#911 | |
Volunteer Fire and Rescue
Drives: Ambulance... sideways.
Best of luck during your negotiations, I hope you get what you want, and for better or worse, you wont have another car like the 8-6.
It's more fun to drive a slow car fast, than a fast car slow.
| The Following User Says Thank You to Grishbok For This Useful Post: | gmookher (09-29-2012) |
#912 | |
Drives: 2013 Raven Fr-s
#913 | |
How many miles are on your engine? At around 3-5k miles, the engine starts becoming a lot more responsive and sharp. I think you may be referring to a bit of lag or delay as a result of the engine components being brand spanking new. On any new car, there is a definite delay in response until the engine settles in. It takes a few thousand miles for everything to settle in and to really start delivering.
#914 |
Drives: t
I wonder why scion has a reflash avail and subaru wants to change the ecu..
#915 |
Mr. Know It All
Drives: 2013 FR-S Asphalt
So I started a list of complaints for my Rep when I speak to him on Monday;
- A/C smells bad when I turn it on. - The erratic idle and clunky timing chain slapping sound when the idle drops. - Engine ticking (I have to listen to this a little closer, it may be the injectors...will check when I get home from work today) - Was told they put 50 miles on the car, but they actually put 100 miles on the car. I dropped it off with 905 miles and got it back with 1004 miles (yes technically that is 99 miles). I wouldn't really care about this except I dropped the car off with a near full tank of gas and got it back with less than a 1/4 tank, but I was expected to return the rental with the same level of gas. They owe me a tank of gas. All of this may cause me to reconsider my compensation needs.
2013 FR-S Asphalt MT (55w HID's)
1985 Celica Supra 1JZ (Stupid Fast) Last edited by pituala; 09-29-2012 at 11:32 AM. |
#916 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
#918 | |
Drives: Honda Fit
I agree. On the other hand, if a "work-around" effectively solves the problem, and no parts later come flying through the hood, then I would say it amounts to the same outcome. Just because we don't know what the problem is doesn't mean that they don't know what the problem is. Also, if they are willing to change hard parts and software in an attempt to fix the problem, then it doesn't sound like they are simply trying to "mask the problem." But, again, I agree with you. Best to know what's going on in toto. |
#919 |
Drives: 2013 DGM BRZ Limited
#921 | |
Drives: t
I had my parts changed, and still showing a CEL/SL right away.. The dealer ordered a new ECM because a reflash isn't on the flow chart.. |
| The Following User Says Thank You to choi0706 For This Useful Post: | Marrk (09-29-2012) |
#922 |
Drives: 2013 Asphalt FRS AT
add me to the list as well :
christina_marie, FR-S (Asphalt AT), 7073xx, western MA area - normal break in, never went above 4K and didn't drive her hard until after 1000 miles. first incident - 8/20 (day of purchase) with 40 miles on her - CEL popped, no SL, no engine shake or anything else noticeable, brought it immediately back, all they did was clear the code and I was good to go for a week. second incident : 8/27 (830 miles) - CEL/SL/extreme engine shake, RPM hunting, code pulled P0019. Was in servicing for 3 or 4 "business days" and given a loaner. They swapped the OCV sensor, cleared the problem for awhile until the following ... third incident : currently in for service as of 9/23 with 2200 miles on her - CEL/SL/(CEL was actually blinking this time)/engine shake/RPM hunting - service manager stated new ECU being ordered, 2-3 week wait as most everyone else is hearing. my service rep already talked to a toyota/scion corporate rep who approved compensation of some sort once the problem is "fixed", which I'm happy about at least. I will be well within lemon law rights in MA by the time the ECU even comes in, so that will be worst case scenario if need be. Just miss driving her as everyone else is feeling ! I will post updates as soon as I hear anything ..
#923 | |
Drives: 86
looks like you and i have had the same type of symptoms, keep us posted! |
#924 | |
Drives: 2012 FUJI Z
| The Following User Says Thank You to CMOS For This Useful Post: | @Art_Mighty (09-29-2012) |
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 892 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
