#15 |
Do you not have adjustment in the rear?
#16 |
Barred
Drives: My18 wrxsti My19 brzts
I increase neg camber about 0,5 a side(about -3.7) at the track. Can`t say I notice a toe change and car turns in stronger/crisper/nicer/harder( not sure of the word to best describe). Tires definitely approve wear wise.
Wait until my Flex capacitor hits 88
#17 |
Drives: '23 BRZ
#18 | |
Drives: Crapcan
Front toe doesn’t change much with camber with Mac strut. Going more negative probably toe’d it in a touch which would be less noticeable if it went out. The rear changes a lot when you adjust camber.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | gen3v8 (07-01-2022) |
#19 |
Drives: 2013 FR-S, 2017 BRZ
My findings-- front grip isn't all about front camber. I spent most of last season trying to find more front grip- new SPL control arms, crash bolts, etc etc etc, I was getting about -4.5 camber up front and was maxed out before I rubbed on stuff inside the wheel well.
I tried crash bolts first, and my sway bar endlinks started hitting the frame rails after installing the crash bolts, so I removed the crash bolts and bought a set of SPL FLCAs and tie rod ends. I got the FLCAs set up nicely- no bump steer, roll center in a happy place, etc etc. roughly -3.5 to -4 camber, which was more than I had before with crash bolts. next race, the understeer/overall balance was marginally better but I did have more front grip. still angry about the understeer tho. A fellow racer suggested I stiffen up the rear sway-- sometimes the trick to obtaining better balance is by reducing grip on the stuck end, not by increasing the grip on the sliding end.. Sooo, I stiffened up the rear sway a notch from where it was when I bought the car (assuming it was set up correctly to begin with...) HORRY SHEET WHAT A DIFFERENCE! suddenly the car rotates mid-corner as I roll into the throttle and I can steer the exit with the rear... overall grip has even improved-- on the long sweepers I used to have to feather the throttle around 25% to keep the front end from washing out, I can now take same corner about 90% throttle and accelerate through the sweep and STILL have some steering wheel to point the car. Niiiiice. Same tires, same day, same conditions otherwise-- I dropped over 1.8sec on the next session and lowered the track record by 1.5sec. ![]() I didn't take tire temps after, but the results on the clock are obvious and the tire wear on the outer shoulders was much better. Sooo ummm, maybe you could consider looking at what you're doing in the rear and try to stiffen it up a little, vs more and more camber up front. Just my $0.02.
#20 | |
![]() A larger rear sway does not just reduce rear grip...you do get more evenly loaded front tires which is good and means more front grip. Not the magic solution for everyone or every car, but it can definitely work for some when done right. - Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | treedodger (08-16-2022), ZDan (07-07-2022) |
#21 |
Drives: '23 BRZ
Exactly!
| The Following User Says Thank You to ZDan For This Useful Post: | Racecomp Engineering (07-07-2022) |
#22 | ||||
Drives: '23 BRZ
![]() Quote:
| The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (07-11-2022) |
#23 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#24 |
These cars don’t come with enough front roll stiffness from the factory. Stiffer front end helps mitigate camber loss due to body roll and thus tends to improve front grip a small amount while increasing responsiveness, net win.
#25 | |
Drives: '23 BRZ
#26 | |
I have some Whiteline RLCAs on my car, and there are multiple holes for both shock and sway bar mounts. Thus I have additional spring and sway bar rate adjustments by moving the bar through those holes. Just a thought you might be able to stiffen the rear up a lil more with something like that vs. reducing front bar. As mentioned elsewhere, "more total bar" increases overall roll stiffness. since you're on a spring/shock combo, you are already compromising body roll compared to a coilover with track-oriented spring rates. thus you need even greater roll stiffness )on both ends) than a car with stiffer springs in order to keep the body lean in check. |
| The Following User Says Thank You to Matt93SE For This Useful Post: | ZDan (07-08-2022) |
#27 | |
The data didn't really show any increase in peak cornering Gs, but the car definitely handled better and I was able to carry more speed in the long sweepers and rotate the car at/after the apex. initial turn-in was never a problem with either setting, but mid corner and exit suuucked once I got off the brakes and took weight off the nose. I use to have to ride the curbs afte the apex to make the car rotate past the apex, but now if I do that, it'll unload the inside rear and then it REALLY rotates after the apex!
#28 | |
You did in fact significantly increase front roll stiffness relative to the rear. |
| The Following User Says Thank You to strat61caster For This Useful Post: | ZDan (07-08-2022) |
| SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 02:43 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 02:10 PM |
| Good static front/rear camber for street and track? | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 03-28-2014 11:48 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 04:40 PM |
