#2647 | |
Drives: FR-S Firestorm 6MT
Let's say 25mm spacers (most common), then your effective offset will be +27. You will have poke unless you gain extra negative camber, somewhere around -3 or more. You can use smaller conversion spacers like 15mm as you stated but make sure the wheels you are fitting have voids to let the rest of the OEM studs poke through (see pic below to explain what I mean). This would give you effective offset of +37 which is just about perfect. With this setup a 245/40R17 will work very well.
#2648 |
Drives: 2015 BRZ CWP
SSR GTV02 18x9.5 +40 square setup lowered on fortune auto coils.
What kind of tire size you think is appropriate? I was looking at 255/35. What would you recommend? I assume the rear will be fine, how would the front be? |
#2649 | |
Drives: 2015 Subaru BRZ
#2650 |
Drives: '13 Firestorm
looking at Kojin's, 8.5 18's with a +45 with a 245/35 tire setup work? I believe I will need spacers for the fronts (5mm)? Lowered on TRD springs
Thanks, Beach
TRD Lowering Springs
TRD Front and rear sway bars Perrin 3 inch Cat Back Exhaust |
#2651 | |
Firstly, what camber settings are you at? With just lowering springs, these wheels will be a no go, you need coilovers. I'm on 18x9 +35 on springs and I have only about 4-5mm clearance to the strut spring seat on -2.2 camber. You will be closer by 9mm hence the extra clearance by going on coilovers. As you stated, rears are probably okay but fronts are the issue. |
#2652 |
Wheels and tire selection are good. Should be fine with a 255/35R18, could even go to a 265.
#2653 | |
Awesome man, thanks for your help. I ordered 255/35. Sent from my iPhone using Tapatalk
YOU WONT.
#2654 | |
You may need spacers, might not, depends on your camber. 5mm spacers are cheap, so buy them just in case. 245/35 is a perfect tire size for an 8.5" wheel. |
| The Following User Says Thank You to Slick For This Useful Post: | Beachnuttz (02-06-2015) |
#2655 | |
Not sure on the camber bolts as I had the dealer install everything. But I will buy the spacers just in case. I really appreciate your feedback!! Beach
#2656 | |
I am just wondering if they wont fit at all or if they will just stick out? I really love the look of the D2Ex's but I am not ready to throw 1600 on decent coilovers Thanks for being patient with a new car enthusiast |
#2657 | |||
Your best bet for a wide wheel is a 18x9 +35. You can run this setup with springs and no one will notice the extra 1/2". And you could easily run a 245, even a 255/35 with the right camber. Or buy coilovers. |
#2658 | |
So for the 5mm spacers are you referring to the stock springs or with the tein springs? and if so is the problem with clearing the fenders when turning the wheels? |
#2659 |
Alright this is my last post! I apologize, so i found a set of the wheels 18x8 +48mm 56.1 so with my S-Techs these should fit with no problems correct? Any tire size suggestions?
#2660 |
Sleep Chomper
Hello everyone, I am looking to get a new set of wheels & tires (choices tbd later, right now I'm looking for measurements and sizing) for my boosted set up (going for ~300 whp & lowered 1")
My main use cases are: Streets & AutoX Requirements: lighter wheels - function > form, though looking good is a definite plus. Perfect Flush Square Set up My option: Looking at 18x8.5 with 245/40, offset: +42 Front, +32 Rear, no Camber Taken this from the Wheels Directory post Darren started but I am wondering if the offsets are a bit too much for the front? Also I am wondering if that tire is too skinny for the power I am putting down. I don't want to kill gas mileage as well. Any sort of suggestions? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
