#15 |
Drives: brz 2017 hksv2
have you tried asking for opinions to ecutek Support. . they have lot of acknowledgment on this car, you just have to have luck they are Willing to share lol
They used to help me a lot in the past, now they are a bit more evasive sometimes just a little OT, the app ecu Connect stopped working on my xiaomi phone for more than 1 year, i stressed them so much via email and they were blaming it on me, then last week they releases an update with the changelog saying "fix for xiaomi units" and now magically works |
#16 |
Drives: 86 GT
Do you have Techstream? What are your values for the DI Injector Idle Learn (or something similar)?
Going on a limb here but try changing the the injector mode to Direct in the Active Test, hold rpm at 2k for a minute, check if the DI Learn values change, and see if it idles on its own after that.
DIY stuff at Compelica Works
#17 | |
Drives: 2017 GT 86
So today we decided to start the car up with the fuel pressure sensor on the high fuel pressure rail to see what would happen, car started up perfectly on port and direct injections, the sensor is readying 16Mpa on idle which is wayyyy to high on idle, have one on order but is back ordered till the 24th unfortunately, we reckon it could be that? Thanks John |
| The Following 3 Users Say Thank You to JohnGT86-Uk For This Useful Post: |
#18 |
Drives: WRB BRZ
Run an earth wire from chassis to the DI computer
Also try another DI computer they are all same just swap it in Make sure you have all three botls in di computer and it mount bracket bolts Make sure the engine earth strap has be installed best to run a direct earth to do computer to test Ensure the plugs in di computer pushed in all the way |
#19 | |
Drives: WRB BRZ
Yes should be round 3-4mpa at idle If the di computer sees 16 MPA at idle when the real pressure is maybe 3 then it only going to inject 1/4 the required fuel I suspect as it calculated pulse width based on pressure, it's a mechanical pump so unlikely it's rearly generating 16mpa at idle |
#20 | |
Drives: 2017 GT 86
So are you saying you think its the fuel pressure sensor? I managed to get one from subaru, it's arriving today so will let you know Thanks John |
#21 |
Drives: WRB BRZ
| Tags |
| forged, fuel, idle, issue, turbo |
| Difference between direct injectors? | maximumz | Engine, Exhaust, Transmission | 1 | 08-30-2022 12:41 PM |
| Cleaning direct injectors after E85 use | SPCorBUST | Engine, Exhaust, Transmission | 14 | 01-15-2022 12:36 PM |
| FT86 Idle Noise/Issue ? Injectors? | Rezi | Issues | Warranty | Recalls / TSB | 1 | 01-20-2017 11:18 AM |
| Direct Fuel Injectors | Silverspeed | Engine, Exhaust, Bolt-Ons | 0 | 10-20-2016 08:04 PM |
| New injectors and pump, idle dip when tipping in the throttle? | HRTROB | Forced Induction | 22 | 05-12-2014 02:31 PM |
