go_a_way1
Old 03-16-2016, 07:36 PM   #3011
Dmoney
Drives: Frs release series 1.0
Hi guys need some help I have trd lowering springs and just bought rims that are 18x9.5 +35 offset. Wanted to keep the springs for now if possible without scraping and hitting the fenders or suspension. So I need help with what tire sizes will fit. Thanks.
Dmoney is offline   Reply With Quote
Old 03-16-2016, 08:02 PM   #3012
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
245/35/18 all around should fit. Its thight in the front, so let it check again from your tire guy, but it should fit.
You can also staggef the tire setup to 245/35/18 front and 265/30/18 rear
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Teseo (03-16-2016)
Old 03-16-2016, 11:11 PM   #3013
Aire2thethrone
Drives: 2016 CBS BRZ
hey I got a quick question, I just tried putting wheels and tires on my 16 BRZ today. So from what I gathered from forum searching was that 245/35r18 would be a good fit all around, so I bought 18x9 +45 Konig integrams and Michelin pss and the tires touched the springs in the front, any suggestions for what to do now?
Aire2thethrone is offline   Reply With Quote
Old 03-16-2016, 11:24 PM   #3014
swarb
Slip on spacer. 3-5mm.
Old 03-17-2016, 10:06 AM   #3015
Calais
Calais's Avatar
Drives: 2012 BRZ....finally
hi i'm looking at 949 racing 17x8 6UL, offset is +40 and trying to go for a "meatier" tyre look i've gone on a couple of fitment calculators, and have come up with 2 tyre sizes 245/40R17 and 225/45R17, my question is will either of these have rubbing or clearance issues either front or rear?
i'm on stock set up but looking to lower 1" in the future
For a pure sports car, it must be internal combustion-Mazda Motor Corporation’s sports car chief Nobuhiro Yamamoto
Calais is offline   Reply With Quote
Old 03-17-2016, 10:52 AM   #3016
EliteRB
EliteRB's Avatar
Drives: 2013 FRS V1
So I will be running F 18x9.5 -10 and R 18x11 -20 with 15mm spacers all around will I be ok with a 225/40 and R 245/40 and yes the fenders are cut. thanks!!! or would it be better to run a 255/35 in the rear with out the 15mm spacers?
EliteRB is offline   Reply With Quote
Old 03-17-2016, 03:39 PM   #3017
swarb
No clearance or rubbing issues.
Everyone fits RB differently. You could fit either.
The Following User Says Thank You to swarb For This Useful Post:
Calais (03-17-2016)
Old 03-17-2016, 10:41 PM   #3018
Calais
Calais's Avatar
thanks
Old 03-17-2016, 11:21 PM   #3019
unplugged
Master Member
Drives: Subaru BRZ
2016 BRZ Limited
Looking to get either 17" or 18" Rota DPT in Bronze with Bridgestone Potenza S-04. Still debating if I want stock tire size or go wider on 17's. Or move up to 18's - something like 225 width.
Need help with width and offset. I plan to drop the car 1.0-1.2". I believe these were the choices given:
17x7.0
17x8.0
18x8.0
18x8.5
The other choice is
18x8 Rota Tarmac 3 - Sports Bronze(5x100/e48/56.1)
unplugged is offline   Reply With Quote
Old 03-17-2016, 11:46 PM   #3020
swarb
Originally Posted by unplugged View Post
2016 BRZ Limited
17x7.0
17x8.0
18x8.0
18x8.5
question?
8's for 225. Offsets matter, what are the choices?
Old 03-17-2016, 11:53 PM   #3021
unplugged
Master Member
Drives: Subaru BRZ
question?
I emailed the company that sells the rims for offsets. I don't see these on rota's website. Not sure if they are discontinued or I missed them.
They only list 17x9 on web site
wheeldude.com
Old 03-18-2016, 12:05 AM   #3022
swarb
wheeldude.com
question?
17x9 +35
or 17x8 +22/48
Will all fit.
Call if you want a fast response. Otherwise wheeldude is known to be slow with emails.
Old 03-18-2016, 12:10 AM   #3023
unplugged
Master Member
Drives: Subaru BRZ
question?
17x9 +35
or 17x8 +22/48
Will all fit.
Looks like they are discontinued anyway. He might be getting last stock.
The other wheel is 18x8 Rota Tarmac 3 - Bronze 5x100 e48/56.1
Looks like Rota doesn't even come close to the offsets needed for our cars. Then again, not sure how much 28-32 to 48 offset looks like on the car
Old 03-18-2016, 05:36 AM   #3024
Killerbee
Killerbee's Avatar
thats easy to tell
its all in mm, so +48 is 16mm more "inside the fender" than an +32
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
