Old 12-16-2013, 01:49 PM   #85
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by DarrenDriven View Post
Not for my application... I was running 17x9.0 +30 with the Eibach Pros.
I'm talking about the sportlines. Any need for camber adjusting parts other than the cheap camber bolts you can get upfront?
I think the drop of the sportlines is perfect. But if I need to spend more money on lcas to correct camber, I'm simply going to pass. My car is a DD so I want something simple and budget friendly.
hmong337 is offline   Reply With Quote
Old 12-16-2013, 01:52 PM   #86
hmong337
Emperor JDM
hmong337's Avatar
Originally Posted by boredom.is.me View Post
Here:
18x8et45 225/40R18
18x9et42 245/40R18
Camber: 0.5F/1R
Still using the stock control arms?
Old 12-16-2013, 02:45 PM   #87
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Nope.
SPC in the rear
front is stock
However, I do not see them as mandatory. You'll be somewhere around -2 degrees in the rear.
The Following User Says Thank You to boredom.is.me For This Useful Post:
hmong337 (12-16-2013)
Old 12-16-2013, 03:52 PM   #88
hmong337
Emperor JDM
hmong337's Avatar
Yea that's too much camber for me as I use my car as a DD and will probably only track the car like 1-2 times a year. Looks like I'm just gonna stick with my original plan of running 1" Hotchkis lowering springs and call it a day. Seems like going any lower will either chew your tires up without lcas or throw a bunch more money into the setup to correct camber when going lower than 1".
At that point, I'd rather just save a bit more and go directly to a coilover system.
Cheers.
Old 12-16-2013, 04:07 PM   #89
bfrank1972
Drives: 2013 FR-S Argento
Cheers.
Nah you'll be fine - camber doesn't chew up tires like you'd think. Just make sure you get the car aligned (fix your toe settings) whenever you change ride height. If you want a cheaper option:
http://www.ft86club.com/forums/showthread.php?p=815895
Also you mention going to a coilover system, without some sort of camber correction coilovers will have the same problem with rear camber as lowering springs.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 12-16-2013, 04:24 PM   #90
boredom.is.me
Custom User Title
Coilovers don't fix camber in the rear.
Old 12-16-2013, 10:58 PM   #91
hmong337
Emperor JDM
hmong337's Avatar
I really would like to keep my rear camber to about -1.0 degrees and upfront to about -0.5 degrees. Thanks for letting me know about those rear camber bolts. I will keep my options open with the sportlines as they have the desired drop I want.
Old 02-26-2014, 11:21 AM   #92
Evo2Brz
Drives: 2014 SWP BRZ
Old thread but was curious about something that was stated earlier. A guy asked how 18x9 would work with these. I plan on doing these with 18x9et35 on 235 tires. Think I'll be all set without any rubbing or fender mods and still be flush? Thanks all
Evo2Brz is offline   Reply With Quote
Old 02-26-2014, 11:59 AM   #93
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Depends on the aspect ratio of your tires, if you stick to oem tire diameter you should be good (I think).
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 02-28-2014, 10:19 PM   #94
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Scion fr-s on Vossen CVT directional wheels. It's in dire need of gap be gone. Comparison coming soon.
Size:  34.1 KBName:  uploadfromtaptalk1393640365229.jpg
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 03-20-2014, 01:02 AM   #95
Rishod86
Rishod86's Avatar
Drives: Scion FRS 2013
help me
so i put on the sportline springs and i did it myself and the rear is low but the front looks higher
i did everything right with the right tools .. but i dont remember if i put the bump stops the right way could that be why the front isn't lowered?
there is a 1 finger gap in the rear and a 3 to 4 finger gap in the front
Rishod86 is offline   Reply With Quote
Old 04-14-2014, 02:46 PM   #96
mweidner311
Drives: N/A
Yep you guys sold me ordering some sportlines right now! Thanks for the info, DIY, and picures. Did any of you end up using camber bolts?
Thanks again!
Forgot to ask is how is the ride? Ive only had two lowered cars in my life a Neon back in high school lowered on the factory struts with I think Skunk 2 springs I bought on ebay. The second was a 323is on Vogtland with Bilstein struts. Night and day difference between the two cars the BMW I really couldn't even tell a difference between the stock ride quality and the lowered.
I'm just curious will there be a huge difference with the sportlines on stock struts I don't think my wife will enjoy a teeth jarring ride over bumps if you know what I mean...
mweidner311 is offline   Reply With Quote
Old 04-14-2014, 02:47 PM   #97
mweidner311
Drives: N/A
Good deal so I take it the sport line kit comes with new bump stops and sleeves like the pro kit. I couldn't actually find any info stating that.
Old 04-14-2014, 03:31 PM   #98
TylerLinders48
Drives: 2014 Scion FR-S
Yes they do
TylerLinders48 is offline   Reply With Quote
The Following User Says Thank You to TylerLinders48 For This Useful Post:
mweidner311 (04-14-2014)
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 07:26 PM
Eibach Sportline Spring review Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2019 07:23 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 12:04 PM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 03:05 PM
