#2633 | |
Drives: FR-S Firestorm 6MT
Run a 245/40R17 tire. You won't find tires in the sizes you quoted above anyway. |
#2634 |
Drives: 2014 FR-S 6MT Monogram Series
#2635 |
Drives: 2014 SWP BRZ Limited 6SP
OK, I've changed my plans and now I'm looking at a square set-up 18x8 +45 running a 235/45/18.
Should I be looking at a wider tire or mabe a smaller sidewall? I think either 40 or 45 will be fine rubbing wise but Im curous what others think.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
#2636 | |
Choose from one of the following:
For the wheel size, I would go with a 225 unless you need extra width, then a 245/35 would work. |
| The Following User Says Thank You to Slick For This Useful Post: | PollosHermanos (02-01-2015) |
#2637 | |
Great - appreciate the help.
![]() Quote:
#2638 |
Drives: 2013 FRS
Does it fit?
17x9 et52mm rim 255/40/17 dunlop direzza zii star specs. Aiming for basically no camber to be flush. Im okay with getting full suspension and trimming wheel wells, im just not okay with excessive camber and the tires sticking out of the wheel well. So with a set of AST 4150's and the full alignment array of parts you think it will fit? Its not that far off what i've seen others run still a beefy setup though. Let me know! All help appreciated! |
#2639 |
Drives: 2015 Subaru BRZ
Hey there,
New Brz owner here, 2015 Limited. I am currently looking at buying ROTA D2-Ex wheels 18x9.5 +38mm 73 with the sumitomo tires 265/35ZR18 I currently have Tein S-tech lowering springs on the car Im unsure if the wheels will fit in the front just because of the width? Thanks for any help! |
#2640 | |
And why no camber? Understand not wanting excessive camber, but getting some negative camber helps with handling and fitment too. |
#2641 |
I'm really in love with the look of the flat black MB Battle wheels. I am lowered 3-3.5 inches on BC Racing coilovers.
Unfortunately they only come in 18 X9.5 5x114.30 23 offset. As our cars are 5x100 I would have to purchase 15mm conversion spacers. I also plan on purchasing the GT Spec toe kit & Powered by Max rear lower control arms. How can I make these fit without having it super cambered out & without rubbing at the same time? & what kind of tire specs should I go for? Here is an idea of how low my car is:
#2642 | |
Starting with a +23 and adding a 15mm spacer will give you an effective offset of +8. That's not even close to what you need especially when trying to fit a 9.5" wheel. |
#2643 |
Thanks for the speedy reply!
Here's another alternative then. The Gunmetal Grey MB Battles come in: 18 X8 5-114.30 43 offset Adding the 15mm adapters would make it come out to +28 That should be able to fit & sit flush correct? What kind of tire specs should I go for? I was thinking 215/35/18. |
#2644 |
Resident Noob
Drives: Satin White BRZ Limited
Looks like I am going to go a diff direction.. how about 245/35/18's with 18x8 +45? will it run fine on stock without rubbing?
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust “Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson |
#2645 | |
You could go with the 245/35 (meatier), or 225/40 (smaller) but more ideal for the 8" wheel size. You should have no issues if you want to run the 245's and both tire sizes are perfect OEM diameter. No rubbing either way. |
#2646 | |
Drives: 2013 FRS
Mostly i want a rear tire that is straight up and down and has the largest contact patch in a straight line for boost, and up front i wouldnt mind a 1-1.8 ish degrees of camber for fitment and a little bit of grip in the corners. Still kinda thinking about everything |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
