go_a_way1
Old 04-15-2013, 02:45 PM   #1191
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by rmz290 View Post
What about OZ 18x9's with an offset of 51 on stock suspension? I'm guessing I would have to use a 10 mm spacer? Is this safe? These would be mainly for autocross and some trackdays. Tried searching but couldn't find much information.
So this is effectively a 18x9 +41 offset, should fit well for a stock suspension.
However...
I'm not at all a fan of spacers over 3-5mm except for the bolt-on spacers which are usually much thicker than 10mm. That's means your lug nuts will grab onto the studs 10mm further out (how many threads will they even grab?).
If you have the ability to do a test-fitting, I would try it first and perhaps try a smaller spacer (5mm) and see if you clear. I wouldn't personally do a 10mm spacer on mine, but ymmv. 51 offset on its own will definitely not clear the strut though.
Edit: If you are only using these for autocross and track, I would strongly recommend not using any spacers and finding a proper sized wheel. For those applications, your best choices are a 17x9 wheel (lighter) and you'll have a better choice of sticky tires to choose from. Ideal offset would be around +40 in this size.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
ill86 (04-16-2013)
Old 04-15-2013, 02:57 PM   #1192
Slick
Slick's Avatar
Originally Posted by t00n3wb View Post
Im looking at Varrstoen Es 2 18'' would this fitment be a nice fit?
Front: 18x8 +30
Rear: 18x8.5 +31
Front: wheel will be inside slightly, very close to flush. Max tire 225 if you want to make this offset work.
Rear: pretty much the same, same tire size or if bigger will poke out.
If you want to go wider in tire size, I recommend looking at offsets closer to +40.
The Following 2 Users Say Thank You to Slick For This Useful Post:
ill86 (04-16-2013), t00n3wb (04-15-2013)
Old 04-15-2013, 11:57 PM   #1193
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
hey guys i found some drag dr-31's on craigslist that i would like to buy for drifting and autocross but they are 18x8 +45 offset. what do you guys think?
sweetfrs is offline   Reply With Quote
Old 04-16-2013, 11:09 AM   #1194
Slick
Slick's Avatar
Should fit nicely within the fenders provided you don't go crazy wide with tires.
sweetfrs (04-16-2013)
Old 04-16-2013, 04:28 PM   #1195
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
I always considered flush to be a perfect fitment.
I'm currently running 18x8.75 +33 all round. Some would consider this an 'OK' fitment, however there is too much poke up front.
This time, the goal is 'perfect flushness', not just an OK fitment.
The poke can be controlled some what by alignment. That is why I never tell others what is perfect because it is a subjective term from the eye of the beholder.
So if we say flush is perfect, which I would agree with you, alignment settings are also crucial to the fitment equation.. And alignment settings are a personal preference. Like arguing what the best oil is. Or best tire maker, etc. Subjectivity and brand loyalty muddy the discussion waters. :-)
Peace
ill86 is offline   Reply With Quote
Old 04-16-2013, 04:32 PM   #1196
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Slick View Post
+47 on that width of wheel would put it very close to the stock strut (if not against it), but if you are moving to coilovers you will have additional clearance inboard but you may rub the sway bar on tight turns. I.e. coilovers first, then wheels. Or find a set of these wheels to test fit first.
Maybe others can chime in better in terms of inside clearance, but I see no issues with poke with this setup, should be less than flush on the front.
I think on the rears you will be fine even without coilovers.
8.5" +47 is not good fitment IMO. It is too close to the inside as you clearly state.
Old 04-16-2013, 09:49 PM   #1197
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
i dont even know what tires would be good for autocross, i am a newbie in the autocross world lol
Old 04-16-2013, 10:23 PM   #1198
Slick
Slick's Avatar
225/40/18 is ideal then.
Old 04-16-2013, 11:19 PM   #1199
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
what brand do you think would be ideal?
Old 04-16-2013, 11:35 PM   #1200
Slick
Slick's Avatar
There are a few hot tires, look at the Hankook RS3, Kumho Ecsta XS, Dunlop ZII, Bridgestone RE11, and the new BFG G-Force Rival to name a few...
Depends on your budget, and if they will also be DD tires.
Check TireRack.com for the many choices and reviews.
ill86 (04-16-2013)
Old 04-16-2013, 11:55 PM   #1201
ill86
ill86's Avatar
Drives: iG FR-S
Yokohama ADVAN AD-08
but, don't run them because I do. The fewer number of people using them the better it is for me.
lots of good ties out there. What brand do you like?
I teach Motorsport professionally. Happy to make a few recommendations.
Old 04-17-2013, 12:02 AM   #1202
RavSpec
Drives: Rx7
Subscribed .
Pm me if anyone need fitments info.
Have BRZ myself and have tried countless wheels
RavSpec is offline   Reply With Quote
Old 04-17-2013, 12:11 AM   #1203
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by RavSpec View Post
Subscribed .
I'm wondering if I'm going to need at least a 3mm spacer up front for the set I ordered from ya... Might end up buying some 5-10mm's for the rears, but kinda worried about maybe not clearing up front and having to scramble some up 3 days before an event.(when I hit us soil). If you ever get the chance to throw one up front in the sizing I ordered could you let me know how the clearance is? I'm sticking 245s up front aswell...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-17-2013, 12:50 AM   #1204
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
they are going to be strictly for autocross
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
