helps to change their minds and if it doesn't well report it and get a new agency.
As far as the HPDE events go that's good to hear they are paying off. I've found that I'm a lot more wary of my surroundings while driving ever since I started riding my motorcycle. I constantly am checking my mirrors to make sure no one is going to run me over.
jstans84 is offline   Reply With Quote
The Following User Says Thank You to jstans84 For This Useful Post:
Old 08-29-2012, 02:01 PM   #34
JTM
Drives: 2013 FRS-6MT Argento
First off, I'm glad your daughter was able to sleep right through the event.
A couple of things for you:
-Your rate would only go up in you were deemed at fault.
-Your insurance rate is calculated to cover a certain number of not-at-fault accidents per 10year cycle. (unless you are with some cut-rate company as jstans pointed out, Fred Lloya is main one that comes to mind)
-The officer listed you as invovled incase there was damage that you didn't see immediately, the 5mph crash foam behind many rear bumpers is a good example. I'd take it to Toyota and have them inspect it at the VW expense.
Originally Posted by Synack View Post
I do have to ask, what city are you in? Texas drivers ARE THE WORST!!
Houston drivers are the worst!
I strongly disagree, although I will state that the worst drivers in Texas are either illegal, haven't figured how to put their iPhone down, or live in the DFW area.
Originally Posted by DaJoian View Post
IF you do claim this as an accident through your insurance corporation, it will be titled as a damaged vehicle. IF you DO NOT claim any damages, they will never even mention it. At least, that's how it is here in B.C.
Glad to hear that you, your daughter, and your car is alright!
Cheers! :happy0180:
Thankfully this is Texas and not Canada, our vehicles only get titled as Damaged (Actually it is Salvage) if the vehicle is declare totalled by the insurance company. :happy0180:
JTM is offline   Reply With Quote
The Following User Says Thank You to JTM For This Useful Post:
Old 08-29-2012, 02:17 PM   #35
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by Texas FR-S View Post
Okay... That's good to know.
What do you think about a CARFAX / vehicle history report on my car?
Would it be recorded with the VIN since no damage or repair is there?
I did not know the answer to this, but DaJoian already answered it. And I learned that too now.
Cheers! :happy0180:
Sigh-on-Rice is offline   Reply With Quote
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Old 08-29-2012, 02:28 PM   #36
Texas BRZ
Texas BRZ's Avatar
Okay... I called my local insurance agency which my family and I have been clients of for several years. I was upfront and told one the representatives about all this, and she told me that it will likely go on my driving record. She also said that it will not affect me in any way if I do not file a claim with either their insurance or my own insurance in order to complete any repairs. Going back to being recorded on my driving record: It will not raise my insurance costs, nor will it affect me negatively simply because I was not at fault, and it will show on my record that I was indeed not at fault.
Thank you all for all of your inputs... Nothing really to be bothered about as some of you mentioned already.
And life goes on... :happy0180:
*EDIT*
jstans84 - I can relate with you... And you're right, HPDE has become a essential safety asset for me... Average folks may not understand, but there's a reason why I've been spending $300 a month for a long while now.
JTM - Thank you for sharing that important / helpful information.
Texas BRZ
Anyone find a child seat that fits? ashtray Cosmetic Modification (Interior/Exterior/Lighting) 97 04-15-2017 08:29 PM
The Subaru/Toyota/Scion Love Child: BRZ/GT86/FRS - What does it mean? Mr86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 12-06-2011 04:14 PM
"Car geek" credited with finding child killer. 1660 Off-Topic Lounge [WARNING: NO POLITICS] 3 08-04-2011 05:11 AM
How much do you have saved up for the FT-86? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 59 03-19-2011 06:37 PM
