| View Poll Results: Are you experiencing the same problem? | |||
| Yes - I have an aftermarket intake only. |
14 | 9.21% |
| Yes - I have an aftermarket intake and a tune. |
15 | 9.87% |
| Yes - I'm all stock. |
11 | 7.24% |
| No - I have an aftermarket intake only. |
43 | 28.29% |
| No - I have an aftermarket intake and a tune. |
3 | 1.97% |
| No - I'm all stock. |
66 | 43.42% |
| Voters: 152. You may not vote on this poll | |||
#15 | |
#16 | |
Drives: Scion FR-S | 6MT | Ultramarine
#17 |
The install is really easy and I wouldn't worry about it. If you don't mind, please install it, do the test as specified, and report back. Worse case scenario, you just reinstall the stock intake. Best case scenario, your intake works fine. I can do a swap in about 10 minutes now. It's not that bad.
#18 |
Drives: 2018 Golf R
Thanks for starting this thread. I feel bad for bombarding Airaids thread with this, but I didn't like that posts were being deleted.
As I posted in that thread, I have this issue. My mods: -Airaid intake, sound tube and snorkel deleted -Perrin crank pully -Visconti Stage 1 tune I run 93 octane fuel with ~10% ethanol in it (unfortunately). I dont need to go WOT for it to bog either. I gave it just a bit more then 50% throttle yesterday at 2k rpms in first and the engine fell flat on its face. I've noticed that throttle response below 4k rpms is lacking as well. Starting off in first gear takes more throttle then it used to. I, too, plan on sending @Visconti a log.
Parting out HERE
#19 |
Drives: 2009 135i
the problem isn't your intake, its the tune! the tune is not set up for the intake... I would talk to your tuner and see if they can create a custom map for you
#20 | |
Drives: 2006 Subaru Liberty EZ30 S/charged
Tune or not
It says above (read all the posts) that the condition exists on stock and non stock tunes.
Toyota 86 test driver
| The Following 3 Users Say Thank You to Tradewind For This Useful Post: |
#21 |
That guy
Drives: Ultramarine mt FR-S
| The Following 2 Users Say Thank You to Hawaiian For This Useful Post: | 2forme (09-04-2012), civicdrivr (08-26-2012) |
#22 | |
Drives: 2009 135i
Exactly!! The stock tune AND the Stage 1 tunes that are floating around are not properly setup to handle these intakes. I even remember perrin addressing this in one of their threads, stating that their intake will require a tune if used... |
| The Following User Says Thank You to bimmerboy For This Useful Post: | 2forme (09-04-2012) |
#23 |
Drives: FR-S MT & FJ Cruiser
I'd be a bit peeved if I dropped the cash for one of these intakes and was then told I'd need a tune to have it work properly...
#25 | |
Drives: 2011 Civic Si
With the straightener it allows the air to do just that..straighten out for the MAF sensor. This was a big issue for the 6th gen Civic Si's. When Injen, and AEM released their CAI for the cars, people were bogging down, and throwing CEL because the MAF wasn't detecting the air right. It could be resolved by flashing with a tune, and switching to MAP. But most people didn't want to have to do that. I know that AEM released a 2nd version with "veins" around the MAF sensor which resolved the CEL issue and any bogging down without needing a tune. With that said, I'm not sure how our ECUs work, and I don't know if we can switch to MAP or not. But it sounds like the intake companies need to install veins into the intakes for our cars. |
#26 |
I thought the reason or at least one of the reason for the velocity stack was to straighten out the air.
Is the MAF now located before the velocity stack? I wonder if the intake manufacturers are now going to provide some sort of add -on kit. Now that there are some postings on the mass air flow, given the STOCK/NO PROBLEM scenario, how is it suppose to look? |
#27 | |
That guy
Here's a link for you. http://www.ft86club.com/forums/showt...=perrin+intake "What we have learned is we will be offering two intakes. One that runs very close to the stock MAF curve, this will suite the more common customer that doesn't need or want a tune, but would rather get some really cool sounds along with a bit of HP. The other intake will require an ECU retune, and is designed for the customer who wants the maximum HP from his car." Can people please use a search function before claiming to know things? Last edited by Hawaiian; 08-26-2012 at 05:07 AM. |
#28 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I had that jerk coming from the engine as soon as i installed the injen short ram.
I disconnected the MAF Sensor and started back up the engine. Then Reconnected the MAF Sensor and started back up the car. And after i ran the car for 4 mins under 2000rpm so the ECU could Accept the new intake and not jerk anymore. I restarted the car 4 times and ran it and the check engine light came out, and the car stopped jerking and ran way better. |
| Tags |
| engine bogging, hesitation, intake, jerking motion |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 01:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 09:06 PM |
| aftermarket rubber intake tubing??? | 20valvewynn83 | Southern California | 39 | 09-14-2012 12:12 AM |
| Can anyone read Dutch? | Buggy51 | BRZ First-Gen (2012+) -- General Topics | 14 | 12-28-2011 10:48 PM |
| Toyota READ THIS | Mr.Jay | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 12-09-2011 01:13 AM |
