Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
timurrrr
Old 08-19-2022, 04:26 PM   #715
KillerBMotorsport
KillerBMotorsport's Avatar
There is so, so much moly that I can't help but think that the factory fill is actually a special oil specifically for break in.
If this is the case then guys that preach the "get that crap out as fast as you can" method are not doing themselves any favours.
Assembly lube and break-in oil are used. Whomever thought otherwise doesn't have history with performing UOAs on Subaru products. These cars are not $200,000 GT3s that come from the factory already broken in and ready to take to the track
KillerBMotorsport is offline   Reply With Quote
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post:
FRSBRZGT86FAN (08-20-2022), mycrors7 (08-20-2022), soundman98 (08-19-2022), Tokay444 (08-22-2022)
Old 08-19-2022, 11:35 PM   #716
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
^ that
The camshafts and main bearings are going to be installed with assembly lube, presumably with lots of Mo.
Old 08-20-2022, 09:53 AM   #717
^ that
Of course there is assembly lube but that is a shitload of moly even taking that into account.
Assembly lube is usually used sparingly not slathered on in gobs.
Old 08-20-2022, 03:19 PM   #718
mpg9999
Drives: 2022 BRZ
One more datapoint to add. No engine issues, build date 5/22, but I finally hit my break in mileage so I wanted to change the oil. I used a metal strainer when I drained the oil to see if it would catch anything but it was clean. I opened up the filter and found what I assume to be small bits of grey, green, and red RTV.
mpg9999 is offline   Reply With Quote
The Following 8 Users Say Thank You to mpg9999 For This Useful Post:
DrinkenBRZ (08-20-2022), flippy (09-13-2022), gcmak (08-21-2022), Petah78 (08-20-2022), soundman98 (08-20-2022), Stonehorsw (08-20-2022), Sym (08-22-2022), Tcoat (08-20-2022)
Old 08-20-2022, 10:11 PM   #719
Petah78
Drives: 2022 BRZ sport-tech
Thanks for posting this info. Looks like your results are consistent with mine.
I was wondering, though i do not think it's going to work, if it is possible to push the RTV back down towards the pan via compress air through oil filter or engine oil fill hole? But i suspect not since the oil pump is in the way but wanted to confirm.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 08-22-2022, 09:44 AM   #720
KillerBMotorsport
You'd have to do it through the filter hole, NOT the fill tube. Like you, I suspect little to no air coming out of pickup due to the pump being in the way.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Petah78 (08-22-2022)
Old 08-22-2022, 09:51 AM   #721
Petah78
I am going to try on my next oil change anyways since i can't see any negative side effects, worth a shot.
Old 08-22-2022, 10:11 AM   #722
It is sort of a 50/50 proposition if there is indeed anything still in there. You could blow it out or you could just force it in even deeper and cause it to plug up solid. Of course it could not do a thing so I guess it is a 33/33/33 situation. There is just no way to know.
Old 08-22-2022, 10:23 AM   #723
Petah78
It is sort of a 50/50 proposition if there is indeed anything still in there. You could blow it out or you could just force it in even deeper and cause it to plug up solid. Of course it not do a thing so I guess it is a 33/33/33 situation. There is just no way to know.
I am truly amazed at the analytical skills you have, much appreciated. Good to know all the possible scenarios.
On another hand, i thought hooking up a shop vac to the oil drain hole to see if anything will come out. But again, same odds as compressed air through the oil filter hole.
Old 08-22-2022, 10:32 AM   #724
Actually the vacuum could be interesting. Not talking the same levels of pressure and it would be pulling against the flow. Not going to draw after the filter at all I would think. Not sure that it would get much if anything but may (slight chance) pull anything out of the pickup tube strainer.
Old 08-22-2022, 10:41 AM   #725
Petah78
I think this likely the best way to clean out the pick up IF you had access to the pick up and can create a seal the pick up to the shop vac. However, not sure if it will do anything if going through the drain bolt, worth a shot anyways.
Old 08-22-2022, 10:47 AM   #726
Some shopvacs have a cone attachment. If you don't have one make one out of carboard and duct tape. That way you will be able to shove it in the drain hole to get a good seal. Will also improve the draw velocity a bit.
Dadhawk (08-22-2022), Petah78 (08-22-2022)
Old 08-22-2022, 10:58 AM   #727
Petah78
I will see what i can do but i am not sure if i want to stick anything inside the pan. I don't want a "lip" inside the pan as it may block anything from coming out. I am thinking i want to create a seal outside of the pan, just have to figure out how. But thanks for the idea.
Old 08-22-2022, 11:03 AM   #728
In that case just wrap the end of the shop vac hose with some duct tape. Do a few wraps with about a 1/4 inch overlap off the end. That will sort of form a gasket and seal against the outside of the pan.
oh no not again
Search this Thread:
Advanced Search
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
