#3305 |
No I haven't personally seen anyone run it, I've never heard of anyone running it, 255 is more of a 9/9.5 inch wheel thing
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#3306 | |
Grip>Drift
Drives: FRS
Should be fine if you don't have a lot of negative camber. Sent from my iPhone using Tapatalk
#3307 | |
Drives: 2013 Firestorm FRS
Either way, the tire will more than likely rub on the inside strut/spring since you're running double crash bolts. What camber settings are you at right now? Take a look at this: thanks to @track_warrior This a 245/40, but you want 255 + camber bolts. It would be close Also depends which 255 tire you run, some run wider than others.
#3308 |
will a 265/40 fit a square setup of 18x9.5 without rubbing issues dropped an inch on coils
#3309 |
Drives: Too fast
Ended up buying +35 as camber is a priority. Thanks for the input !
I'll post some pics when everything is all done, as the snow keeps falling up here. |
#3310 |
#3311 |
#3312 |
Drives: Scion FR-S 2014
Will this fit?
18x8.5 +45 225x40 up front
18x9.5 +45 255x35 in back putting 1" suspension drop in front and back. Thanks for the help! |
#3313 |
But what about the 9"+ tire on an 8" wheel...
#3314 |
Drives: Too fast
You guys (except a few of you of course) are forum tuners. Plenty of people are running 255 tires on 8 inch rims at the track, and its been like that for years. Get out there. Stretching is bad, be e-thugs about that. Let people that have been involved with the track do their things and keep regurgitating what is normal and what is not somewhere else.
Thanks ! |
#3315 |
Drives: '15 Scion Frs Steel
Ok i have 19x9.5 up front and 19x10.5 in rear +30 offset they are 5x114 so im going to need adapters and I have 245/45/19 tires would they fit and im getting airbag suspension too?
#3316 |
Drives: GT-86
Need help! Have my Rocket Bunny GT 86, and i bought Forgestar F14 Super Deep
Parametrs - (2) Front: 19x10 +20 SUPER DEEP CONCAVE PROFILE (2) Rear: 19x10 +20 SUPER DEEP CONCAVE PROFILE Bolt Pattern: 5x120 But what i have... https://pp.vk.me/c837526/v837526067/...oJAo9WAW6k.jpg https://pp.vk.me/c837526/v837526067/...JReokEE1cg.jpg https://pp.vk.me/c837526/v837526067/...2MVBuye9uk.jpg Master said that i need to sell front, because it is not established... Any ideas? |
#3317 |
45 series tires are too tall. For 19's you need 30 series. Rears will probably rub bumper tabs, but anything low with air suspension will be a tight fit if you are trying to tuck tire/rim. Also depending on the airbags, there will be about 15mm less inside clearance than stock so those wheels won't work. Search for bags fitment(?) thread for more info.
#3318 | |
Adapters? Size? Tires? Lots of camber? Should be able to fit it as is, you can search for the wide body/rocket bunny wheel fitment thread for more specific info on other people's setups. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
