#3697 | |
Country Boy 4 Life
http://www.ft86club.com/forums/showt...=28017&page=16 Read page one of the Meaty tire thread. http://www.ft86club.com/forums/showthread.php?t=41083 __________________
I LIKE TIRES! |
#3698 |
I have enkei rpf1 17x9 +35 on RCE lowering springs, bilstein b6, camber plates, and stock crash bolts.
I am soon going to get the Federal RSRR tires. They only come in 235 or 255 and I know they run a size wider than normal. Would 255 rub on my lowering springs? And if 235 is the way, then should I get 235/40/17, or 235/45/17? TIA |
#3699 |
Ok, so I plan on buying some Motegi MR127's. I want to double check that everything would work on stock FR-S and not have fitment issues, and how flush it would be. Its the Motegi Racing MR127 Satin Black Wheel (18x8"/5x100mm, +38mm offset). Also since this is my first time buying new wheels for my FR-S is there anything else that I should purchase along side of the wheels and tires (probably gonna be 225/40R18W)
#3700 | |
Drives: 2015 BRZ
#3701 | |
Country Boy 4 Life
It looks like 255/40/17 hankook RS-3's fit on 17x9 +35's with similar suspension parts. Post #18 http://www.ft86club.com/forums/showt...=100400&page=2
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | norcalpb (03-06-2018) |
#3702 | |
So getting 235s, will I need 235/40 or 235/45? |
| The Following User Says Thank You to norcalpb For This Useful Post: | Leonardo (03-06-2018) |
#3703 |
Country Boy 4 Life
235/40. 100%
I LIKE TIRES! |
#3704 |
A Nobody
Drives: FRS
dont know where to properly ask this dumb beginner question but if i lower my car on stock wheels, then get new ones will new wheels affect the camber? i have decided on what wheels but they would be wider and +35 offset range over stock but curious about lca
#3705 |
Drives: 86
With the Rocket Bunny v1!
Front: Rim Specs 18x9.5 +30 25mm Spacer 2inch Drop =18x9.5 +11mm Rear:Rim Specs 18x10.5 +22 30mm Spacer 2inch Drop =18x10.5 -6mm Correct me if I’m wrong? |
#3706 |
Country Boy 4 Life
What wheels are you thinking? Lowering will change camber. Not wheels. Also, the more you lower, the more natural camber you will get. The car does not have adjustment stock. I'd suggest a set of camber bolts, the are easy to install and inexpensive.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | JustSomeGuy (03-14-2018) |
#3707 |
A Nobody
Drives: FRS
either 17x9 or 17x8 around 35 offset range. i guess i just wanted to know if i could get away with being lowered on stock wheels until the new ones came in with lca and decide then if it would be worth it but thanks
#3708 | |
Country Boy 4 Life
17x8 +35 is a perfect size. 17x9 +35 will work great too, but pokes some in the front. I'd run 225/45 on the 17x8. 245/40 on the 17x9. LCA is not necessary, but camber bolts are for the front. Especially for 17x9 +35.
I LIKE TIRES! |
#3709 |
A Nobody
Drives: FRS
im not smart enough to figure this out but im curious about 17x8 +30.. is that close to how 17x9 +35 would sit? 17x8 does seem more appealing to me though and with the cheaper tire price it would be nice aha. i plan on getting camber bolts up front though but good to know i dont need lca.. but even if i go about 1.5" lower? natural should be fine for DD?
#3710 | |
Country Boy 4 Life
How are you lowering? How much camber do you want to run? 17x8 +30 will work with around -2 front camber. IMHO, I can not suggest going lower than 1" on springs. But, that's how I roll.
I LIKE TIRES! |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
