#3795 |
Country Boy 4 Life
That's a colloquialism I'm not familar with.
I LIKE TIRES! |
#3796 |
Country Boy 4 Life
Welcome to the forum.
They will poke a bit. About the same as 18x9+35. 225/40 would work good on stock. Get camber bolts. With +30 offset wheels, you will have room to add camber in the front with stock springs and lowering springs. (If you decide to get some) Good luck!
I LIKE TIRES! |
#3797 | |
Drives: '13 BRZ Limited
Thanks for the info. I know the RCE yellows/stock shocks make things more difficult...
I ended up being able to measure clearance before the weekend. Looks like I have 12.5mm of space to the springs with the stock 17x7 ET48 wheels. Going to ET42/17x9 is going to result in about 7mm of interference with my current setup. I'd need to put about +2 deg of camber at the bolts to get it to clear - but I only have about 0.8 left in the plates - so that would be a 1.2 deg camber loss (would go from about -3.3 to -2.1). So... ET42 is not going to work for me without spacers - and I'd rather not have to run spacers. ET35 means there is ~0 clearance but it should just fit - I can remove a bit of camber at the bolts to give some margin and have a little adjustment left on the camber plates... Will probably go that route... Quote:
#3798 |
Drives: 2017 Toyota 86
Hello everyone, I have a 2017 86 with TRD lowering springs.
I'm very close to ordering: 18" Work emotion kiwami wheels with a 38mm offset and 235/40/18 tires. Will this work with the TRD springs without rubbing? I checked the wheel fitment thread but only saw that this setup would work with coilovers. I don't know if it will work with TRD springs. |
#3799 | |
Drives: '13 FRS
| The Following User Says Thank You to Grisha For This Useful Post: | HachiRokuX (06-09-2018) |
#3800 | |
How about 17x9 wheels with a 35mm offset and 235/40/17 Or 18x7.5 with 35mm offset and 225/40/17. Would spacers help the work emotion kiwami fit on lowering springs? This is so frustrating, I won't change wheels if there is no real upgrade in looks/grip (I know grip depends more on tire compoudthan width). Edit: also, this guy say 18x8.5 and 225/40/17 will fit but I'm not sure. https://www.reddit.com/r/ft86/commen...ock_coilovers/ Last edited by HachiRokuX; 06-10-2018 at 02:58 AM. |
#3801 |
All of those will fit with gobs of extra room.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| The Following User Says Thank You to 15limited For This Useful Post: | HachiRokuX (06-11-2018) |
#3802 | |
Thank you, just to be clear, you meant: 17x9 +35 and 235/40/17 18x7.5 +35 (or +38) and 225/40/18 will fit on trd lowering springs? I might just get the work emotion kiwami wheels in 7.5 size and +38 offset instead of 8.5 in that case so I can fit the 225/40/18s a little better. I don’t really plan on tracking or autocrossing too much or anything, it’s mainly just for daily driving where I don’t really need too much width. Only thing that sucks is the 18x8.5 and 18x7.5 work emotion wheels are the same price. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to HachiRokuX For This Useful Post: | 15limited (06-12-2018) |
#3803 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
How wide can I go without rubbing?
stock BRZ tS. 17x9 35 offset. Right now runnig 235/45/17 but it looks like I have a lot extra space. 245? 255? 265? Would have I have to lower to 40 side wall? |
#3804 |
I ran 245/45, 245/40 stock dampers and was really close to the spring perch, with maxed out camber bolts, super down drop springs. Then ran 255/40 with coilovers on the same wheels,but now I'm on 18x9.5 and at 265/35.
| The Following User Says Thank You to 15limited For This Useful Post: | Elliotw (06-12-2018) |
#3805 |
Drives: 2019 Toyota 86
Will 225/45R17 tires fit properly in the wheel wells and will the speedometer need to be recalibrated for it?
#3806 |
Drives: 2014 GT86
Yes, no.
It's possible to fit much larger tires. By silent manufacturer convention speedos for all non retro cars lie. With slightly larger tires it will lie a bit less .
#3807 | |
#3808 |
Drives: 2014 GT86
"Depends".
How you will drive? DD or track or autox? Will you go for built engine/high boost/lots of power? Then i'd probably look for wider tires. Though going for much wider tires may ask for wider wheels too. For NA build or mild boost 225/45/R17 might be ok. Of grippier tire model then stock primacies though. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
