#2577 | |
Drives: FR-S Firestorm 6MT
Pros and Cons? It's not a huge difference, so doubt anyone will notice but you. Pretty much the same tire size, and you should be able to run up to 245/35R18 on both. The 225-wide is better suited for a 7.5+8" wide wheel while the 245 is better on the 8.5" but there is a bit of play there (like folks with 225's on 9's, lol). I would suggest you choose the wheel width that gives you the best offset of the 2. For me, I would go with the 8" +37 as opposed to the 8.5+31 (+47 will fit but lots of tuck). The other thing to consider is suspension upgrade, not sure if you are lowered or not. Also, tire choice is a factor, easier to run the bigger tire with the 8.5+31. |
| The Following User Says Thank You to Slick For This Useful Post: | Kayshart (11-17-2014) |
#2578 | |
Best to post here as these guys are of the same mindset as you (stance crowd). http://www.ft86club.com/forums/showt...25171&page=123 As you can see from this thread (if you choose to read the whole thing or just a few pages), pretty crazy wheels and offsets can be made to fit if you want it to. The wheels will fit, but stanced is all about camber. Read on... |
#2579 | |
Drives: Scion frs
#2580 |
Wayward Member
Drives: Hot Lava 86
Is it possible to have enough camber for a 17x8 +32 not to poke up front without it looking ridiculous?
#2581 |
Drives: Subaru BRZ
will this guys fit? I'm looking at this 3SDM 0.06 18" 5x100 et35 245. I want to run the same size on all four. will this be possible if I go 2" down? My only fear is for the tires to touch. Im installing st suspension coilovers xta as well.
thanks for all the help guys |
#2583 |
Drives: 2013 Firestorm FRS MT
Plan on running 18 x 10 +36 Square. Ideally I would like to run 275/35/18 square but i doubt i could fit that in the front. What do you guys suggest? I'm on coilovers.
#2584 |
Drives: Nissan GT-R
I will run H&R coilovers and want a square wheel setup on my EU 2014 GT86.
Plan is to run 9.5x18 with either 245/40-18(MPSS) or 255/35-18(PZero) but the question is if I should go for ET35 or ET40? What issues could I be facing?
Nurburgring 07:42 BTG
#2585 | |
These are RPF1 17x8 +35. So you're only 3mm further out. http://www.ft86club.com/forums/showthread.php?t=37136 And with a mild drop, the natural camber will bring them in a bit. |
#2586 | |
![]() Not sure what you mean by stock wheels and Advan +47 wheels though. I would consider a wheel with a better offset instead of dealing with studs or extended lugnuts. |
| The Following User Says Thank You to Slick For This Useful Post: | Kayshart (11-27-2014) |
#2587 | |
Even with an 18x9 +35, you can fit a 245 on all corners easily. I am running that spec wheel with 255/35R18 currently with no rubbing and -2.2F/-2.0R camber on a 1" drop. With a 2" drop, you should be okay with 245/35R18 with the proper camber settings. |
#2588 | |
See the aggressive wheels thread here for more info: http://www.ft86club.com/forums/showthread.php?t=25171 |
#2589 | |
With the +35, you will need more camber dialed-in to eliminate the poke or rubbing. Tire size for that wheel should be the 255/35R18 or 245/35R18. A 245/40R18 will be too tall. |
| The Following User Says Thank You to Slick For This Useful Post: | MadeInSweden (12-01-2014) |
#2590 |
Drives: Whiteout frs
17x9 +28
Lowered 2" not sure on tire specs yet cheers |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
