#2675 |
I've been browsing the XXR galleries for a few days now but thought I would ask here. Looking at 18x9.75 +36 with 235/40/18 tires in the rear. Lowered on stance coils. Right now they are lowered all the way down. No other suspension mods. Wondering how fitment would be in the rear. Any issues with fitting it w/o LCAs or fender mods? A little rubbing is fine but my main thing is I don't want them poking out a few inches like I've seen in some other pictures. Was thinking 8.75 +36 with 225/40 in the front so I would need a spacer to even it out with the rear? I already have the tires and handling is not the biggest concern to me as it just my daily and I don't use it for "spirited" driving. Thanks for any input.
#2676 |
Drives: '13 Firestorm
OK, we got the wheels put on this morning. They look and fit perfectly! Thank you to Slick for the help.
I will post pictures later after it is washed. Enkei Kojins 8.5 square setup, 245/35/18 tires, NO front spacer needed, TRD springs no coilovers
TRD Lowering Springs
TRD Front and rear sway bars Perrin 3 inch Cat Back Exhaust |
#2677 | |
Drives: FR-S Firestorm 6MT
If you upgrade wheels, try to NOT run a spacer, focus on getting a wheel in the right size and offset instead. |
| The Following User Says Thank You to Slick For This Useful Post: | sftateofmind (02-14-2015) |
#2678 | |
Evening Primrose
#2679 | |
A 215/50 is 2.5% and 1" taller than your OEM tire. If you're looking to upgrade your tires, you should be looking at 225/45R17. Wider tire, easily fits on the stock wheel, only 1/2" taller than stock. But to answer your question, you shouldn't rub anywhere on a 215/50. |
#2680 | |
The issues are:
7.5-8.5" wide wheel: 225/40R18 8.0-9.0" wide wheel: 245/35R18 8.5-9.5" wide wheel: 255/35R18 |
#2681 | |
I can't see any issues with fitment as you probably have enough camber already to tuck the back wheels in. You may need LCA's, not sure. Look over the aggressive wheels thread here as I think it is probably up your alley. http://www.ft86club.com/forums/showthread.php?t=25171 |
| The Following User Says Thank You to Slick For This Useful Post: | dubbrand (02-15-2015) |
#2682 | |
Yeah, post up some pics when you can. |
#2683 |
Evening Primrose
@Slick I also read that 25mm spacers would make oem wheels pretty much flush. Am I missing something? 8mm seems to make more sense, just double checking.
#2684 | |
If you want to go with bolt-on spacers, then they're about $100/set and up for a quality set like H&R or Eibach's. Ebay sets are much cheaper ($$ and quality). You should be pretty close to flush with 25mm ones. But I'd personally save the big expense and just flush them up a bit more with slipons. |
#2685 | |
Evening Primrose
#2686 |
Here is the only picture I got, had to get it in the garage before it rained. 245/35/18 8.5 square. The only question I have is.....how close can the wheel be to the spring perch? IT IS SUPER CLOSE. I didn't use the 5mm wheel spacer as the wheel would poke if I went that direction. I would guess there is roughly 2mm clearance.
#2687 | |
Here's mine when I had 245’s mounted, now I have 255's on.
| The Following User Says Thank You to Slick For This Useful Post: | Beachnuttz (03-12-2015) |
#2688 |
It is way closer than that. I will try a pic....yet again, thank you for your help
TRD Front and rear sway bars Perrin 3 inch Cat Back Exhaust Last edited by Beachnuttz; 02-14-2015 at 11:44 PM. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
