Old 10-01-2022, 11:08 PM   #1
GR_stevenson
GR_stevenson's Avatar
Drives: 2023 GR86 HALO MT
ZN8 - GR_Stevenson's track build
Originally placed my order at DVN toyota at the end of January this year, waited 6 months without any update, luckily someone at Markville cancelled their order midway, so I had the chance to take delivery of this war machine at the end of August.
The goal of this build is to make it a daily driver that is capable of weekend track duty; the main focus of this car will be reliability as I will be driving this car all year round.
MOD LIST
INTERIOR:
CUSCO GAS PEDAL 965766A
BLITZ SHIFT KNOB 13850
THINKWARE U1000 DASHCAM
DRIVETRAIN/SUSPENSION:
KARTBOY TRANSMISSION MOUNT INSERT KB-025-BRZ
MTEC SHIFTER SPRING
BLITZ STRUT TOWER BAR 96133
EXTERIOR:
TRD GR DOOR HANDLE PROTECTOR
AUXITO LED REVERSE BULB T15-15E-JM-W2-GM
EXHAUST:
AMUSE R1 TITAN "SOUEN" SINGLE EXIT CATBACK
BRAKE/WHEELS/TIRES:
APEX EC7R 17X9 +35,+42
HANKOOK VENTUS RS4 235/45/17
PROJECT KICS R40 LUG NUTS 12 X 1.25
PREVIOUS PARTS:
CUSCO SPORTS SHIFT KNOB 6C1 760 BA
GR_stevenson is offline   Reply With Quote
Old 10-01-2022, 11:18 PM   #2
GR_stevenson
2022 Aug 31: Delivery
Old 10-01-2022, 11:24 PM   #3
GR_stevenson
2022 Sept 3: Ceramic coating and rust proof, plus rear & side ceramic tints.
Old 10-01-2022, 11:34 PM   #4
GR_stevenson
Installed cusco knob and gas pedal. Initially, I tried to have both verus spacer and the pedal cover together, but such a combination is a proven failure, I removed the verus piece the second following day, heel & toeing felt much better.
The shift knob is way smaller and lighter than the stock piece, very nice.
The Following User Says Thank You to GR_stevenson For This Useful Post:
villainous_frx (10-01-2022)
Old 10-16-2022, 12:30 PM   #5
GR_stevenson
Acquired a brand new set of amuse r1 titan "souen" catback exhaust, could have used that money for fujitsubo or hks spec l2, but I can't resist the weight saving, and the aesthetic or burnt tip loll.
Sound clip link:
https://youtube.com/shorts/skWawgBa7Ac?feature=share
The Following 2 Users Say Thank You to GR_stevenson For This Useful Post:
jongers (02-18-2023), villainous_frx (10-16-2022)
Old 02-16-2023, 10:11 PM   #6
GR_stevenson
Oil change update:
I went to Apex at Markham for my second oil change on Feb 15, 2023.
The first one was done at 3300km last fall, mostly highway driven and RPM was mostly staying around 3k to 3.5k, no excessive revving or sustained high RPM by any means, perhaps few pulls on backroads where I upshift at 6500 RPM, nothing crazy.
I started to drive the car on a daily basis last Nov and changed the oil plus RTV clean up at 8317km, and this is what the tech at Apex sent to me.
Needless to say, the robots at Subaru have the brain of a goldfish, and I would be lying if I said I was not worried.
The car felt to be easier to rev up and more "powerful" after the clean-up, and no strange sound is coming out of the motor.
Will my motor have any premature wear and damage? IDK.
Will I be doing a blackstone analysis on my next oil change? You bet ya sweet bippy I will.
Prob should've dropped the pan earlier or done the blackstone on my first oil change.
Clipdat (02-21-2023), jongers (02-18-2023)
Old 02-18-2023, 05:22 PM   #7
jongers
Drives: 19 86, 22 BRZ
Originally Posted by GR_stevenson View Post
Oil change update:
Geez - glad you took the initiative and got the oil pan/pickup checked. That looks pretty bad compared to others I've seen (including mine around the same mileage ~5.5k).
jongers is offline   Reply With Quote
Old 04-13-2023, 06:53 PM   #8
GR_stevenson
Got the lug nuts and tires this Tuesday
Old 04-13-2023, 07:06 PM   #9
GR_stevenson
Got my wheels ceramic coated and installed at my friend's shop, RS4's 235 is a little bit wider than I expected, and the car now looks like a monster truck, will have to dial in the height and alignment soon
Old 04-13-2023, 07:10 PM   #10
GR_stevenson
Surprise from the UPS man!
Installed the new knob and strut tower bar, I got to say the knob from Blitz is way better than the Cusco one I used to have, just a wee bit heavier and the grip is right on point!
Old 04-14-2023, 01:29 AM   #11
bkd705
Drives: 2023 BRZ WRB
How is the 17x9 +35 fitting? Thought that would be way too aggressive but doesn't look bad in the photos.
bkd705 is offline   Reply With Quote
Old 04-14-2023, 04:48 PM   #12
GR_stevenson
I fitted +35 up front and +42 in the back to avoid shaving the body, with the sacrifice of losing the ability to rotate the tires, both front and back are poking a little, but not excessive imo.
Old 04-14-2023, 09:06 PM   #13
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
Poke should go away with about -2* camber and some lowering.
grippgoat is offline   Reply With Quote
$5K for track build Kulebrero1 Tracking / Autocross / HPDE / Drifting 27 05-08-2022 09:51 PM
Mr. Frs Trd track build Mr.Frs Member's Car Journals 24 06-20-2018 06:20 PM
dp1 track build (NY) dp1 NY / NJ / CT / PA 114 07-19-2017 01:47 PM
What's your Track Build? neroman98 BRZ First-Gen (2012+) — General Topics 4 08-06-2015 04:16 PM
FRS Track Build smoltz Tracking / Autocross / HPDE / Drifting 27 07-08-2015 09:17 AM
