#3501 |
Drives: 2013 SWP BRZ Limited
Looking for a square setup with natural camber and preferably no fender work...I am torn...
Will 17x9 +35 245/40/17 or 18x9.5 +38 245/40/18 fit with OEM damper with Eibach Sportlines or am I in for coils as well? I am not a fan of the stretched tire look most people get in the front and am trying to gauge if I am better off dropping down to 17s for a meatier look or if I could get away with a taller sidewall on 18s as I know it is tough to go wider than 245 in the front even with coils. Yes, I am aware 245/40/18 would throw off my speedo...
#3502 |
Drives: 2013 Subaru BRZ
Hey guys! I'm in the market for some 17x9 +27 wheels with a 5x114.3 lug pattern. I plan on pairing them with +15mm conversion spacers. Is this the right size spacers to use to achieve a flush look?
About my car: Stock body BRZ Fortune Auto coil 17x9 +35 RPF1s right now so i have some idea of setting up wheels..lol |
#3503 | |
Drives: 2013 Firestorm FRS
#3504 | |
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| The Following User Says Thank You to 15limited For This Useful Post: | Waffle86 (07-14-2017) |
#3505 | |
Assuming a square setup: 1) 18x9.5 +38 on 245/40/18 w/ eibach sportlines will fit w/out rubbing. No room for camber adjustment due to stock perch. No camber bolts needed to remove natural camber from lowering. Coilovers required to fix poke. 2) 18x8.5 +35 on 235/40/18 w/ eibach sportlines will fit w/out rubbing. Camber bolts optional. 3) 17x9 +42 on 245/40/17 w/ eibach sportlines will fit w/out rubbing. Very little room for camber adjustment due to stock perch. 4) 17x9 +35 on 245/40/17 w/ eibach sportlines will fit w/out rubbing. Camber bolts required to fix poke. 5) Coilovers magically make everything listed above fit. Please correct me if I'm wrong about any of this - I've read a lot of conflicting information across multiple threads to get to this point
#3506 |
Drives: 2017 Subaru BRZ limited PP
Would nt03 18x9.5 +40 fit on a 2017 brz with factory brembo brakes?
#3507 |
Drives: 2017 Series Yellow BRZ
#3508 |
Ok. Thank you for the info.
What wheels and size would fit with factory brembo brakes? I apologize in advance as I'm new to the brz/86 world coming from a 2013 wrx hatchback |
#3509 |
Drives: 2015 BRZ
Need some advice on running TE37SL 18x9.5 +40 on what tire size I should go with. I am picking up some KW V3's coils as well.
I was set on MICHELIN PILOT SUPER SPORT 255/35ZR18 but am wondering if I would be better off with 245's instead? I don't want to roll my fenders at this point but want to avoid rubbing. Any advice would be great! Thanks
Daily: 2008 IS250 (Stock)
Toy: 2015 BRZ (KW V3, TE37sl) More to come. Past: 2008 BMW M3, 1976 Datsun 280z, 1998 240sx, 1990 180sx, 2005 RSX-S, 2003 IS300, 2001 Civic. |
#3510 |
I have RPF1s at 17x7 with, I believe, 38 offset. I'd like to get some spacers to make them more flush. Any recommendations? Thanks.
#3511 | |
Loading...████████] 99%
Drives: #0517
| The Following User Says Thank You to asdf For This Useful Post: | continuecrushing (07-17-2017) |
#3512 | |
I'm picturing Work VS-KF in 5x100 18x9.5 +30 on a 245/40/18 Locating a 5x100 set is proving to be extremely challenging. 18s in 5x100 that I've found are all shit and would need to be rebuilt anyways. Instead I'm going with Devilswerk wheels. They gave me the best quote with shipping. What offset could I run to maximize the lips of the wheel? +27,+30, or +35? What size tire is best for a lower profile look with minimal stretch on a 9.5 wheel? 245/40 or 235/40? **Edit: Or would a 18x8 an aggressive offset like +15 be a better route? That would allow me to fun skinnier tires and enjoy stock power levels I've seen plenty of threads with people running other 18x9.5 +38 or +45 wheels but not many VS-KFs on stock body 86s. Won't consider 225s on a 9.5 either. Too risky About my car: WRB BRZ Fortune Auto v5s Camber Bolts This will allow me to tilt in the fronts. I'm expecting no more than -3.5 camber max to get this to all work. I'll order rear LCAs if I'm not happy without how the rear sit. Prepared to receive some hate for the hotboy wheels/instagram build :/ Last edited by whitelightninn; 07-18-2017 at 04:52 AM. Reason: revised post |
#3513 |
Drives: 2014 Scion FR-S
Would 18x9.5 +45 in the rear and 18x8.5 +45 in the front cause any rubbing issues?
#3514 | |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
