#2857 | |||||
quick tutorial. 40=40% of the width of the tire. 245/40= 245 X .4 = xxx mm side wall height 255/40= 255 X .4 = xxx mm side wall height so 255 is 10mm wider than 245 so there for 10mm X .4 = 4mm higher sidewall on 255 than 245. Read the tire spec to get the exact measured sizes as the math is just a guideline. Good size. You should be good to go. 225/40 tire will be stretched a little, but you should be fine. Also check out 235/40 and 245/35 tires. |
| The Following User Says Thank You to swarb For This Useful Post: | Jonde875 (09-23-2015) |
#2858 |
Drives: '15 Firestorm FR-S
#2859 |
Not a troll
18x10 +15F and +5R with 225/40 tires
| The Following User Says Thank You to Cole For This Useful Post: | drewbot (09-23-2015) |
#2860 |
Drives: 2013 Fire T86
I live in Colorado so ATM a drop is pointless. No fender roll but would a 18x9.5 all around work with the right tire size on stock suspensions? Kinda sucks don't come pre rolled like Genesis coupe
#2861 |
Drives: GT86
HI!
Someone help me to decide what to choose of Gramlights 57extremes? ![]() I have thinked 18x8,5 +42 face2 all around but still I have taught if the 18x9,5 +40 looks much better and fits nicely without rubbing at rear! I just wonder is the 9,5 wide wheel with 255/265/35 tyre too big for this car and effects much to performance? I know the 8,5 is better than 9,5 for performance except grip but still I want think about it! ![]() Tyres I would put setup 1 225 or 235/40 allround setup 2 235/40 front 265/35 rear or 225/40 front 255/35 rear! Last edited by Jonde875; 09-30-2015 at 04:15 PM. |
#2862 |
Anyone think 18x9.5 et22 with 225/40's fit? Slight camber and maybe a fender roll?
#2863 |
Drives: toyota 86
i have the same question. will wait for the feedback.
im thinks ng if getting 18x9.5 offset 40 (square). |
#2864 | |
Your setup will work just fine if keeping stock suspension have a good tires and picture combo of something close to it if needed. |
#2865 |
Drives: FRS
you need adjustable coilovers to have clearance on the inside with that setup. stock suspension or lowering springs will still rub.
#2866 |
Drives: 2015 FR-S White
I have TRD lowering springs -
Whats the widest i can go on tire with no rub? (square or staggered) Ive been looking at 245/40/18 What wheel size? I was looking at 18x9.5 +38 |
#2867 |
turbo turtle
Drives: exit GT86 enter STI
Hello!
need help. bone stock frs my friend can sell me work rims 18 9.5 +38 is it fit to my frs? |
#2868 |
JDM Vaping Stance Nation
Drives: 2013 White
Trying to get into the wheel game. Saw my first wheels that I like, will it fit?
17x8 +35 offset 5x100. Hub Bore is 73.1 What I'm more worried about is the bore size, I know the car is around 56. And it's an ongoing battle of aluminum, plastic, if they help the car's load, if it's just to center the wheel for vibrations etc. I plan on mounting 225/45/17 tires as well since I've researched and those seem like the best bet. Also, I know the rear is going to be flush and the front will stick out a bit. I'm not planning on lowering either. |
#2869 | ||||||
Please don't quote my whole post if it is not needed.
| The Following User Says Thank You to swarb For This Useful Post: | Baramzisyan (10-12-2015) |
#2870 | |
Drives: GT86
![]() I bought 18x8.5 +42 in front and 18x9.5 40 in rear! Is it that bad really! I didnt buy tyres yet still!! I just did think they will look nicely flush! |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
