#15 |
Drives: Crapcan
Eh, that's a bit of a stretch argument. He is asking about the HKS engine because he is interested in one complete with new parts and there is not much info on the HKS engine. You got yours built with an IAG shortblock with reused heads and cams. Yes that may be more economical and more than adaquite. I'd prefer to go your route too if I was going that way, but it isn't the question.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Uplink (03-03-2023) |
#16 |
Drives: 17 Asphalt 86
If you are open to a build in that realm of budget maybe consider a FA24 swap?
Base output is regularly measured around or above most full bolt on E85 FA20s. |
#17 | |
Drives: 2017 BRZ w/PP
I mean i bought a fully complete and timed longblock that had the heads cleaned and machined, new valves, seats, and springs put in, new DI injectors put in, seals, a new oil pump, and it all timed. All i did was put plugs and coils in, put the manifold on and bigger port injectors, and alternator. Yeah it isn't 100% drop in but its 95% there was also a fraction of 40k. I honestly don't give a flying shit what what yall do with your money, but a question was asked and i gave my answer. Yall must be related to my old boss who would ask my opinion on things then do whatever she originally wanted lol if you want to disingenuously frame it like that sure go ahead I personally don't care, but i didn't just but a shortblock and resued the heads and cams. If i did i'd have a fatter bank account
#18 |
Drives: 2013 frs base
Can you easily do a FA24 swap into an early twin (2013-2016)? Seems to me that I read where crank and other sensors in 2017+ are more compatible with this swap.
#19 | |
Drives: Crapcan
I am thinking it is going to be similar to the 17+ swap with some more wrenches thrown in. I will probably be looking into it this winter.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (03-03-2023), brandonblt2 (03-13-2023), RedReplicant (03-03-2023), Tatsu333 (03-04-2023), Ultramaroon (03-04-2023) |
#20 | |
Drives: anything you let me
For me, that's not a worthwhile enough gain for the hassles and cost involved with doing a K-swap. Plus, I still don't like how they sound and I have to live with that every day. Several friends run in HC and I've discussed the swap with them at length. Ultimately, for what I need/want, it doesn't work. |
| The Following User Says Thank You to Uplink For This Useful Post: | RedReplicant (03-10-2023) |
#21 | |
I was just hoping someone had some insight at the baseline numbers, something I can't seem to find or get a response from the manufacturer on. There also seems to be a discrepancy on their documentation saying that stock our engines are 11.9:1 and their modifications bring it "up" to 12.0:1. That seems to be a bit of a red flag. |
#22 | |
That's the crazy part. They actually DO list what the engines are rated to at each stage. The lowest end Stage 0 being 395hp/470tq which is already more than the stock transmission can reliably handle. My curiosity was more around the starting point because I don't know how to do the math on the stroke increase to power output. I'm looking to compare an all new stock FA20 vs the HKS S0 and see how much of a leg up the HKS gives you NA or if it's a step down with them expecting the engine to be boosted. As I mentioned in another reply, their stated CR seems incorrect by a considerable amount so I would think their engine starts down a bit of power, just more "bulletproof". |
#23 | |
This. I have 2 FA20s of questionable reliability of parts. If I have to purchase a 3rd and start Frankensteining parts together then try to sell off spares, it's just not a road I want to go down. |
#24 | |
Oh, I'm definitely not dropping $40k on this engine build. I'm trying to do the research on all my options. Plus I don't want to do a conversion. I'll settle for a little less power with 0 headaches.
#25 | |
It's all good, but you do realize the question asked was: "Does anyone know where/if there are hp/tq numbers or (god willing) dyno sheets for the HKS FA20 complete engines run NA?" Not: "Is it cheaper to build something else?" I agree with you and in my original post I said straight up that $42k was off the wall. All I was looking for was a power baseline.
#26 | |
It's ok, I didn't take the comments harshly and wasn't being defensive. I knew those numbers are prohibitively high vs some other options before even delving into this. But you're right, I was looking for all net-new. I have 2 factory engines on hand. One was hydrolocked but I was able to revive it and it ran for a bit then something let go out of nowhere. Luckily that didn't happen on track, it would have been ugly. I don't trust that there aren't hidden stress issues internally that might spring up even after a rebuild. The other one was a 75k donor motor that I don't know the history of but it felt tired and after about 5k of commuting is beginning to smell of oil, worse on any spirited driving. So it's time to evaluate options while I've still got a functioning daily. ![]() I'm really looking for something I can drop in and be at work the next day (or at least Monday morning) so complete assembly is my best bet. I could do that swap in about 4 hours. Also, most builders I've spoken with have a backlog now with the season ramping up so getting a custom build done is going to take several months while the HKS can be delivered in a week or two. Not losing out on a summer at the track is decent offset in the pricing. What's the old phrase, fast/reliable/cheap, pick 2?
| The Following 2 Users Say Thank You to Uplink For This Useful Post: | NoHaveMSG (03-10-2023), RedReplicant (03-10-2023) |
#27 |
Ok, mystery solved. So after a bit of digging around their site (they have still not responded to my e-mail) I was able to find some ballpark numbers indirectly. If you look at the page for the camshaft they use in the Stage 0 engine, they have a dyno graph. Unfortunately, that graph is the 2.1L capacity kit + cams + supercharger... because of course it is.
But if you look at the 2.1L capacity kit used in the Stage 0, it has a dyno graph of just that and the cams, NA. It's basically a little better than going with a 2017 FA20, netting +12hp and +18ft/lbs (209 & 169) over a stock 1st gen. But you're also getting a beefed up engine rated to well above the transmission's reliability plus it's a complete drop-in replacement. All-in, it's not a terrible option.
#28 | |
Drives: 2013 BRZ HKS Turbo
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 09:53 PM |
| 2015 FR-S Tech Specs Document - no engine upgrade | 5AD86D | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 04-26-2014 05:33 PM |
| Cam specs?? | brn12345 | Engine, Exhaust, Transmission | 6 | 11-12-2012 06:04 PM |
| 2 ENGINE VARIANTS: Old article leaked accurate info consistent with today's specs | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-17-2012 05:50 AM |
| Ducati 1199 Superquadro engine specs | RRnold | Other Vehicles & General Automotive Discussions | 9 | 11-21-2011 02:36 AM |
