Old 07-20-2022, 01:35 AM   #71
Originally Posted by Matt93SE View Post
GIVE ME STICK OR GIVE ME DEATH! I don't care if it's slower. Driving a GTR is like a freaking video game- it's just not real. turn the wheel, mash the gas mid corner, noise happens, flip little paddle on the steering wheel, different noise happens, brain smashes into the seat, car stays on track. no. unpossible!
Funny, because that's how a street GT-R is, but not the Racecar GT-R
blsfrs (07-20-2022)
Old 07-20-2022, 01:53 PM   #72
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by TommyW View Post
I've been using PowerstopTrackday pads since I started doing track days. I went through a set my first 3 days I now get 7 or more. I attribute it to better braking and general driving technique and not using the nannies.
In your humble opinion: What constitutes "better braking"?
Old 07-20-2022, 03:35 PM   #73
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Thinking back, I'd say it's spending less time on the brakes and rolling more speed through the corners.
The Following 2 Users Say Thank You to TommyW For This Useful Post:
blsfrs (07-20-2022), CSG Mike (07-20-2022)
Old 07-22-2022, 02:02 PM   #74
blsfrs
blsfrs's Avatar
I know that I'm beating this thread to death but, if you are spending less time on the brakes, that would imply that you are braking harder for a shorter period and which seems to be contributing to longer pad life. Correct?
Old 07-22-2022, 02:50 PM   #75
TommyW
TommyW's Avatar
less time on hard braking. Hitting hard then rolling off right away but smoothly and carrying more speed into the corners rather than staying longer at max braking and causing all sorts of weight management issues.
blsfrs (07-22-2022), ZDan (07-22-2022)
Old 07-22-2022, 03:25 PM   #76
ZDan
ZDan's Avatar
Drives: '23 BRZ
What he said ^^^. I've seen speed traces where some are able to get more OFF the brakes earlier and make up 2-3 tenths in some corners relative to drivers in similar cars trail-braking deeper into the turn.
blsfrs (07-22-2022)
Old 07-22-2022, 06:49 PM   #77
TommyW
TommyW's Avatar
it’s amazing how much faster it is to have the car balanced in turns rather than entering with your hair on fire and then trying to hit the apex
The Following 4 Users Say Thank You to TommyW For This Useful Post:
bcj (07-23-2022), blsfrs (07-23-2022), treedodger (08-09-2022), ZDan (07-22-2022)
Old 09-07-2022, 06:30 PM   #78
andyk5
Drives: GR86
Rounding up the thread here, Bought XP12s and did 4-5 track days. Still have half the pad. Initial bite is meh but does stop better than stocks and lasts 5x more. Squeaks pretty bad even after proper bed in, which wears off after a week of daily driving.
Next I am gonna try CSGs. I have a feeling I won’t get the bite I am looking for until I get BBK.
andyk5 is offline   Reply With Quote
Old 09-07-2022, 07:07 PM   #79
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
BBK is more heat capacity, not more bite. If you are getting more “bite” from BBK it probably shifted brake bias forward some. Try different pad compounds. I hated carbotechs.
NoHaveMSG is online now   Reply With Quote
Old 09-07-2022, 09:40 PM   #80
andyk5
Drives: GR86
That actually makes sense, though i thought more pistons and greater pad area would help with bite as well…I mean physics says given everything else the same, increased are would be multiplied with the same k constant(which changes after the initial bite), providing more immediate resistive force.
Old 09-07-2022, 10:04 PM   #81
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
More pistons doesn't equal more piston surface area applying clamping force.
The chart in this link is known to have some errors but will give you an idea.
https://www.pointmeby.com/2016/09/24...z-frs-gt86-86/
Pad area doesn't equate to more clamping force applied to the rotor, the force per square inch is actually less on a larger pad vs smaller pad given the same clamping force.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
andyk5 (09-08-2022)
Old 09-07-2022, 10:09 PM   #82
ZDan
ZDan's Avatar
Drives: '23 BRZ
For me, CSG C2 >>> Carbotech XP10 for "bite". Also they last a lot longer. Started running them a couple of years ago and while initial $$$ is high, they last long enough to offset that. Even if they didn't I greatly prefer them to anything else I've run at the track. With the PP Brembos I get like 18 track days out of 'em? Unreal...
Old 09-08-2022, 02:05 PM   #83
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Almost every track pad is going to squeal on the street. The compounds are designed to work starting at several hundred degrees, not 50-200F like you usually see during street driving. Using race pads at these temps wears off all the pad materials embedded into the rotor via abrasive friction instead of adhesive friction like when they're warmer-- you're essentially stopping the car with a brick mashed onto your rotor (this is why you use the outlap to warm up the car which includes getting the tires and brakes up to their happy temperature range. ).
Track pads for the track, street pads for the street.
Matt93SE is offline   Reply With Quote
Old 09-09-2022, 02:43 PM   #84
Tokay444
Anti stance.
Tokay444's Avatar
Love the initial bite and firm pedal of my CGS C1/C11 combo.
Search this Thread:
Advanced Search
PMU NS400 front pads, StopTech Street rear pads, Motul RBF600 fluid Darth Vaden Brakes, Suspension, Chassis 1 06-17-2022 09:27 PM
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
Safe oil temps for daily driving and spirited driving off the track? MilkyWitness Engine, Exhaust, Transmission 15 06-12-2019 09:21 AM
Interior Red Stitched Knee Pads Door Pads 2016 brz limited Rear View Mirror sokol Interior Parts (Incl. Lighting) 11 12-25-2018 10:37 PM
First time driving manual, some questions after one month of driving kyto31 Engine, Exhaust, Transmission 10 06-24-2018 11:57 AM
