go_a_way1
Old 01-03-2018, 11:35 AM   #3613
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Originally Posted by swarb View Post
It would not fit without major modification to have 5++ camber and super stretched tires like 215's up front and 225's in the rear.
Thanks my friend,so thats not gonna work the way i want,
Im getting the Rotiform HUR 3pc 18x8.5 front and 18x9.5 rear, can anyone help me whats the best ET and tire size for them? I have Airlift air suspention on my car and i need a good fitment for the rims
Mehrshad is offline   Reply With Quote
Old 01-09-2018, 02:20 AM   #3614
Logikal Reazon
Logikal Reazon's Avatar
Drives: 2017 Toyota 86
18x9.5 Offset +35
255/35 tires
Stock suspension (KW v3 coilovers in the future)
Will this fit?
Thank you!
Logikal Reazon is offline   Reply With Quote
The Following User Says Thank You to Logikal Reazon For This Useful Post:
Leonardo (01-11-2018)
Old 01-09-2018, 10:41 PM   #3615
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Logikal Reazon View Post
18x9.5 Offset +35
255/35 tires
Will this fit?
Thank you!
Read post 213 and 214.
http://www.ft86club.com/forums/showt...=28017&page=16
I LIKE TIRES!
Logikal Reazon (01-14-2018)
Old 01-11-2018, 06:05 AM   #3616
Kalamakid
Drives: 2014 FRS
OK searched the thread and a few forums. I have 17x8 +45's with TRD lowering springs with -2 camber rear and straight front. My 225/45's fit great but will a 245/45 fit without rubbing full lock? I see mixed results but most have stock height... Thanks for the help! Cheers!
Kalamakid is offline   Reply With Quote
The Following User Says Thank You to Kalamakid For This Useful Post:
Old 01-11-2018, 06:52 PM   #3617
Leonardo
Country Boy 4 Life
Leonardo's Avatar
245/40 will fit. Why would you want a 245/45? That is way to big. At 1.1 inches taller and 4.5% larger diameter, this is greater than the suggested +/- 3% range difference compared to stock.
A 225/45 is only 1.6% different that stock and works great.
A 245/40 is only 0.4% different - basically it is the same as stock and will not change your speedometer.
Edit: Additionally, the tread width (for MPSS anyway) for a 245/40 is 8.5" compared to 8.0 for a 245/45.
Oregon is great! I'm in Eugene.
I LIKE TIRES!
Old 01-12-2018, 11:37 PM   #3618
Kalamakid
Drives: 2014 FRS
Yeah a 245/40 is what I'm thinking! I was just worried that I don't have that .4 of and inch of space with the +45 offset to fit that wide of a tire. Might have to buy different rims
Leonardo (01-13-2018)
Old 01-13-2018, 12:42 AM   #3619
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Your wheels are good specs. 245/40 will fit no problems.
I LIKE TIRES!
Old 01-13-2018, 05:13 PM   #3620
shroud
Drives: 2015 FR-S White
18X9.5 +38
245/40/18 Square
TRD springs
will it fit?
Thanks!
shroud is offline   Reply With Quote
Old 01-14-2018, 04:51 PM   #3621
Logikal Reazon
THANK YOU!!
Sent from my SM-N950U using Tapatalk
Leonardo (01-14-2018)
Old 01-14-2018, 10:44 PM   #3622
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by shroud View Post
18X9.5 +38
245/40/18 Square
TRD springs
will it fit?
Thanks!
I LIKE TIRES!
Old 01-17-2018, 06:28 PM   #3623
Tgutz21
I’m trying to find help on getting as much lip as I can on Works Meister L1 3p but with little to no camber. And I am not going widebody! I want more lip in the rear than front. I was think of running 18x10 in the back and 18x9 in the front but not sure exactly on the offset i can get. If someone could help it point me to the correct thread if this isn’t it. Thank you!!
Tgutz21 is offline   Reply With Quote
Old 01-17-2018, 06:34 PM   #3624
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to tbe forum.
This will give you an idea of what it will take.
http://www.ft86club.com/forums/showthread.php?t=15446
oh, and you are going to have some camber...
I LIKE TIRES!
Old 01-17-2018, 06:47 PM   #3625
Tgutz21
If you had to answer how exaggerated would the camber be?
The link you posted is exactly how I want the wheels! Could I use those same wheel specs?
Old 01-17-2018, 07:04 PM   #3626
Leonardo
Country Boy 4 Life
Leonardo's Avatar
He is running the following spec. I think that this is reasonable for wheels of this size. It doesn't look exaggerated to me. Though the 18x10's look huge!
Camber Info:
Front camber: -1.6
Rear camber: -2.5
I have 18x8 +35 & 18x9 +37 with 225/40 & 245/35. My camber is -1.5 f & -2.0 rear. My tire wear is even. Some camber is good; but you'll want your toe to close to zero.
The wheel directory has most Forum Members wheels specs. It is a great resource. http://www.ft86club.com/forums/showthread.php?t=7535
Also, the Meaty tire thread is great!
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
