Old 08-10-2013, 03:34 PM   #141
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Right when i was looking forward to one of these.
It does suck, but I am still very pleased with this exhaust and a replacement gasket isn't gonna cost much at all
ahaghshenas is offline   Reply With Quote
Old 08-20-2013, 05:41 AM   #142
ahaghshenas
Drives: Subaru BRZ
More bad news regarding gaskets, seems both gaskets for the overpipe have failed.
I have replaced one to find out the other one between the headers and overpipe is leaking too!!
The quality of the supplied gaskets in my opinion are not the best, considering I installed my exhaust just over 3 months ago and I am not happy with the price I paid for a replacement.
Looking into high quality gaskets, If anyone has suggestions?
Old 08-20-2013, 08:36 PM   #143
Anaxilus
Drives: They have four wheels
Anyone else see the Titanium tips at 86fest for the Milltek? Like the idea but the execution was off. The roll on the slant cut was poor as was the 'burn' to get the color on the edges. I hope it was a prototype because the idea is nice.
Anaxilus is offline   Reply With Quote
Old 08-20-2013, 08:46 PM   #144
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by ahaghshenas View Post
Got an exhaust leak between the overpipe and secondary Catalyst Bypass Pipe.
Any owners of the Milltek exhaust remember if they were supplied gaskets for this exhaust?
Sounds awful, need to get some new gaskets any suggestions on where I can get new ones that would fit?
I don't have this exhaust but try calling your vendor and tell them you need new gaskets. Or auto parts stores such as NAPA or Kragen should carry various sized gaskets that could be made to fit any auto exhaust system. Or you could try OEM Subaru gaskets. Also make sure you torque everything down to spec (hopefully they provided you with specs or if you're able to reuse OEM bolts, use the OEM torque specs) and apply this to both sides of your new gaskets: http://www.permatex.com/products/product-categories/gasketing/gasket-sealants/permatex-copper-spray-a-gasket-hi-temp-sealant-detail.
I felt a tiny leak in my GReddy SP Elite exhaust flange and in my buddy's. I applied Permatex copper gasket sealant liberally to both sides of our newly replaced gaskets and replaced GReddy's cheapo supplied bolts (I stripped 3 of the 4 bolts between both our exhausts because they couldn't withstand OEM torque specs) with stock bolts. Was able to fix both our leaks; now our cars respond and sound slightly better.
Old 09-11-2013, 09:30 PM   #145
BRZgirl
BRZgirl's Avatar
Drives: Subaru BRZ Silver Limited AT
Love the titanium tips for the Milltek, I might get that to replace my original stainless steel milltek tips. Not sure why you say the execution is off because Milltek uses two sheet smooth weld that has a more flattened sleeker look. It is not rolled because in order to have a more aggressive slant which Milltek has achieved and other's can't, it must use a different welding process. I like the color as it is a gradient shade of gradual color and not solid burnt blue. Then again, it's all personal preference.
BRZgirl Subaru BRZ Silver Limited AT
Pages:BRZ & FR-S Girls
Current Builds: Mann Stainless Steel Brake Lines, OEM Audio+, Speedline & Mann Engineering Type-25 Coilovers
Tune by:
Mann That's Delicious Future Builds: Brembo 4-Piston BBK
BRZgirl is offline   Reply With Quote
Old 09-11-2013, 09:51 PM   #146
BRZgirl
BRZgirl's Avatar
Did you or the installer heat cycle the system after installation? I know mine went through a heat cycle after installation where all the bolts were retightened after the exhaust was heated up to temperature and then cooled down. After you get your new gaskets, do a heat cycle. I've had my system over 3 months and have no problems at all. Good luck!
Tune by:
Old 09-11-2013, 10:33 PM   #147
Anaxilus
I don't think you understand my post. I said nothing about having a problem w/ slant cuts or titanium finishes. Did you see the actual piece at the 86Fest? There were blisters from the heating on the welded edges that damaged the finish and splotched the hues, not smooth and uniform like other titanium tips. This was surprising since their stuff seems to be well executed most of the time. But it's enough to make me wonder what surprise would be awaiting me inside the box once I got it. When I see something like that being displayed as a demo for a show or exhibit it makes me wonder.
