#4075 | |
Drives: 2015 BRZ
#4076 |
Hi Leonardo,
Would I have rubbing issues on the ff setup: - 18x8.5 +42 57xtreme - eibach prokit Looking at either 245/40/18 or 235/40/18. Also, i was hoping i wouldnt have to stretch the tire but wouldnt want rubbing issues either. Thanks! Sent from my SM-G955F using Tapatalk |
| The Following User Says Thank You to Foreplay For This Useful Post: | Leonardo (06-06-2019) |
#4077 | |
Drives: 2015 BRZ
| The Following User Says Thank You to Vital For This Useful Post: | Leonardo (06-06-2019) |
#4078 | |
Country Boy 4 Life
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Vital (06-06-2019) |
#4080 | |
#4081 |
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
I’ve tried to do my research, but I’ve never bought aftermarket wheels before.
Will this setup have any issues? Or rubbing? Or any extra pieces like camber bolts or certain alignment I might need for it? 18x8.5 with +37 offset 245/35/18 Eibach Sportline lowering springs (-1.4” front/-1.4” rear) Thanks guys! |
#4082 | |
Drives: 2015 BRZ
| The Following 2 Users Say Thank You to Vital For This Useful Post: | DriveDriftDogfight86 (06-10-2019), Leonardo (06-12-2019) |
#4083 |
Drives: 2017 Pure Red BRZ w/ Perf Package
Will this fit comfortably? My friend is getting rid of his TE37’s in about a year and giving me a good deal on them.
18x9.5 +35 Volk TE37SL’s while being dropped 1” on Eibach Pro-kits on stock suspension. I’ve used the wheel calculator for fitment and it seems to check out. I’ll be running about -2 camber on the fronts to avoid too much poke since the +35 is a bit much. I definitely want to avoid rubbing at full lock. I wouldn’t have to worry about spring perch clearance with a +35 will be running 245/35/18 MP4S or MPSS tired. Is there anything else I should be worried about? Coilovers and adjustable LCA’s are for later in the build since my shocks are still pretty new. |
#4084 | |
Country Boy 4 Life
I LIKE TIRES! Last edited by Leonardo; 06-12-2019 at 09:41 AM. |
| The Following User Says Thank You to Leonardo For This Useful Post: | Vital (06-12-2019) |
#4085 |
I meant either -1 or -2 degrees in total while being dropped 1” since dropping normally adds camber. I’m guessing at that setup since I can’t add much front camber even with 1” drop, I’ll have a decent amount of poke at +35. Unless I go coils and then use the camber bolts to tuck in the poke properly. Ahh so many things to account for.
#4086 | |
Country Boy 4 Life
My 18x9 +42 wheels have basically the same inner clearance to the spring perch. Your 18x9.5 +35 is only going to be 0.7mm further away from it. So you will have something like 3mm to 5mm clearance in the front. I installed a 10mm spacer in the front to be able to add camber. Then I added coils to be able to add more camber and a 15mm front spacer. You will want/need coils to "dial" those wheels in.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Skyehigh55 (06-12-2019) |
#4087 | |
| The Following User Says Thank You to Skyehigh55 For This Useful Post: | Leonardo (06-12-2019) |
#4088 | |
Country Boy 4 Life
I think at a minimum will also want LCA; spc, moog, whiteline are all lower cost and will work great! I also highly suggest the bumpsteer kit. It really makes a difference. I installed all the other parts first, then the bumpsteer kit; it gave the car a more solid planted feel. LCA are good because after lowering 1", my natural rear camber was -1.8 left and -2.2 right. This did not cause uneven tire wear, but it looked funny to me. For my rear setup I got: Coils - FA 500's lowered - 1.25" LCA - Blackworks Billet -3.0 rear camber J2 Trailing arms - these center the rear wheel front to rear in the wheel well after lowering J2 Toe arms - adjusts toe back to zero For my Front: Coils- FA 500's lowered - 1.25" Camber bolts - SPC - with these bolts and my tophats I have -2.5 rear. Whiteline Bumpsteer / roll center kit - fixes suspension geometry after lowering - suggested for setups lowered more 1" or more. I am about to change my alignment to -3 front and -2.5 rear, which is better than my current spec. I also got endlinks and sways, but they are not necessary to make the wheels fit like you want.
I LIKE TIRES! |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
