#3235 |
Drives: 2013 scion frs
how will this fit
17x9+ 30 245/40/17 on swift springs / stock suspension? thx
#3236 |
#3237 |
my bad 245/40/17 sorry
#3238 |
Drives: 2013 White-Out FRS
I live my life one quarter-pounder at a time.
#3239 |
Drives: GT 86
Looking at going RB V1.
I want the CR2P's 19" 11 back 10 front Max camber negative 3 I've been told a variety of offsets and need some help... Anyone know what my offsets should be for a flush finish |
#3240 | |
Country Boy 4 Life
AWESOME!!!! |
#3241 |
Drives: 2014 BRZ brand new!
currently have 17x9 +35 with 245/40/17. cusco coilovers (pillowball mount) lowered all the way in he front and only 1/2 inch taller than that in the rear. im looking fo all season tires, found some i like, but im wondering if a 255 width tire will fit without rubbing? anyone with a similar setup that can confirm? ive turned the wheel lock to lock and looked at clearance and it looks prettttty tight. idk. little wider tires couldnt hurt as long as they fit. thanks!
#3242 |
Glorious BRZ Master Race
Drives: Subaru Libird
Will 18x9.5 +45 with 265/35R18 rub the rear bumper tab? Tires will be Hankook Ventus V12 which run narrower than most. Lowered 1.4" with -2.5 camber.
#3243 |
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Specs:
18x9.5 +38 245/40/18 Bridgestone RE71Rs. Car is bone stock, will not be lowering until early summer 2017. Question 1: Will it fit stock suspension? No rubs at full lock? Question 2: Will it fit after 1 inch drop come summer time? (Eibach Pro Kits) |
#3244 |
That Auto Guy
Drives: Ultramarine FRS
17x8 +35 on coils.
Would 235/45/17 or 235/40/17 be better?? |
#3245 |
Drives: 2016 Series.Hyperblue BRZ
17x9 +35 with a set of 245's. Will it fit with a 1 inch drop or do I need other things for good fitment. Only suspension pieces I have are H&R Super sport springs
Sent from my SAMSUNG-SM-G930A using Tapatalk |
#3246 | |||
I'm probably lowered about 2 inches.Compared to your setup, you gain 10mm from the offset but lose 5mm(10mm/2) from the tire. I'd say you will rub. Quote:
2. When you drop it, the car will gain camber. That would reduce the clearance. You won't really know until you try it, but it will be less than the 3-8mm mentioned above. I personally wouldn't risk damaging the wheels or getting into a sticky situation. 9.5's don't fit good on stock struts, they either poke or rub or are dangerously close. A 3-5mm spacer would help. 245/40's are for 17's. 40 series is for 225 or 235 on 18's. 245/35 is a much better choice. On 18's you will be a full inch taller than stock. Quote:
245/40 will fit. Chance you might need a 3-5mm spacer up front due to camber and not all cars are made the same, we are talking a few mm here, maybe about 10mm clearance? Depending on how much clearance you are willing to accept. Last edited by swarb; 10-29-2016 at 01:08 AM. |
| The Following User Says Thank You to swarb For This Useful Post: | Leonardo (10-29-2016) |
#3247 |
You should have plenty of room, closest point of contact would be your tire to the spring perch. I'm slightly lower in the front with -1.5 camber and I wouldn't want to get any closer than that, same wheel specs and tire width. I've heard tire manufacture measurements can vary but I've ran Falkens and... whatever different tire I'm on now and neither rubbed. I would recommend camber bolts anyways and an alignment to get this dialed in to where you want them.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#3248 | |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
