#3711 | |
A Nobody
Drives: FRS
lol
#3712 | |
Country Boy 4 Life
Well, then... I would say. If your budget is big, get coilovers. (greater than $1000) If not get 1" drop springs and camber bolts. 1" drop give a lower ride height with out sacrificing: drivability, the stock shocks life span, or comfort. And is budget friendly. I got both for $250 and installed them my self. There is a amazing DIY on how to install springs in the DIY section.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | JustSomeGuy (03-14-2018) |
#3713 | |
A Nobody
Drives: FRS
| The Following User Says Thank You to JustSomeGuy For This Useful Post: | Leonardo (03-14-2018) |
#3714 |
Drives: '13 Black BRZ
Hey guys,
so I have 18x8 et34 and 18x9 et34. I was thinking about doing 235/40/18 for the front and 255/35/18 for the rear. I'll also be on coils and plan on lowering about 1". I don't have LCA's, and I'm hoping to not rub or roll fenders. Anyone know if I should have any problems? Last edited by Hussbuss; 03-16-2018 at 03:37 AM. |
#3715 |
MTXclusive
Drives: 2017 Toyota 86
Would 17x9 +45 clear? Tire size? I am currently on stock struts I will be getting coilovers in the near future. Thank you.
2017 Toyota 86 l Progress/Build/Update Thread
#3716 | |
Country Boy 4 Life
I'm running 18x8 +35 and 18x9+37. I have -1.5 front and -2 rear camber. With 225/40 front and 245/35 rear. I have a few mm before I rub. I think that you may rub on the fender in the rear with a 255 on a 18x9 +34. Also, a 235/40 will look fat compared to the rear 255. I'd go 225/40 to match the 255/35. 225/40 is the same diameter as a 255/35. I don't like how the 225/40 looks on my car. I am going 215/40 next time to match the diameter ( and stretch look) of my 245/35 rear tires. Why coils? Which ones? I'm lowered 1" on Eibach prokit springs (TRD are branded Eibach springs). I also have camber bolts in the front.
I LIKE TIRES! |
#3717 | |
Country Boy 4 Life
17x9 +45 does not really fit on a stock car. Though a 17x9 +42 does on most cars. So it is really really close to fitting. Either get a small spacer in the front for now( 3mm-5mm should do it), or get your coils first. You will not be able to run any camber with out more room by adding a spacer or getting coils. (no camber = No tucking the top of the tire under the fender) A few guys say they "fit". A few guys say they hit the tire rod at full lock. Most are going coils to fit this size in the front. I'd read through this. http://www.ft86club.com/forums/showt...t=32719&page=7
I LIKE TIRES! |
#3718 | |
MTXclusive
#3719 | |
Country Boy 4 Life
I said a 3mm to 5mm front will work. Not a 25.4mm spacer. Look at post 2299. http://www.ft86club.com/forums/showt...41083&page=165 He is running a 17x9 +42. I was surprised to see that a 255/40 did not rub. Because most times a 245/40 will be maxed out. Anyway, Is this is the look you are going for?
I LIKE TIRES! |
#3720 | |
Drives: 2015 Firestorm FRS
How about 17x9 +38 with 245/40/17 tires
Lowered trd springs? Need camber bolts in front? Will run like -1 to -1.5 front camber and -1 rear for daily drive Quote:
#3721 | |
I have a set of HKS Hipermax IV GT's on the way. I figured I'd lower an inch first, and then depending on how much tire is left, check and go from there on. |
#3722 | |
Country Boy 4 Life
I LIKE TIRES! |
#3723 | |
MTXclusive
#3724 |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
