#3600 |
Drives: 2013 pearl white FR-S
#3601 |
Drives: Toyota 86
Have searched rocket bunny in this thread and didn't see my specific question so here goes. Looking at RB v2 with Tein Super Racing at 1.4" drop. What's the absolute max contact patch I can get in the rear? Would like to run 305s or even 315s on 18" wheels if possible.
Bonus question, can I fit 255s or wider up front? What about with these? https://www.maperformance.com/produc...SABEgIokvD_BwE |
#3602 | |
Country Boy 4 Life
http://www.ft86club.com/forums/showthread.php?t=74391 Also, at least read the first page of this thread too. I've read the whole thing. Great info! http://www.ft86club.com/forums/showthread.php?t=41083 GOOD LUCK.
I LIKE TIRES! |
#3603 | |
It really depends on a number of factors. 1. Tire, a wide 200tw tire runs wide when compared to a street tire. 2. Every car slightly different. 3. Inside lip/barrel is shaped different for every wheel. If you are worried, you can buy a pair of 3mm spacers for the front to make them fit like a +35 and go from there. The rears will clear easily. While the fronts will be very tight... we are talking 5mm or less here... not exactly a lot space to work with. |
| The Following User Says Thank You to swarb For This Useful Post: | Leonardo (12-30-2017) |
#3605 | |
Country Boy 4 Life
Thanks. But from my experience the fact that you are saying "Hopefully".... bro you may as well say never. None of this talk impresses anyone here. Guys doing swaps have lots of money (or lots of debt). Like yoda says "Do or Do not, there is NO try" Just have fun with the car, post pics of mods you have made, you can fit 275 front 285 rear on a stock body, a 2jz swap is 20 grand minimum. GOOD LUCK, welcome to the Forum, and ![]()
I LIKE TIRES! |
#3606 | |
Drives: Toyota 86
Yeah, might not do it. But then again I might. If life’s about the journey, a project car is way more appealing than rolling up to the dealership and driving off with something. Last edited by jz86; 12-30-2017 at 11:34 PM. |
| The Following User Says Thank You to jz86 For This Useful Post: | Leonardo (12-30-2017) |
#3607 |
I'm looking at a set of wheels right now that are 16x7.5'' with an offset of +48.
Would this fit ok? Usually I see 16'' wheels with a lot lower of an offset. |
#3608 |
Country Boy 4 Life
Those will fit, no problems. You could use a 225/50, if you wanted a little more tire.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | funwheeldrive (12-31-2017) |
#3609 | |
I'll probably end up using either a 205 or 215 tire. Last edited by funwheeldrive; 12-31-2017 at 02:58 PM. |
| The Following User Says Thank You to funwheeldrive For This Useful Post: | Leonardo (12-31-2017) |
#3610 |
Drives: 2014 GT86
If it's for winter tires, then they are better to run narrower, eg. 205. Lugnuts/wheels on ours are lugcentric. It's not must have to have hub bore exactly same. As in same hub bore will ease mounting/centering, but should be safe enough to drive even with wheel bore bigger then stock axle diameter (56.1mm). For ease of mind you can buy spacer rings.
Check though, what nut seat wheels in add have. If they are of most common for aftermarket wheels 60degree conical seat (coincidentally same as stock) you should be ok. If it's flat seat like eg. VW's wheels, you may need to get other lugnuts or adapters. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | funwheeldrive (12-31-2017), Leonardo (12-31-2017) |
#3611 |
GT86PersianClub
Drives: 2014 Crystal Black Silica GT86
Hey guys
I found a Rays te37 with good price, But the size is 18x9,5 +12 and 18x10,5 +15 You think its gonna fit stock 86?i really love te37’s |
#3612 |
It would not fit without major modification to have 5++ camber and super stretched tires like 215's up front and 225's in the rear.
| The Following User Says Thank You to swarb For This Useful Post: | Leonardo (01-02-2018) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
