86WORX
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
timurrrr
Old 08-18-2022, 11:08 AM   #701
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by mycrors7 View Post
Oh it’s 60k for warranty? Yikes I gotta drive more LOL
Do you guys not RTFM? lol
In the US, outside of Hyundai/Kia, it's pretty standard to have a:
3/36 - Bumper to bumper
5/60 - Powertrain
5/unlimited for rust
Emissions is a bit different.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
raisingAnarchy (08-19-2022), Tcoat (08-18-2022)
Old 08-18-2022, 11:28 AM   #702
1st86 Driver!
In the US, the Feds require the emissions warranty for light-duty vehicles to be at minimum all emissions related parts are covered for 2 years or 24,000 miles, with the catalytic converter and ECU covered for 8 years or 80,000 miles.
That is why most areas with emissions testing requirement usually exclude the first two years.
I think the requirement in California may be higher but not sure. For example, seems I remember that they require any car considered to be "low emissions" such as plug in hybrids, to be warranted up to 15 years/150,000 miles for any part that would make the check engine light come on.
Tcoat (08-18-2022)
Old 08-18-2022, 12:19 PM   #703
OkieSnuffBox
Yeah, I figured he could google that part.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Dadhawk (08-18-2022)
Old 08-18-2022, 09:45 PM   #704
Starbucker
Drives: 2022 GR86
1k Oil change analysis by Blackstone. Note the RTV comment.
Starbucker is offline   Reply With Quote
The Following 5 Users Say Thank You to Starbucker For This Useful Post:
Dadhawk (08-19-2022), DylanJZA (08-19-2022), JusTheG (08-19-2022), soundman98 (08-18-2022), Tcoat (08-19-2022)
Old 08-18-2022, 10:08 PM   #705
soundman98
ProCrastinationConsultant
soundman98's Avatar
i thought you and tcoat had both said something similar before,
one shouldn't really be watching the UOA for silicone products, but for increased engine wear indicators, indicating poor lubrication from reduced pressure and/or blocked passageways.
Tcoat (08-19-2022)
Old 08-18-2022, 10:41 PM   #706
austintampa
Drives: honda element
wood i be wrong to think that the problematic RTV wouldnt necessarily show in the oil sample?
think of it like this.
the RTV isnt meant to dissolve in the oil - the opposite.
assumably the exposed bead on the inside of the oil pan is touching oil all the time.
if a piece falls into the oil - its floating, getting sucked to the pickup - but is it dissolving into the oil though (enough to show on a test)? hell if it was - it wouldnt be that bigga issue - because then it would get through the pickup screen, hit the filter, and be gone with an oil change.
austintampa is offline   Reply With Quote
The Following User Says Thank You to austintampa For This Useful Post:
Petah78 (08-18-2022)
Old 08-18-2022, 10:42 PM   #707
OkieSnuffBox
Facts have no place in hysteria.
The Following 6 Users Say Thank You to OkieSnuffBox For This Useful Post:
flippy (09-13-2022), justinco (08-19-2022), Petah78 (08-18-2022), raisingAnarchy (08-19-2022), Tcoat (08-19-2022), Ultramaroon (08-19-2022)
Old 08-18-2022, 11:05 PM   #708
Petah78
Drives: 2022 BRZ sport-tech
Logic is sound, though silicon can be higher given i "think" these motors are sealed with more RTV than your traditional ones (but fact check me on this). I think paying attention to the wear metals is key.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
Old 08-18-2022, 11:43 PM   #709
austintampa
no i think Subaru / Toyota addressing the problem publicly, announcing the issue resolved, extending confidence to owners would be key.
i know how to fix this for owners - i dont know how to manufacture it but I might give it a shot.
Old 08-19-2022, 07:14 AM   #710
Thanks!
Yes there will be higher silicone and metals in the first couple of tests. As the analysis very clearly states that is perfectly normal and expected. Hell, if it didn't show elevated silicone in the first sample I would question the validity of the test!
If you are still getting high metals by the third or fourth test THEN you can start to worry.
soundman98 (08-19-2022)
Old 08-19-2022, 07:28 AM   #711
That makes the assumptions that
A) All the sealant starts being introduced before the filter
B) All the oil passes through the filter at all times.
Not going to repeat the whole thing but neither of these assumptions can be made.
These engines are almost completely sealed with RTV. It would take a long study of the service manual to see exactly where it is used. If this was winter may have actually gone through that exercise but at this point will leave to somebody else.
As you yourself demonstrated by opening up the filter there are at least 4 different sealants used.
Between all your pictures we have grey, green, pink and black.
Of all of them the one I would be most curious as to the source would be the green. It has a high probability of being introduced someplace between the filter and the pan. There is also a lot of it and those little flat pieces could act as a valve while plugging a channel. Under the right pressure they could open and let enough oil through but get just the wrong combination of conditions and they suck closed and BANG.
Old 08-19-2022, 08:01 AM   #712
That is an interesting report. Not so much for the expected silicone or initial break in metals but because of the massive amount of molybdenum and highish levels of boron and phosphorus in the sample.
I always assumed that the factory fill was just normal oil but those are all oil additives to reduce wear not the byproduct of engine operation.
There is so, so much moly that I can't help but think that the factory fill is actually a special oil specifically for break in.
If this is the case then guys that preach the "get that crap out as fast as you can" method are not doing themselves any favours.
Decep (08-20-2022), OldBiker (07-05-2023), Opie (08-22-2022), Petah78 (08-19-2022), soundman98 (08-19-2022)
Old 08-19-2022, 08:43 AM   #713
Petah78
Good pick up. I assumed the factory is the same reg oil. Good thing i left mine in there for 1600kms and drove it like a granny. I am only now starting to open it up more @ 2400kms.
Old 08-19-2022, 11:52 AM   #714
Code Monkey
Drives: Subaru BRZ
Here's mine, this is not the OEM fill, which I drained after 975 miles, but Motul 300V 5w-30 after three HPDE weekends. I though my copper level was high, but not worried anymore looking at the report above.
Code Monkey is offline   Reply With Quote
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
DarkSunrise (08-20-2022), DylanJZA (08-19-2022), JusTheG (08-19-2022), Petah78 (08-19-2022), Tcoat (08-19-2022)
oh no not again
Search this Thread:
Advanced Search
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
