86WORX
Old 08-21-2012, 02:24 PM   #15
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
Even with TRC and VSC off, the car still seems to attempt to pulse the wheel that is in the air, you can hear the VSC pulsing and a shuddering noise.. Obviously one wheel is in the air, but surely turning all the aids off should fix this?
You can clearly see the TRC/VSC light flashing on the dash, however note that the aids are all OFF (lights on the other part of the dash)
[ame="http://www.youtube.com/watch?v=L6VwJsSldV0"]Toyota 86 Scion FR-S Subaru BRZ VSC noise (all aids are OFF) 86forums.com - YouTube[/ame]
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
The Following User Says Thank You to WTF For This Useful Post:
civicdrivr (08-21-2012)
Old 02-20-2014, 07:53 PM   #16
Zechs21
Drives: CBS Subaru BRZ
Sorry to revive this old thread, but has anybody found a fix to this issue? At first I thought I was scraping something underneath but it seems that this is the issue. I turned the traction completely off by holding down the button for 5 seconds but I still get the grinding noise when I pull up to my driveway from the side.
Zechs21 is offline   Reply With Quote
Old 02-20-2014, 10:17 PM   #17
twag4
Drives: frs
It's normal. The torsen limited slip works to a 4:1 ratio. When going very slow, the inner wheel turns very slow compared to the outer wheel. I believe at the slow speeds the inner tire just gets drug a bitcausing it to skip. It also makes that growling noise. The owner's manual says it is a normal characteristic. Mine does it too.
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
Zechs21 (02-20-2014)
Old 03-13-2014, 08:30 PM   #18
mission2toilet
mission2toilet's Avatar
Originally Posted by jm1681 View Post
This happens to me EVERY time I pull up my driveway, but only from one side. Basically, I need to slow down a LOT to pull up without scraping my front end. In doing so, when I go to pull up the driveway (VERY cautiously, with a bit of slip and VERY light throttle) the rear tires spin for a fraction of a second (Hardly a chirp), and a pretty horrid noise comes from the rear.
Not sure if it's the diff, or something related to the traction control, or both, but I was just wondering if anyone else has experienced anything similar. For all I know, it could be totally normal, I just want to be sure I'm not cooking my diff.
My BRZ does it too but it's more like a pause. Like tire is on hold or something. It never did it before. I have 3300 miles on it now.
mission2toilet is offline   Reply With Quote
The Following User Says Thank You to mission2toilet For This Useful Post:
AteMyShorts (08-04-2016)
Search this Thread:
Advanced Search
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 05:55 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 10:27 PM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 06:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 04:21 PM
Rumble coming from rear end? No Quarter Scion FR-S / Toyota 86 GT86 General Forum 34 06-27-2012 03:14 PM
