go_a_way1
Old 09-27-2019, 12:34 AM   #4131
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Will BRZ View Post
Is it true that tire size 225/40/18 has a difference of 0.47 in. (1.9%) from stock diameter while the larger tire size 245/35/18 only has a difference of 0.13 in. (0.5%)? I was on this tire size calculator website and found that pretty interesting. I’ve decided on wheel choice finally just debating 17s or 18s. I’d like to stay as close to stock as possible for speedometer accuracy, overall height etc.
Yes, you are correct. A 245/35/18 is closer to OEM diameter than a 225/40/18. The general rule of thumb for tire sizing is plus or minus 3% different from stock is ok.
I'm running 245/35/18 square. It's a sweet spot for width, weight, and diameter.
I LIKE TIRES!
Will BRZ (09-27-2019)
Old 09-27-2019, 12:47 AM   #4132
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Thanks! That’s good to know. What’s the width of your wheels? Springs should be coming in soon so I think 8.5 is about where I want to be.
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
Leonardo (09-27-2019)
Old 09-27-2019, 12:55 AM   #4133
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x9 +42 with spacers making them +30 front +27 rear. They fit with springs. -2 rear natural camber and -1.4 front from just a set of camber bolts. I'm on coils now though.
18x8.5 is a good size, what's the offset?
If I had things to do over again I think I would get bilsteins for the Eibach springs, LCA, camber bolts, and a bumpsteer kit. I feel this would have been a great street setup.
I LIKE TIRES!
Old 09-27-2019, 01:08 AM   #4134
Will BRZ
Drives: 2015 BRZ
I think they were +44, if I remember correctly. That might be what I’ll do and just piece everything together one by one. Not looking for a super aggressive setup or a track setup. Just a good looking, functional, daily driver.
Old 09-27-2019, 01:35 AM   #4135
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Those are a good size. 18x8.5 +44 is functional and conservative. 245/35 will sit squarely on a 18x8.5 for a meatier look. 225/40 is also a good size, they would give you a slight stretch, there are more tires to choose from, and they are cheaper.
Your wheels will be sunk in 20mm in the front and 23mm in the rear compared to my wheels.
I LIKE TIRES!
Old 09-27-2019, 02:00 AM   #4136
Will BRZ
Drives: 2015 BRZ
I really appreciate your help. I like the sound of the 245/35. I’d rather the wheel be sunken in than to poke honestly. Wouldn’t really bother me. Especially knowing it’s so close to stock diameter. Thanks again
Old 09-28-2019, 05:52 AM   #4137
Firedrops
Drives: MY15
For 18" wheels, square set-up, what would be the maximum width and offset that the rear can take with coils at ~stock height? Might do very slight camber, up to ~-1.5 front ~1.0 rear.
I'm thinking of getting custom wheels made and a possibly +20mm aftermarket front fender, want to know my upper limits.
Firedrops is offline   Reply With Quote
Old 10-03-2019, 12:42 PM   #4138
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Max rear width custom made wheels? Here are some for sale!
https://www.ft86club.com/forums/showthread.php?t=136926
I LIKE TIRES!
Old 10-12-2019, 09:01 AM   #4139
Firedrops
Drives: MY15
18x10.5 +50, +3mm spacers... so the stock rear fits 18x10.5 +47mm? daaaaayum
Old 10-23-2019, 04:06 PM   #4140
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by 86TOYO2k17 View Post
That is why I'm using a very uncommon 4mm spacer, which i heard leaves enough turns/threads to be fine and that 5th mm is what puts it over the top to not have enough.
Just an update to an earlier post,
Installed 17x9 +45 255/40R17 in rears, i am using a 4mm hubcentric/wheel centric spacer with 100% stock suspension. Plenty of room between tire and strut/spring perch.
Tire is flush to outside of fender.
Also the 4mm spacer still allowed lug nut 8 1/4 turns once torqued to 90 ft lbs.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Leonardo (10-23-2019)
Old 10-23-2019, 04:12 PM   #4141
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What brand and model 255/40 tire?
I LIKE TIRES!
Old 10-23-2019, 04:37 PM   #4142
Will BRZ
Drives: 2015 BRZ
Do you have pictures of that setup? Are you planning to keep the suspension stock?
Old 10-23-2019, 09:34 PM   #4143
86TOYO2k17
Rear is Michelin pilot sport a/s 3+ on advanti dst storm 17x9 +45 W/ 4mm spacer.
Front is Same but 225/45r17 on 17x8 +35 no spacer.
Old 10-23-2019, 09:39 PM   #4144
86TOYO2k17
I bought rear LCA, front camber bolts, and had RCE yellow on back order but after 2 months got impatient, refunded springs and bought rear rims + 4 tires.
But now I'm thinking tein flex A coils sometime later, still got LCA and bolts.
Maybe once i get around to selling my old but still new tires i just took off and 2 rims ill buy them.
Ill get some pics later.
Will BRZ (10-23-2019)
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
