Old 08-30-2012, 08:39 PM   #57
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Originally Posted by daiheadjai View Post
Isn't this a fail-safe installed in the wake of the mythical Sudden Unintended Acceleration "problem" that the U.S. gov't found with Toyotas?
I believe someone mentioned that before...
Nope its clearly a troll on Toyota/Subaru's part to piss off drag racers using auto trannies.
Old 08-30-2012, 08:39 PM   #58
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
^ that is exactly why they do this on newer cars.
Originally Posted by sho220 View Post
Tell that to these "ladies"...
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 08-30-2012, 08:50 PM   #59
Sasquachulator
Pavement Grey
Originally Posted by K2wings View Post
Did you actually know that it's not an AT, its a semi-manual. You can shift like a manual, it's the same. Actually, it's better, since you can't miss your gear like in MT.
It's an automatic like in a minivan, or any other car with an automatic transmission that isnt a DSG/SMG/dual clutch system.
It's just set up in a different way than those automatics.
And it all came from the Lexus ISF.
The ISF came out amidst some criticism that it was getting an 8 speed automatic transmission to take on the germans with their dual clutch boxes. And the fear was because its an automatic, its automatically gonna suck when it comes to shifting via paddles or +/- on the shifter (because up until the ISF all paddle shifted automatics have been pretty much garbage in the shifting response/time/feel department)
But Lexus did something clever, it locked up the torque converter in 2nd to 8th gear so that gear changes dont have that delay that all other autos have (or whatever technical mumbo jumbo this involves). this allows the transmission to work very similar to a dual clutch system without being a dual clutch system. i think one drawback to this system is that you still get the typical automatic transmission parasitic drivetrain power loss that is higher than in a clutch based transmission.
they adapted this system into the FRS/BRZ transmission so it functions the same way. Note it is NOT the 8speed lexus transmission with 2 gears lopped off.
Old 09-01-2012, 12:51 AM   #60
LSxJunkie
Douchebag
LSxJunkie's Avatar
Drives: 2014 Mustang GT
Originally Posted by zooki View Post
I don't think you are going to be able to change the stall speed of the torque converter through a tune. The transmission isn't a "semi automatic" because it still has a torque converter in front of it. The converter is a lockup converter, but still a converter. You really wouldn't want to lock up the converter anyway as you would lose the torque multiplication that the converter supplies. This is what lets an automatic get away with less gear in the rearend, but still achieve decent acceleration. You would have to change it out to a higher stall speed converter, and I don't think anyone is making one yet.
Oh look, someone who actually understands how a torque converter works.
I don't know how much of a market there would be for a bigger stall. The car would drive like shit around town and the unit would either have to be engineered to lock up like the stocker or it'll just drive like dogshit all the time. I've driven a couple stalled 4L65 and 4L80 cars. They were fun as hell.....because they were 450+hp muscle cars. I think it'd just make this car feel slower and sloppy.
I've driven an IS-F around Monticello. What that transmission does is lock the torque converter when you are in 2nd through 8th, but it unlocks it to blip the throttle between gears. It actually doesn't do this perfectly either. On a few softer laps, I wasn't braking aggressively for the downshifts I was asking for. Even though the TC was unlocked it was still putting power through to the transmission (when unlocked, a TC can actually put more power to the trans) and the car was actually jerking forward a bit with each downshift as I braked for corners.
Also, planetary automatics use more power to turn than standard manual transmissions. I don't know what the drivetrain loss is through a DSG/DCT/DKG.
Here - 2014 Mustang GT Track Package/Recaros - Koni Yellows, Boss 302 Springs, BMR SB041 Front Sway Bar, Boss 302 Rear Sway Bar, Boss 302 Wheels, GT500 Quad Tip Axleback, 2016 Legacy 2.5i Limited
Gone - 2010 RX350, 2006 GTO (2nd), 2007 RX350, 2008 IS250AWD, 2006 GTO, 2004 G35 6MT, 1992 SC400
LSxJunkie is offline   Reply With Quote
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
Problem with Toyotapartsoutlet.com BRZranger User/Vendor/Sponsor Reviews, Feedback, Comments 11 08-09-2012 02:20 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 05:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 11:17 AM
