#393 | |
hashiryu
Drives: Mk4 Supra
Does this forum have an ignore button or list or something of the sort? Anway...
#394 |
Drives: Ms. Daisy
It does actually... click on their name, click on user lists, and select ignore member. But where's the fun in that. :happy0180:
BRZ before hoes
#395 |
On the Rise
Drives: Toyota
This is the first I've heard of mean piston speed, having to do with longevity. Why would 20m/s be a cut off? (I assume m/s means meters per second?) Does it mean reducing stress on bearings by reducing reciprocating stress? Does this apply to some kind of stress formula?
#396 | |
Drives: 2010 Evo X MR-T
anyways, the D4-S system is the perfect solution, theoretically.... |
#397 | |
GL 86!
Drives: Maybe FR-S... maybe not
Typical piston acceleration forces become quite great, recommended maximum mean piston speed for most piston internal combustion engines is at ~20m/s, (I'm also thinking combustion expansion rate has something to do with this as well): Hence stroke length and RPM relationship is one of the pieces to a high revving engine. Obviously if you increase the piston speed the greater distance the piston has traveled (easier to understand linearly) the more wear it will cause in the cylinder bore and hence why engines wear faster at high RPM, particularly if they are not designed for it. Hope this helps. |
#398 | |
I'm surprised hachi hasn't banned yet. Lol
I am the Ice Queen.
Logic > Emotion ┬──┬◡ノ(° -°ノ) Yashio Factory Pink adds +10HP to anything. TOYOTA FT-86 ![]() |
#399 | |||
hashiryu
Drives: Mk4 Supra
![]() Quote:
Dude, didn't you hear? We just ought to go back to using carbs. |
#400 |
ZC6A2B82KC7J
Drives: 2002 WRX
it works for NASCAR
#401 |
Drives: '06 AM V8V Coupe
With D4-S if you want to make SERIOUS power, you could theoretically turn on both the port and the direct injectors couldn't you?
Well if you could coax the ECU into it. That should be more than enough fuel.
#402 | |
so if the rumors are true that the next WRX will use toyota D4-S tech? it could be a monster of an engine... |
#403 |
Yup, it decreases the work the piston does during the compression stroke by the value of the latent heat of vaporization of the fuel (times the amount of fuel obviously). This work is directly saved from the compression stroke and the rest of the cycle is for the most part unchanged. Depending on fuel you basically get a few percent more power for free. With a fuel like methanol or ethanol this number becomes very significant and you get a crapton more power. Oh and that's not factoring in the increased compression you can run.
#404 |
I don't think it's just a "few joules", given that part of the reason people adjust their air/fuel ratios rather rich is just so the fuel can provide a cooling effect. If you have port injection, (assuming performance oriented engine) at the bottom of the intake stroke your valve closes off so you have basically atmospheric pressure, and the temperature is slightly cooler than ambient due to the fuel vaporization. So the compression stroke works as an adiabatic process. If you have direct injection, you pull in pure air at ambient temperature, atmospheric pressure into the cylinder. If this were it, the compression stroke would consume slightly more power due to the lower heat ratio. However if you add fuel gradually as the compression stroke happens, you cool it off and it loses pressure. Depending on how it's done, this is somewhere between adiabatic and isothermal compression. In the first scenario, the charge was essentially cooled isobarically, then compressed adiabatically, and this requires more work. If you're not convinced you can go draw some T/S diagrams and convince yourself.
A second benefit is that you can probably cram a tiny bit more air/fuel mixture in, since the fuel is added after the intake valve closes. A third benefit is higher compression like I said. A fourth benefit is as you said, better fuel atomization, although I'm not too sure about this one since port injection allows the fuel to pass through the relatively narrow intake opening and experience some turbulence. The higher pressure used in direct injection probably helps with this, at least at the start of the compression stroke where the pressure difference between fuel system and cylinder is very large. EDIT: Gasoline's heat of vaporization is about 3% of its heat of combustion. I wouldn't call that insignificant. |
#405 | |
Drives: N/A
#406 | |
| New set of Toyota FT-86 interior photos from the studio (some great details) | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 52 | 09-15-2013 02:29 PM |
| Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 04-11-2011 10:03 PM |
| Toyota UK: Behind the scenes shoot with the Toyota FT-86 II Sports Concept | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 48 | 04-05-2011 11:02 AM |
| Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! | Nemesis | Scion FR-S / Toyota 86 GT86 General Forum | 128 | 02-19-2010 12:36 PM |
| Toyota’s chief tester? The boss | Axel | Other Vehicles & General Automotive Discussions | 7 | 12-30-2009 10:44 PM |
