#3389 |
Wes
Is this from a functional or aesthetic standpoint? Cause I don't want stretch but at the same time would like to avoid the other end of the spectrum and not have meaty tires.
#3390 | |
Drives: 2015 Scion FR-S Release 1.0
#3391 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
225/235 are rather streeched, 245 are normal, 255/265 are meaty on a 8.5"
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#3392 | |
| The Following User Says Thank You to Killerbee For This Useful Post: | Loetke (03-17-2017) |
#3393 |
Wes
Okay thank you. I'll go with the same size tire as you then 245/35/18
#3394 |
Drives: Evo X
What’s the most appropriate tire size (aka not illest stretch brah) my friend can fit on 17x9 +35 RPF1's with a 1-1.5 inch drop? Not sure what suspension he’s buying nor when he’s buying new tires, I’m buying the wheels as a surprise/goodbye/thank you gift. He’s definitely not going to stretch the stock tires (crashed a car in the rain before), so I figured I’d ask in case what I’m looking at isn’t ideal.
Need to place the order by 3pm PST or I'm going to have to ship to their new place, which isn't ideal. TIA. |
#3395 |
Drives: 2014 GT86
Evo.X: do you know if he is from those that value looks over function and has shown interest in fitting widest wheels he can? Maybe wheels of more reasonable width x7-x7.5-x8 might be better choice, if stock tires are mentioned?
#3396 |
Drives: 2013 10 Series Scion Frs
Will it fit on stock suspension? Been looking at the charts, but still not positive...
18x9.5 +45 with 245/35/18 |
#3397 | |
255/40 might rub rear bumper tab on big dips. |
#3398 |
| The Following User Says Thank You to swarb For This Useful Post: | James The Giant (03-22-2017) |
#3399 |
#3400 | |
Drives: Evo X
If I had to say either or, I'd say form over function. However, I did mention he's crashed in the rain before and we frequently do some sketchy mountain/canyon runs, but I know he's probably never going to the track. Is running 18's on the BRZ like running 19's on an Evo X, "not the norm"? If so, I'll probably stick with 17 even though I was considering 18. As far a width, might step it down to 8.5. I just want something that will fill out the wheel well and be flush without rubbing at 1-1.5 drop. I'll be getting the appropriate spacers for the rear. My coworker was telling me 17x9 +35 would be flush at the front at 1-1.5 drop, despite it being considerably higher than what the chart says. Or better yet, I'll just ask: what do you guys think I should get to be flush front and rear at a 1-1.5 drop. He'll just have to buy tires that fit the wheel after. These are the requirements: -8in width, minumum -As little stretch as possible -1-1.5 inch drop -As close to flush as possible 17x8.5 +30/+35 are what I've kinda narrowed it down to. Last edited by Evo.X; 03-24-2017 at 01:25 PM. |
#3401 |
17x8 45mm offset 215/45/17 front
17x9 45mm offset 255/40/71 rear Stock suspension Will it fit? |
#3402 | |
Loading...████████] 99%
Drives: #0517
A lot of folks on the forums do run 18s, but I would prefer to stick to 17s (preference in looks/tire sidewall look, tires slightly cheaper as well). I believe the rpf1s will present clearance issues if you ever want to run a BBK so that may be a consideration. a widely popular option that comes in 17x9+35 (among other sizes that fit would fit well) and will not cost an arm and a leg are the wedssport tc105n wheels |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
