go_a_way1
Old 09-06-2016, 08:45 PM   #3221
NickoDiko
Drives: Aaphalt Scion FRS
Looking into getting 18x8.5 +33 on RSR lowering springs. Will this have a lot of poke or be flushed fairly well?
NickoDiko is offline   Reply With Quote
The Following User Says Thank You to NickoDiko For This Useful Post:
CatalystPLUR (10-28-2016)
Old 09-07-2016, 01:36 PM   #3222
ol_dirty_dmo
Drives: 2013 scion frs
Originally Posted by VIP BRZ View Post
Those are going to poke a lot, your offset should be closer to +20 or higher I'll let the more experienced guys chime in with better specs but youll have issues
yes, but if I'm running lower control arms and toe links, I can pull the poke to where I want it to be and ill be running alot of camber as well. so it will give me more room to play with and get it to where I want to sit. correct??
thank you for the input though man. right now my offset is at +21 in front and +26 in rear. just wanting a more aggressive fitment.
ol_dirty_dmo is offline   Reply With Quote
Old 09-07-2016, 01:47 PM   #3223
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Your issue is going to be the fronts, 9.5" at even +15 would take Extreme camber to sit flush.. probably a lot more then you can possibly get. like neg 10 - 15
You should look into going widebody, at least front (TODOROKI) if you want that aggressive
VIP BRZ is offline   Reply With Quote
Old 09-07-2016, 02:03 PM   #3224
ol_dirty_dmo
understandable.. the only aggressive front offset I have seen is -5 on stock body. I am trying to stay stock body for now. thank you for the input I really appreciate it.
Old 09-07-2016, 02:15 PM   #3225
VIP BRZ
VIP BRZ's Avatar
Look at the specs on some the the guys running aggressive setups on this thread..
http://www.ft86club.com/forums/showthread.php?t=25171
takes some time reading through all the pages but it helped me a lot when rebuilding my wheels
The Following User Says Thank You to VIP BRZ For This Useful Post:
ol_dirty_dmo (09-07-2016)
Old 09-07-2016, 06:09 PM   #3226
SStratos
SStratos's Avatar
Drives: 2017 WRB Subaru BRZ
I'm learning lots from all of my reading on here, and wanted to ask a fitment question.
Trying to stay as close as possible to standard ride height, what would the modifications needed to try to fit 17"x9" up front and 17"x10" rear, given that any offset is available, what would be the optimal offset front and rear?
Thank you!
SStratos is offline   Reply With Quote
Old 09-17-2016, 03:37 AM   #3227
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Noob suspension question. Ok so I'm on TRD springs on OEM shocks, and right now I'm running 18x7.5 +38 with 235/40/18 in the front, and 18x8.75 +33 with 255/40/18 in the rear. I only rub in the rear of the outer fender on big dips going above +50MPH , and not the the strut at all.
If I run 18x8.5 +33 all around with the same tires, I know the front will clear, but will the rear still rub since I'm at the same offset? And would I be able to add -1.5 camber in the front and rear and clear the front and rear strut?
Instagram: @battleship_86
It's more than a hobby it's a lifestyle.
KungFuWaffle is offline   Reply With Quote
Old 09-17-2016, 03:53 AM   #3228
swarb
You good. That is a very good size.
Old 09-17-2016, 04:09 AM   #3229
swarb
Do you have your sizes correct? 8.75 +33 to 8.5 +33 in the rear?
You will gain about 3mm of clearance, both on inside and outside.
LOok and find out where you rub, it is probably the rear bumper tab, and unlikely the fender. Look at the size/shape of the rubbing on the bumper tab and see if that extra 3mm of clearance is enough. 255/40-18 is a bad size tire that is way too tall, that is mustang size. 245/35 or 255/35 is a much better choice.
Rear you should be good if you add camber, are you adding -1.5 or -1.5 total? you should be good either way.
Front you should be ok too, but it will be about ~10mm(or less) from rubbing the strut. It also depends on the tire width also. If anything 3-5mm spacer would give more clearance. I would tell you to mount them and then stick your phone under and take a pic to see how close you are before adding camber.
Old 09-17-2016, 06:11 AM   #3230
KungFuWaffle
Drives: Whiteout
Yep the sizes are correct, I'm going to be switching to a squared setup so I can rotate my tires again. I was just wondering if the size tire would be fine in the meantime I can get new tires on them. I would be adding -1.5 camber to eliminate the poke a bit.
Old 09-17-2016, 07:06 AM   #3231
swarb
Same offset wheels, the tires just get pinched by a more narrow rim.
Old 09-17-2016, 02:38 PM   #3232
KungFuWaffle
Drives: Whiteout
If I run 18x9.5 +38 all around would those same size tires rub?
The Following User Says Thank You to KungFuWaffle For This Useful Post:
thien (09-26-2016)
Old 09-17-2016, 06:05 PM   #3233
swarb
You would gain 5mm of clearance from the offset changing 5mm. The shape of the tire would be slightly different because of the wider rim.
The problem isn't your wheel. It is the diameter of the tire and the limited clearance on stock struts.
255/40-18 are too tall. Get rid of them. Or keep on trying to fit those bad size tires with other, more expensive fixes. Or just deal with the rubbing.
http://www.frsproject.com/
I am done here. Maybe someone else can help. Good luck.
Old 09-17-2016, 06:12 PM   #3234
KungFuWaffle
Drives: Whiteout
You have been a great help! Thank so a lot for your answers and patience!
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
