#1779 | |
Drives: 2008 Lotus Elise SC
I stumbled upon this.... To answer your question....I'd say the probability is high after they get a CEL for the vast majority of owners. However, that being said, even that may not be all that valid.....IF this turns out to be an issue that crops up as cars put more miles on them (and since the mfr doesn't seem to really know what the root cause is....or they're not telling.....that *could* be the case).....we could see even more reports of the problem as time passes. |
#1780 | |
Drives: t
#1781 |
Drives: BRZ Limited DGM, Camry SE Limited E
Totoya's answer
After not purchasing an FR-S yesterday from my idiot salesman who refuses to believe there is any real problem, I did get a call back from another "nicer" salesman who took the time to at least research all the documentation I had brought in. He repeated back to me all I've already read online, although he did mention there were only a few cases. i countered with 152 is not a few.
I emailed the Manager of the dealership about the treatment I received and he called me this morning. He says he called Toyota and was told that this is a minor problem that JUST requires a reflash, nothing about replacing the ECU. when mentioned this goes against all I have read online, he tried to throw doubt on everything printed in this forum or even the press. So I called Toyota with my concerns and I did get an answer from whoever this guy Jose is to the numbers affected and he said "it's only a small number about 5% or less." (is 5% THAT small?)He explained that Toyota was handling it case by case as to whether your ECU were replaced or not, and not whether is was under or over 100 miles. He would not comment on Suburu's handling of the same problem and he said he couldn't speak on whether this issue would become a service release or not, but since he brought up that point I would think they understand this issue is causing a bit of bad publicity. It was obvious i was not the first person to call concerning this. The more people who call and complain the better. As i was writing this I was again called by the manager of the dealership who supposedly was trying to get me a free extension on the warranty as an incentive to buy it. He could not. His parting words were "well hopefully sometime in the future Toyota can win back your trust". |
#1782 |
Drives: 2013 MT FR-S Asphalt
So, on my way home from work last night in the loaner, it popped the maintenance required light on the dash. I decided to stop off at the dealership and get it taken care of. At first they tried to tell me to go ahead and drive, that it was just a service call needed, and I insisted that they either take care of it quickly or give me a different car.
While it was in for it's service (which only took about 5 minutes, I would like to add - wish I got that kind of service normally..) I went to the parts dept. to eyeball the order system for my parts. It said that there was a number somewhere in the upper thirties waiting in the DFW area for a new ECU, and that 9 were expected to hit dealerships on Monday. This tells me that I am now going to be waiting until at least then to get mine, and that the case manager really had no idea what she was talking about....
#1783 |
Drives: GT86
I've been using shell v-power 98ron and tesco momentum 99ron since I picked the car up, and I still get CELs.
#1784 | |
I Love custom Turbo kits
Drives: Limited BRZ
Second, I'm not saying it resolves the issue, I'm just stating what happened to my car :happy0180:
#1785 |
Long Distance Driver
#1786 |
FRS Rear Mount Turbo
Drives: 2013 FR-S Raven, Rear Turbo
I've been using shell from the beginning and no idle issues or CEL's at this point. Hopefully I did not jinx myself.
#1787 |
I too have been using Shell and for me no chirping. I did have some odd seeking idle moments a few days ago but the last couple of days it's been very steady.
| The Following User Says Thank You to jduffy For This Useful Post: | Sportsguy83 (10-19-2012) |
#1788 |
Car is ready to be picked up, will take pics and copy some info.
#1789 |
Drives: fr-s
so my frs has 3800 miles on it and today my car started droping below 5k rpm and started flashin the check engine light 2 times then the traction controll light came on ..... my major queston is i have a perrion light weight pully and motiv front pipe cat delete should i swap them out befor takieng the car to the delership ???? i know where not supposed to reuse the pully bolt other then swapin it out one time so im worried about that messing up ..... or would the delership even care about these mods???
#1790 | |
Drives: 2013 Scion Frs(Scarlet)
#1791 | |
#1792 |
Drives: 2013 WRB Subaru BRZ
I've been putting mostly Chevron Premium in my car and I occasionally have an engine idle dip, its not that often and its never killed the car just something I notice when the tack drops a couple hundred RPMs and then jumps back up.
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 892 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
