Old 06-29-2022, 11:50 AM   #15
waterpanda
Heard back from Perrin - they reckon it's the diffuser obstructing airflow + muffler placement + high EGTs.
In any case, they were kind enough to ship out free replacements.
Next track event is NASA @ Lime Rock Park - Jul 8-9, going to try heat-wrapping the muffler as well as try doing the same as what the guy did with his Focus (wrap the hangers themselves in heatwrap and apply steel band around it). Bringing extra hangers just in case and check them after every session. Will report back
waterpanda is offline   Reply With Quote
The Following User Says Thank You to waterpanda For This Useful Post:
Ohio Enthusiast (06-29-2022)
Old 06-29-2022, 12:02 PM   #16
Ohio Enthusiast
Drives: 2018 BRZ
This sounds like the best solution to me. The reduced airflow means you probably can't do anything with convective heat (as the air in the cavity will get hot no matter how much you insulate the exhaust), but you can fight radiative heat by foil shielding the hangers.
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
waterpanda (06-29-2022)
Old 06-29-2022, 02:04 PM   #17
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I remember reading a post about a guy developing underbody aero for his car and he kept melting poly hangers so he went back to rubber hangers.
The poly hangers are the likely issue.
I *think* it was this thread: https://www.1addicts.com/forums/show....php?t=1713247
edit: it was indeed that thread, see the post here https://www.1addicts.com/forums/show...0&postcount=67
DocWalt is online now   Reply With Quote
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
CrowsFeast (07-11-2022), waterpanda (06-29-2022)
Old 06-29-2022, 02:29 PM   #18
waterpanda
This is super insightful, thanks for sharing. I actually have the rubber OE mounts on right now, going to give the rubber ones a try with the above-mentioned mod.
Old 06-30-2022, 01:38 PM   #19
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Cheat code: if the factory rubber hangers aren't quite stiff enough to hold everything in place, I've used cheap metal hose clamps around the hanger to limit the stretch of the rubber.
see if this random interweb photo link works:
Matt93SE is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt93SE For This Useful Post:
ka-t_240 (07-01-2022), waterpanda (06-30-2022)
Old 07-04-2022, 08:24 PM   #20
waterpanda
Reinforced rubber bushings are on the car now - gonna see how it holds up this week at LRP!
Old 07-04-2022, 08:34 PM   #21
Ultramaroon
fabulous
Ultramaroon's Avatar
I suggest, instead of zip tie, a smidge of safety wire or a little improvised clip made from a piece of coat hanger. Dunno, maybe the zip tie will hold up. Good stuff!
DocWalt (07-05-2022), waterpanda (07-05-2022)
Old 07-08-2022, 06:06 PM   #22
waterpanda
Update: Great day at LRP today with NASA, both hangers holding up nicely after 4 sessions, no signs of deterioration so happy about that
The Following 4 Users Say Thank You to waterpanda For This Useful Post:
bcj (07-08-2022), CrowsFeast (07-11-2022), Ohio Enthusiast (07-08-2022), Ultramaroon (07-08-2022)
Search this Thread:
Advanced Search
OEM Exhaust hangers nikitopo Engine, Exhaust, Bolt-Ons 0 10-07-2021 12:27 PM
Perrin exhaust with added benefit of melted plastic s30series Engine, Exhaust, Transmission 3 09-12-2014 09:44 PM
Exhaust Hangers FrSnake Engine, Exhaust, Transmission 11 01-20-2014 02:45 PM
exhaust hangers jazztennor Engine, Exhaust, Transmission 7 02-19-2013 10:57 AM
Exhaust hangers yomchi1989 AUSTRALIA 4 12-01-2012 02:15 AM