Unless you think bad craftsmanship is a matter of 'personal preference', you're missing my point. Until I see a pic of a better unit, I'll trust my own eyes that the piece I saw indicates the product I would receive.
Here's a pic of their matte finish. This is the quality I'm talking about, or lack off. This is NOT expert craftsmanship or treatment on the finish, and not something I would pay for to put on my car. The actual polished tip on display w/ the bluing was worse than even this if you look straight on at the edges (which they hide in the pic). I'll agree that the gradual powder bluing is nice though. Personal preference? Ok. Versus Greddy and Tomei below...
(Other's can't replicate the Milltek slant? Come on.....)
Old 09-13-2013, 01:57 AM   #148
mush
mush's Avatar
i got the milltek catback non resonated about a month ago... either im going deaf or the exhaust is getting quieter
im not complaining tho lol
The Following User Says Thank You to mush For This Useful Post:
BRZgirl (10-07-2013)
Old 09-13-2013, 02:00 AM   #149
mfbmike
Drives: 2013 FRS, 2008 R32
I ran a full milltek exhaust system on my previous car, a 2008 VW R32 and absolutely loved it. Headers, downpipes, test pipe, the whole 9. I can post a clip of that if anyone cares. The clamps the exhaust came with weren't the best and had to be replaced to fix an exhaust leak but otherwise, awesome exhaust system.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Old 09-13-2013, 02:32 AM   #150
mush
mush's Avatar
post it
Old 09-13-2013, 02:34 AM   #151
mfbmike
post it
Ask and you shall receive.
[ame="http://www.youtube.com/watch?v=Qt83sxBQA18&feature=player_embedded"]MVI 2232 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=YiNIi5GTPfQ&feature=player_embedded"]Mike's spark cut - YouTube[/ame]
The second video was after I added a spark cut addition to my tune. Fireballs and gunshots.
That car was good times. lol.
The Following 2 Users Say Thank You to mfbmike For This Useful Post:
BRZgirl (10-07-2013), mush (09-13-2013)
Old 10-07-2013, 09:41 PM   #152
BRZgirl
BRZgirl's Avatar
I understand your point, however you are comparing apples to oranges. The design and manufacturing process of the Milltek involves "TWO Sheets" of high quality titanium. The Greddy uses ROLLED sheets thus the thicker tip edges. You also can't justify how much percentage titanium is within the alloy combination because titanium will break if you try to roll it to the angle close to the Milltek degree. The Tomei exhaust below is ONE sheet of titanium with flat tip, thus you will not find any welding edges and cannot be used to compare at all.
Tune by:
Old 10-07-2013, 09:45 PM   #153
BRZgirl
BRZgirl's Avatar
Where did you get yours from? I like the low growl of my resonated, sometimes, you just get used to it and it becomes background music.
Tune by:
Old 10-08-2013, 02:35 AM   #154
Anaxilus
I buy most of that explanation, except for the slant cut Greddy tip you seemed to have missed. Believe me, if the finish was as well crafted as the GReddy tip, I'd be all over the Milltek w/o a second thought. As it is, the less than perfect welding seems to coincide w/ the bubble blisters ghosted in the heat treated finish on the edges and some stories about leaking gaskets. I think it's a great product but some people like myself would like to see a little more attention to detail at a certain price point. I don't have a problem with the process, I have a problem w/ the semi-DIY finish/craftsmanship which is more than evident on the Ti tips on inspection.
The Following User Says Thank You to Anaxilus For This Useful Post:
BRZgirl (10-08-2013)
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Dynosty Presents MXP Exhaust System for FR-S/BRZ Dustin@Dynosty Engine, Exhaust, Bolt-Ons 12 11-08-2012 10:15 AM
Subaru BRZ Arrives At Milltek Sport HQ For Development vividracing Engine, Exhaust, Transmission 13 08-13-2012 09:53 PM
What is the best exhaust system for the FT86 LOTUS86 Engine, Exhaust, Transmission 4 07-31-2012 03:36 AM
TRD Exhaust System... Griffdawg Engine, Exhaust, Transmission 2 07-18-2012 01:27 AM
