#2451 |
Automatic Hooligan
Good question. I'd assume it's an 810 as it's never been changed.
#2452 | |
Drives: Honda Fit
"swapped the valves" ? I'm not sure what this means, nor do I recall seeing anything about swapping valves in this thread. Maybe I missed something (?). Could you explain? Thanks. |
#2453 |
Most likely swapped sensors to see if its a cam sensor issue like they did on mine.
Sent from my SCH-I535 using Tapatalk 2 |
#2454 |
Drives: Honda Fit
^^Okay. Swapping sensors I understand. Thanks.
#2455 |
Drives: RIP 2013 Scion FR-S
xfire0384, Scion FR-S, 5,400 miles, 7078XX, 1 day - repaired, CA, USA
They scanned the ECM and got error code P0019 - Cam Sensor Correlation. They reflashed the ECM and it seems to have fixed the issue. Talked with the Service Consultant and he said he had seen a number of FR-S come through and in all cases the reflash or replacing the ECM has fixed the problem. Here's hoping... |
#2456 |
Drives: Subaru BRZ Lmtd
Damn! Just got my BRZ on Thursday.. See what surprises await. :/ Currently at 680mi. Have experienced a rough shake when completely stopped. Is that the start to this problem?
#2457 |
Drives: GT-86
So i got the flash today.
No more idle issues no more CEL Car runs smooth as butter. This is the way it should have come U can count me as case solved |
#2458 |
That is what I had just before my FR-S gave me the CEL/SL lights. Think it was about a month for me from the first rough idle to that.
#2459 |
Drives: Honda Fit
#2460 |
Drives: White out Scion Frs
Have my frs checked in at the dealer for CEL. They will keep my car for couple of days to drive it to regenerate the code again. Hope to get my car back soon.
#2461 |
Because Racecar
Drives: 2013 Asphalt FRS
Tuckdaddy number 209 now around 9,000 miles and still kicking strong!
#2462 |
6055XX.. Hope my made it clear from all those major problems..
#2463 |
Drives: BRZ DGM Limited
#2464 |
Went in for the ECM recall(01/31) for about 10 min and everything is set hopefully the light doesn't come on XD
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 892 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
