Unread 02-06-2024, 01:11 PM   #85
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by RT-BRZ View Post
At least that's how I've understood it.
Correct.
RT-BRZ (02-06-2024), x808drifter (02-06-2024)
Unread 02-06-2024, 05:17 PM   #86
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
It has always been my understanding that tighter clearances were the result of higher precision machining and manufacturing. It seems logical to me that the tighter clearances allowed for less drag by having the ability to use lower viscosity lubrication. When clearances were bigger, higher viscosity lubrication was needed to "fill the space" to reduce wear. All in the name of efficiency.
Taking tolerance/precision out- wouldn't you want a thicker layer of thicker oil there rather than a thin layer of thinner oil for durability though?
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies.
2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter
2016 GX460: IDK. Too reliable to sell. Too boring to use.
GrandSport is offline   Reply With Quote
Unread 02-06-2024, 05:45 PM   #87
RT-BRZ
FNG
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Well, I think it's a story of tradeoffs. The lower viscosity oils are more "slippery" apparently which gives the appropriate amount of lubrication. A thicker oil may offer more "cushion" and may better maintain it's heat resistance but it may also increase parasitic drag and lower efficiency (mileage, power, etc.).
Honestly, I'm not the design engineer for these engines and I'm definitely not qualified to determine what's better. All I am is a caveman trying to understand the wheel.
RT-BRZ is offline   Reply With Quote
Best track hood for cooling (coil overheating issue) GrandSport Tracking / Autocross / HPDE / Drifting 54 01-07-2024 07:43 PM
Track Car Weight Lunatic Tracking / Autocross / HPDE / Drifting 83 03-15-2021 01:35 AM
Track car weight reduction Irace86 BRZ First-Gen (2012+) -- General Topics 17 06-11-2016 06:21 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 12:38 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 02:39 AM
