#2983 |
8.5 all around so you can rotate tires. You can always add a spacer. 9.5's don't fit well without coilovers.
#2984 | |
Drives: Scion Frs 2013
#2985 |
#2986 | |
Spacer not needed for the fronts at x8.5 +33. You can also use them in the rear for that staggered look.
#2988 | |
Drives: 2014 SWP BRZ Limited 6SP
When adding spacers should I do it in a balanced way front to back? ie, if I add 10mm up front should I do the same in the rear?
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
#2989 | |
Stock studs are only good for 3-5mm slip on spacers. Some say 5mm is too much. Up to you what you feel is safe. Any more you need a bolt on spacer or longer studs. |
#2990 |
Drives: 2013 WhiteOut Frs
Okay, so im looking to buy a set of Avid1 AV50, preferably 18x8.5. The only offsets they offer are +30, +35. My question is, what offset would be best and what would be a good tire size without going less than 225. I will be running stock height. Thanks
#2991 |
Drives: 2012 GT86
hey guys, need some help.
I bought a set of 18x9.5 + 38 kiwamis. I am not sure what tyres to get. I was thinking 235/40 fronts and 245/35 rears. Would this be fine on stock suspension? Would I need coilovers ? I have been told too many different things IRL so I am so confused right now.. Got it all sorted. Went 235/40 all round. Sits really good but pokes alittle. Last edited by sNake89; 02-16-2016 at 03:07 AM. |
#2992 | |
You pretty much only have three tire choices. 225/40, 235/40 or 245/35. Look up a tire size calculator and compare to stock. 225 is a slight stretch, 235 slightly too tall, 245/35 best overall choice. |
#2993 | |
Thanks! Now should I expect an rubbing or poke running a +35 |
#2994 |
Country Boy 4 Life
http://www.ft86club.com/forums/showt...t=18980&page=3 +35 will look like like this with a 225/40 stock height. Pokes some.
#2995 |
Drives: scion fr-s
hello! new to the forum... im pretty sure this question has already been asked but i just want to make sure... can i fit 18x9.5 +38 offset with 255/38/18 tires on them on a stock frs suspension? will i have rubbing issues or will i be good?
#2996 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
![]() I'm a complete noob to this. This is what I believe the following setup looks like: [ame="http://www.amazon.com/18x9-5-Enkei-Raijin-Silver-467-895-8045HS/dp/B00CZCEWFU/ref=sr_1_1?ie=UTF8&qid=1455988118&sr=8-1&keywords=enkei+raijin+hyper+silver+9.5+5x100"]18x9.5 Enkei Raijin, 45mm offset[/ame] Michelin Pilot Super Sports 245/40ZR18/XL Eibach Pro Kit 1" drop springs Will it fit? Could I use spacers to get rid of the additional offset from flush? Thanks edit: semi-answering, still looking for more information. The 9.5" wheels won't fit with the springs, but can with coilovers. Last edited by gkubed; 02-28-2016 at 02:28 PM. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
