go_a_way1
Old 07-28-2019, 02:02 AM   #4103
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Originally Posted by lumbeardjack View Post
suspension stays stock until I can get out of the part of town with curbs to go over and pot holes. I'm planning on wheels and tires at the same time just because I see dealers mount and balance for free and I do want to keep my original stock wheels for when I do decide to do something risqué
Cool same here, but I’ll probably do coilovers at the same time even though roads here suuuuuck lol Fitment Industries is such a great resource. Both their website and YouTube channel provide excellent information for anyone looking to buy wheels for the first time.
Will BRZ is offline   Reply With Quote
Old 08-07-2019, 11:45 PM   #4104
sukumizu
sukumizu's Avatar
Drives: 6MT '15 BRZ | '89 240sx (sold...)
I'm pretty set on Enkei RPF1s, thinking of going 18x8 + 35 on all four wheels. How well will this line up with the front and rear fenders?
Most of the pictures I'm coming across are for 9.5s +35/38...
la cocaina is not good for you
ig: sad_fa20
sukumizu is offline   Reply With Quote
Old 08-08-2019, 05:24 PM   #4105
jRuN
Hey guys.. i'm looking at picking up these wheels in
18x9.5 they come in a +35 offset.
Stock suspension. Will they fit? Flush look? Will i be able to throw on coilovers down the road and lower it at all?
https://esrwheels.com/products/sr01
jRuN is offline   Reply With Quote
Old 08-09-2019, 10:29 AM   #4106
Vital
Drives: 2015 BRZ
It will fit fine. Just keep in mind the front will have a little poke, but the back should be pretty much flush with the fender. Check out the second page on this thread to see the fitment. http://www.ft86club.com/forums/showt...t=20872&page=2
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
sukumizu (08-09-2019)
Old 08-09-2019, 10:32 AM   #4107
Vital
Drives: 2015 BRZ
Those are pretty wide for stock suspension. It will fit on stock with a 235/40/18 tire in the front the rear is not going to be an issue. Yes, you will be able to run this size with coilovers, ideally get the coilovers first if you can. With coilovers you can get a tire size of 245/35/18 or 255/35/18.
This thread should help you out. https://www.ft86club.com/forums/show....php?p=3097900. Even though its a +38 offset it close enough to a +35.
Leonardo (08-09-2019)
Old 08-09-2019, 05:41 PM   #4108
sukumizu
sukumizu's Avatar
This is great, thanks!!
ig: sad_fa20
The Following User Says Thank You to sukumizu For This Useful Post:
Vital (08-10-2019)
Old 08-30-2019, 11:18 PM   #4109
x_hawker
Drives: 2013 FR-S 10-Series
Location: SJ/OC/IE California; Temporarily: Glendale,AZ
Hello everyone, I am planning to pick up RPF1's in SBC in 17x9 +35 as that is the narrowest width they have in a 17" size.
I would like to keep the tire width as narrow as possible as I understand my car is quite under powered. I am thinking 235/45/17 or 235/40/17 or 245/40/17. I am unsure how the choices will affect the performance of the car, and I do know that the 235/45/17 will result in a the car sitting higher / more ground clearance.
Based on my understanding, a tire with a taller sidewall does not perform as well as a tire with a shorter sidewall in a motorsport setting. I am unsure what the pros and cons are of having a taller vs shorter sidewall. Does anyone have any insight on this?
x_hawker is offline   Reply With Quote
Old 09-05-2019, 02:17 AM   #4110
Ciriously
Drives: FR-S 10 Series
I have done so much research and I'm still confused on something... will this combo rub on stock suspension?
18x8.5 +45 wheels with 245/35/18 tires?
Ciriously is offline   Reply With Quote
Old 09-05-2019, 12:17 PM   #4111
Vital
Drives: 2015 BRZ
It will fit fine. Just know you will be close to the spring perch though
The Following 2 Users Say Thank You to Vital For This Useful Post:
Ciriously (09-05-2019), Leonardo (09-05-2019)
Old 09-05-2019, 06:12 PM   #4112
Ciriously
Thank you! Would a different size tire be better or a different offset?
Old 09-05-2019, 06:30 PM   #4113
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I would get +35 offset if its available. Then you could add camber bolts in the front and the back will sit flush.
245/35 will be square looking on the 8.5" wheel. I'm running 245/35 on 9" wide wheels and they are slightly stretched.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Ciriously (09-06-2019), Vital (09-05-2019)
Old 09-05-2019, 07:04 PM   #4114
Glitchy86
Drives: Red 86
So as turned out where I live 245/40R17 are the most rare size tiers ever.
Does anyone know if I can fit 235/45R17 on stock car with Eibach pro kit lowering springs and front camber bolts? My wheels are 17×9 +38.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 09-05-2019, 11:54 PM   #4115
Vital
Drives: 2015 BRZ
You can try ordering them from tirerack.com. Yes, 235/45/17 will fit fine with Pro-Kit and those wheels. You'll actually get a little more clearance and gain more camber since the 235/45 tire wont be as wide as the 245/40.
Old 09-06-2019, 02:04 AM   #4116
Glitchy86
Drives: Red 86
The problem is that I don't live in the US and international shipping is very expensive.
As long as the 235/45R17 will be good and won't fuck up the gearing much I guess I'll go with it.
Thanks.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
