#2619 |
Drives: 2015 Scion FR-S
I'm currently considering to get 18x9.0 with a 40 offset or 18x9.5 with a 43 offset. Both setups would be square and they would be wrapped around in 245/35 tires. I'm lowered on TRD springs. Would I have any issues with either setup? Thanks
#2620 | |
Drives: FR-S Firestorm 6MT
For a 7.5" wide wheel, I would suggest going with a 225/45R17. You could also use a 235, but they will more expensive and only you will be able to tell the difference at quick glance. If you do auto-x, you might consider an 8" wide wheel (around +35 offset) with a 245/40R17 tire if that keeps you within the rules. |
| The Following User Says Thank You to Slick For This Useful Post: | PollosHermanos (01-16-2015) |
#2621 | |
These would fit well if you were lowered and on coilovers:
http://www.ft86club.com/forums/showthread.php?t=7535 and compare others running the same wheel or a different wheel with the same specs. You'll find that most people running 18x9.5 are running a +38 offset and probably everyone is running coilovers. |
#2622 |
On a 8.5" wheel, you could fit a 255, but if you're stock you would be better with a 245/35R18 or a 235/40R18 (less common size). 225/40R18 will also fit but a bit of a stretch.
#2623 | |
These should work with the ProKit, you shouldn't need the camber bolts but you'll gain a bit of camber with them which will help them tuck in a bit more (less poke). |
| The Following User Says Thank You to Slick For This Useful Post: | SilverBullet86Z (01-17-2015) |
#2624 | |
You may find you need small spacers to clear inside once you lower (depending how much). CHeck out the wheel directory here: http://www.ft86club.com/forums/showthread.php?t=7535 and compare the different setups on Raijins. Here is someone running your combo but looks lowered. http://www.ft86club.com/forums/showthread.php?t=21697 |
| The Following User Says Thank You to Slick For This Useful Post: | SpeedFromSwede (01-18-2015) |
#2625 |
Drives: '14 Subaru BRZ Sport-Tech SSM
#2626 | |
Resident Noob
Drives: Satin White BRZ Limited
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust “Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson |
#2627 | |
Pretty much anything up front wider than 9" will rub on coils or stock suspension. If you fit these, the wheels will contact the spring perch, plus the tires will rub on the outer fender lip. To make these fit you need to go to coilovers. You will gain extra inside clearance from the smaller suspension components and then, will need extra camber to make sure the outside of the tire doesn't rub, probably somewhere around -2.5 to -3.0 all around. Read this thread for more info: http://www.ft86club.com/forums/showthread.php?t=35463 Your options are:
#2628 |
Drives: 2017 Cayman S
Not speaking as an authority, but yes it will work (based on my experience).
I installed a similar setup (exact wheels sizes) (tires: 245/35 & 265/35) about a week ago and on stock suspension I'm clear in the rear, and have roughly 5mm clearance in the front. After 150 + miles no rubbing even at full lock. My RCE Yellow springs are scheduled to arrive tomorrow. According to RCE, the fitment should remain good. However, Myles says that installing crash bolts will reduce clearance further.
… and loving it! Maxwell Smart
. Gone but not forgotten 2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT |
| The Following User Says Thank You to Agent 86 For This Useful Post: | SpeedFromSwede (01-18-2015) |
#2629 |
Drives: Asphalt FR-S 2013
I'm planning on getting ag f440 in 19 x 8.5(front) and 9.5 (rear).
They're custom so I got to choose an offset! Any recommendations? I'm looking to flush to fender |
#2630 |
Drives: FRS
Will this fit? (width, offset and tire size Qs)
I'm trying to buy wheels (looking at the works emotion or the rota torque, depends which one is easier to buy) on my country. but can't decide on the offset. What will be the best offset and tire for 17x9 square setup on stock (trd springs) without any poke. I want a flush or a bit inside the fenders setup. Thanks.
#2631 |
Drives: Subaru BRZ
Can someone tell me which set up is more flush:
18x7.5 +38 front, 18x8.75 +33 rear like fellow member ericmpena or just 18x8.75 all round. And if 18x8.75 all around should I go for offset +33 or +35. I'm running Eibach Pro Kit. Wheels I'm considering is the XXR 530. Also what's the best tyre size, I currently have 225/40 front and 245/35 rear, can I reuse these tyres? Thanks! Last edited by KenN; 01-25-2015 at 07:57 AM. |
#2632 |
Drives: 2014 FR-S 6MT Monogram Series
wanted to get the rpf1 for tracking my car. i was thinking of getting a 17x9 and running either a 235/35 or 245/35 tire and plan on getting a BBK in the future. I currently have kw v3 coilovers and camber plates.
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
