#1975 | |
My next question is going to be can they just pull one out of a car sitting on the lot? My thought is its probably bad too and they are knowingly going to sell it like that. I think we will find out this is much closer to a 100% fail rate that first believed. I do R&D for a major OEM and this kind of failure either is or isnt - ECUs are built to very rigourous standards and never fail unless abused. |
| The Following User Says Thank You to mhigham For This Useful Post: | eurospeed (10-27-2012) |
#1976 |
| The Following User Says Thank You to jduffy For This Useful Post: | Plxdjake89 (10-27-2012) |
#1978 |
Drives: 2013 Scion FR-S-white out
I'm truly sorry for all of you having problems, my car was acting up at one point and now it's running just fine. I believe if you all had patience and let them take care of you ( Subaru or Toyota ) you would enjoy this car, just like me. Again, sorry for all you quitters
#1979 | |
Drives: GT86
It's the same ECU in all cars and the same software. What the hell gets out of order on some cars, and why does it? I have a hard time believing Toyobarus "first 100miles your ECU learns your driving and then it's done".... |
#1980 | |
Drives: 2013 Firestorm FR-S
| The Following 2 Users Say Thank You to DieselxIndustry For This Useful Post: | @Art_Mighty (10-27-2012), eurospeed (10-27-2012) |
#1981 | |
Drives: 2010 Mazda 3 hatch
| The Following User Says Thank You to mx5apex For This Useful Post: | sajonf (10-27-2012) |
#1982 |
Done
Drives: WRB BRZ
Not much I can do really. It's my daily driver and I fell in love at first sight/drive. But then I know I'm not the only one. It's frustrating because all we really want is to have a dependable fun car that we have all been waiting a long time for. We all expected little quirky issues that is the right of passage when buying a first year platform. None of us expected catostrophic failures or endless weeks of service time. I have several scars to remind me life is short. Now my car does too. In my favor or not, It's a lesson in life.
#1983 |
People get the CEL on both cold and warmed up engines.
The AVCS/VVTi sensors do not monitor oil pressure they monitor the position of the cam. The oil control valves have a valve in them which is opened in one direction or the other to either retard or advance the cam, or it just closes to maintain the current position. The ECU knows approximately how much to move the valve to change the position but relies on the sensors for feedback. My guess is something is machined incorrectly in the sprockets/OCV which is causing the cam to either not advance enough or advance too much, and then things start to go awry. I've always thought it had more to do with when the cam needs to be retarded again because the issue happens at idle, I have yet to hear of a case where the issue really causes an issue at speed or WOT. The car itself has no way to monitor oil pressure, it just has the idiot switch/light you mentioned. Subaru engines run relatively high oil pressure. If it was truly an oil pressure problem we'd be hearing about a lot of spun bearings, with the high oil pressure the cars run any kind of low pressure can wreak havok very quickly. Especially with the 0w-20 oil they use in the engines from the factory, it is like water. I've read a couple instances of oil pressure problems on fixed cars but it has been due to the mechanics who replaced the sprockets screwing something up. |
#1984 |
Drives: Mazda MX5
I agree, it seems that the fault has more to do with the VVT cams than strictly low oil pressure alone. I think that this is why some of the "fix" for engines with CEL included at least one new cam actuator. I think that if it were strictly a low oil pressure problem we'd see more engines affected. I also agree with others who have stated that the ECU reflash has something to do with an increase in the computer's tolerance levels for actautors, and sampling parameters.
#1985 | |
Drives: 2008 Lotus Elise SC
As others have said, I doubt the oil weight is the issue here..... Unfortunately, I think we are all in the boat of waiting on Subaru to figure out what the problem is with their engine. I wish they'd hurry up.....the wife is ready to buy a new car, I'm ready to get one too....and we both like the BRZ....but until they get this sorted out, we're not touching this one. The only plus side is we're looking at a Lotus Elise instead....but the practicality of that car is markedly less than the BRZ for us....so it REALLY doesn't make sense. Sean |
#1986 | |
Go for the Elise, you'll probably enjoy the same exclusivity that I am enjoying everyday. |
#1987 |
Drives: it like he stole it!!
I miss my car......
| The Following User Says Thank You to MikesFRS For This Useful Post: | ftc~brz (10-27-2012) |
#1988 |
Drives: Scion FR-S Auto
re: Idle issue
mbaexec, FR-S, 260, 7079XX , ECU on order (according to the dealer) , Bethesda, MD US
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 892 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
